[PATCH] covoar.cc: Correct build path checks for multiple executables.
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Fri May 18 20:59:59 UTC 2018
On 19 May 2018 at 01:30, Cillian O'Donnell <cpodonnell8 at gmail.com> wrote:
> On Fri, 18 May 2018, 14:55 Vijay Kumar Banerjee, <vijaykumar9597 at gmail.com>
> wrote:
>> On 18 May 2018 at 19:09, Cillian O'Donnell <cpodonnell8 at gmail.com> wrote:
>>> On Fri, 18 May 2018, 12:36 Vijay Kumar Banerjee, <
>>> vijaykumar9597 at gmail.com> wrote:
>>>> On 18 May 2018 at 12:30, Cillian O'Donnell <cpodonnell8 at gmail.com>
>>>> wrote:
>>>>> Cool, you should run it for the full testsuite and take a look at that
>>>>> report (takes a while.. around 575 tests)
>>>>>>> When I try to run the full testsuites it gives the following error .
>>>> What could be causing this ?
>>> If you run the full testsuite without the coverage options, does it
>>> still happen?
>> No it seems to run fine without coverage.
> I vaguely remember seeing this before last year, I suspect that when
> things are cleared up in coverage.py it will dissappear. So don't worry
> about it for now, carry on with what you're doing. What branch are you
> working on at the moment?
The path to build directory from the executable path is working now !
I'm working in this branch currently, I'll send a patch to all of it
together when it starts working. Please have a look and also suggest
improvements where applicable .
https://github.com/thelunatic/rtems-tools/tree/cov-tester-support.
after this update, running it on full testsuits doesn't give that error
anymore but it has some other issue. The report doesn't shows data only for
samples even after running it for full testsuites
and I'm getting this error :
ERROR==> Different lengths for the symbol CSWTCH.1 (16 and 544)
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180519/87889446/attachment.html>
