[PATCH 01/16] beatnik: Move -Dxxx to configure.ac
Fri May 18 13:44:46 UTC 2018
On 18/05/18 15:42, Joel Sherrill wrote:
> On Fri, May 18, 2018 at 8:25 AM, Sebastian Huber
> <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>> wrote:
>     On 18/05/18 15:21, Joel Sherrill wrote:
>         On Fri, May 18, 2018 at 12:41 AM, Sebastian Huber
>         <mailto:sebastian.huber at embedded-brains.de>>> wrote:
>             On 16/05/18 17:09, Joel Sherrill wrote:
>                 Updates #3425.
>                   bsps/powerpc/beatnik/config/beatnik.cfg      | 2 +-
>                   c/src/lib/libbsp/powerpc/beatnik/configure.ac
>         <http://configure.ac>
>                 <http://configure.ac> | 2 ++
>                   2 files changed, 3 insertions(+), 1 deletion(-)
>                 diff --git a/bsps/powerpc/beatnik/config/beatnik.cfg
>                 b/bsps/powerpc/beatnik/config/beatnik.cfg
>                 index 1190cad..05bea38 100644
>                 --- a/bsps/powerpc/beatnik/config/beatnik.cfg
>                 +++ b/bsps/powerpc/beatnik/config/beatnik.cfg
>                 @@ -14,7 +14,7 @@ RTEMS_BSP_FAMILY=beatnik
>                   #  This contains the compiler options necessary to
>         select
>                 the CPU model
>                   #  and (hopefully) optimize for it.
>                 -CPU_CFLAGS = -mcpu=7400 -D__ppc_generic
>                 +CPU_CFLAGS = -mcpu=7400
>                   #T. Straumann; disable sdata=eabi for now until CEXP
>                 supports it -meabi -msdata=eabi
>                     # optimize flag: typically -0, could use -O4 or -fast
>                 diff --git
>         a/c/src/lib/libbsp/powerpc/beatnik/configure.ac
>                 b/c/src/lib/libbsp/powerpc/beatnik/configure.ac
>                 index a48007c..b332aaa 100644
>                 --- a/c/src/lib/libbsp/powerpc/beatnik/configure.ac
>                 +++ b/c/src/lib/libbsp/powerpc/beatnik/configure.ac
>                 @@ -34,6 +34,8 @@ Note that the policy can still be
>         defined by
>                 the application
>                   CONFIGURE_MALLOC_BSP_SUPPORTS_SBRK this feature is
>         removed
>                   and a little memory is saved.])
>                   +AC_DEFINE(__ppc_generic, 1, [PowerPC model option])
>                   # Explicitly list all Makefiles here
>                   AC_CONFIG_FILES([Makefile])
>             I would rather eliminate the only user of __ppc_generic in
>             bsps/powerpc/include/rtems/powerpc/powerpc.h.
>         I have file another ticket #3431 to address this and assigned
>         it to you.
>         I am committing my changes because they eliminate use of -D on
>         the GCC command line
>         and allow packages using rtems_waf to compile.
>     Did you check that every consumer of these defines includes
>     <bspopts.h> somehow?
> powerpc.h fails to compile if it isn't provided.
Are these defines only used in powerpc.h?
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
