[PATCH] covoar.cc: Correct build path checks for multiple executables.
Cillian O'Donnell
cpodonnell8 at gmail.com
Fri May 18 13:39:50 UTC 2018
On Fri, 18 May 2018, 12:36 Vijay Kumar Banerjee, <vijaykumar9597 at gmail.com>
wrote:
> On 18 May 2018 at 12:30, Cillian O'Donnell <cpodonnell8 at gmail.com> wrote:
>> Cool, you should run it for the full testsuite and take a look at that
>> report (takes a while.. around 575 tests)
>>>> When I try to run the full testsuites it gives the following error .
> What could be causing this ?
If you run the full testsuite without the coverage options, does it still
happen?
> self.__bootstrap_inner()
> File "/usr/lib64/python2.7/threading.py", line 817, in __bootstrap_inner
> (self.name, _format_exc()))
> IOError: [Errno 11] Resource temporarily unavailable
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180518/33508552/attachment.html>
