LIST OF IO BENCHMARKS
Fri May 18 17:49:04 UTC 2018
Udit,
Can you please compare pros/cons of FIO, IOZONE, and Bonnie++,
probably in a blog post is a good idea.
The GPLv2 is not a problem for test suites / benchmarks. It is only a
problem for code that should get merged into the rtems.git.
Gedare
On Thu, May 17, 2018 at 5:20 AM, Udit agarwal <dev.madaari at gmail.com> wrote:
> Hi all,
> As discussed in yesterday's IRC meeting, here is the list of different IO
> benchmarks(which are supported by FreeBSD) in the decreasing order of their
> popularity  :
> FIO - License type:  GPLv2 - Widely accepted for storage device benchmarking
> IOZONE - License: Customized - Large number of features, Also used for
> storage benchmarking
> Bonnie++ - GPLv2 - Widely known filesystem benchmark, Not much used for
> storage benchmarking.
> IOMETER -  GPLv2 - Out of active development.
> IORATE - Flexible - Out of active development
> I have performed SDIO-SDHCI performance analysis using IOZONE. Here are the
> results. And i have documented the process on my blog.
> Regards,
> Udit Agarwal
> devel mailing list
> devel at rtems.org
