[PATCH] covoar.cc: Correct build path checks for multiple executables.
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Fri May 18 21:01:41 UTC 2018
On 19 May 2018 at 02:29, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com>
wrote:
> On 19 May 2018 at 01:30, Cillian O'Donnell <cpodonnell8 at gmail.com> wrote:
>> On Fri, 18 May 2018, 14:55 Vijay Kumar Banerjee, <
>> vijaykumar9597 at gmail.com> wrote:
>>> On 18 May 2018 at 19:09, Cillian O'Donnell <cpodonnell8 at gmail.com>
>>> wrote:
>>>> On Fri, 18 May 2018, 12:36 Vijay Kumar Banerjee, <
>>>>> On 18 May 2018 at 12:30, Cillian O'Donnell <cpodonnell8 at gmail.com>
>>>>> wrote:
>>>>>> Cool, you should run it for the full testsuite and take a look at
>>>>>> that report (takes a while.. around 575 tests)
>>>>>>>> When I try to run the full testsuites it gives the following error
>>>>> . What could be causing this ?
>>>> If you run the full testsuite without the coverage options, does it
>>>> still happen?
>>> No it seems to run fine without coverage.
>> I vaguely remember seeing this before last year, I suspect that when
>> things are cleared up in coverage.py it will dissappear. So don't worry
>> about it for now, carry on with what you're doing. What branch are you
>> working on at the moment?
> The path to build directory from the executable path is working now !
> I'm working in this branch currently, I'll send a patch to all of it
> together when it starts working.
I meant to say once the parsing of ini file starts working. the path to
build directory is already working.
> Please have a look and also suggest improvements where applicable .
> https://github.com/thelunatic/rtems-tools/tree/cov-tester-support.
> after this update, running it on full testsuits doesn't give that error
> anymore but it has some other issue. The report doesn't shows data only for
> samples even after running it for full testsuites
> and I'm getting this error :
> ERROR==> Different lengths for the symbol CSWTCH.1 (16 and 544)
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180519/2c8a45a7/attachment.html>
