[PATCH 01/16] beatnik: Move -Dxxx to configure.ac
Joel Sherrill
joel at rtems.org
Fri May 18 13:21:14 UTC 2018
On Fri, May 18, 2018 at 12:41 AM, Sebastian Huber <
> On 16/05/18 17:09, Joel Sherrill wrote:
>> Updates #3425.
>> bsps/powerpc/beatnik/config/beatnik.cfg | 2 +-
>> c/src/lib/libbsp/powerpc/beatnik/configure.ac | 2 ++
>> 2 files changed, 3 insertions(+), 1 deletion(-)
>> diff --git a/bsps/powerpc/beatnik/config/beatnik.cfg
>> b/bsps/powerpc/beatnik/config/beatnik.cfg
>> index 1190cad..05bea38 100644
>> --- a/bsps/powerpc/beatnik/config/beatnik.cfg
>> +++ b/bsps/powerpc/beatnik/config/beatnik.cfg
>> @@ -14,7 +14,7 @@ RTEMS_BSP_FAMILY=beatnik
>> # This contains the compiler options necessary to select the CPU model
>> # and (hopefully) optimize for it.
>> -CPU_CFLAGS = -mcpu=7400 -D__ppc_generic
>> +CPU_CFLAGS = -mcpu=7400
>> #T. Straumann; disable sdata=eabi for now until CEXP supports it -meabi
>> -msdata=eabi
>> # optimize flag: typically -0, could use -O4 or -fast
>> diff --git a/c/src/lib/libbsp/powerpc/beatnik/configure.ac
>> b/c/src/lib/libbsp/powerpc/beatnik/configure.ac
>> index a48007c..b332aaa 100644
>> --- a/c/src/lib/libbsp/powerpc/beatnik/configure.ac
>> +++ b/c/src/lib/libbsp/powerpc/beatnik/configure.ac
>> @@ -34,6 +34,8 @@ Note that the policy can still be defined by the
>> application
>> CONFIGURE_MALLOC_BSP_SUPPORTS_SBRK this feature is removed
>> and a little memory is saved.])
>> +AC_DEFINE(__ppc_generic, 1, [PowerPC model option])
>> # Explicitly list all Makefiles here
>> AC_CONFIG_FILES([Makefile])
> I would rather eliminate the only user of __ppc_generic in
> bsps/powerpc/include/rtems/powerpc/powerpc.h.
I have file another ticket #3431 to address this and assigned it to you.
I am committing my changes because they eliminate use of -D on the GCC
command line
and allow packages using rtems_waf to compile.
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180518/60425471/attachment.html>
