[PATCH 01/16] beatnik: Move -Dxxx to configure.ac
Fri May 18 05:41:16 UTC 2018
On 16/05/18 17:09, Joel Sherrill wrote:
> Updates #3425.
>   bsps/powerpc/beatnik/config/beatnik.cfg       | 2 +-
>   c/src/lib/libbsp/powerpc/beatnik/configure.ac | 2 ++
>   2 files changed, 3 insertions(+), 1 deletion(-)
> diff --git a/bsps/powerpc/beatnik/config/beatnik.cfg b/bsps/powerpc/beatnik/config/beatnik.cfg
> index 1190cad..05bea38 100644
> --- a/bsps/powerpc/beatnik/config/beatnik.cfg
> +++ b/bsps/powerpc/beatnik/config/beatnik.cfg
> @@ -14,7 +14,7 @@ RTEMS_BSP_FAMILY=beatnik
>   #  This contains the compiler options necessary to select the CPU model
>   #  and (hopefully) optimize for it.
> -CPU_CFLAGS = -mcpu=7400 -D__ppc_generic
> +CPU_CFLAGS = -mcpu=7400
>   #T. Straumann; disable sdata=eabi for now until CEXP supports it -meabi -msdata=eabi
>   # optimize flag: typically -0, could use -O4 or -fast
> diff --git a/c/src/lib/libbsp/powerpc/beatnik/configure.ac b/c/src/lib/libbsp/powerpc/beatnik/configure.ac
> index a48007c..b332aaa 100644
> --- a/c/src/lib/libbsp/powerpc/beatnik/configure.ac
> +++ b/c/src/lib/libbsp/powerpc/beatnik/configure.ac
> @@ -34,6 +34,8 @@ Note that the policy can still be defined by the application
>   CONFIGURE_MALLOC_BSP_SUPPORTS_SBRK this feature is removed
>   and a little memory is saved.])
> +AC_DEFINE(__ppc_generic, 1, [PowerPC model option])
>   # Explicitly list all Makefiles here
>   AC_CONFIG_FILES([Makefile])
I would rather eliminate the only user of __ppc_generic in
bsps/powerpc/include/rtems/powerpc/powerpc.h.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
