[PATCH] Rework to minimize and eventually eliminate RTEMS use of bsp_specs
Joel Sherrill
joel at rtems.org
Fri May 18 21:47:20 UTC 2018
Thanks. I will try to deal with this Monday.
My specs patches are not ready to push to gcc so I need to focus on
just the parts to make x86_64 right.
On Fri, May 18, 2018 at 3:41 PM, Amaan Cheval <amaan.cheval at gmail.com>
wrote:
> To be clear, I applied this patch (with my fixes) on the 7.3 release
> through the RSB to test, not on GCC's master branch.
> > to add i386/rtemself64.h
> What you sent in this email thread adds rtemself64.h already. Do you
> mean you'd like to split the commits up or something?
> The only changes I made on top of yours were:
> - Readd "rtems.h" to config.gcc
> - Fix comments
> I've attached the patch file I used within the RSB here (sorry if you
> meant a patch of _just_ the fixes I made on top of yours, this is just
> the cumulative diff I used to patch GCC 7.3 to test).
> Regards,
> On Fri, May 18, 2018 at 7:00 PM, Joel Sherrill <joel at rtems.org> wrote:
> > On Fri, May 18, 2018 at 1:38 AM, Amaan Cheval <amaan.cheval at gmail.com>
> > wrote:
> >> I just compiled my local fixed copy (adding rtems.h back in) and
> >> there's good news! With the patch, the x86_64 compile stub works with
> >> a blank bsp_specs file!
> > Awesome!
> > Can you send me your changes as a patch? I am thinking I need to make
> > sure we agree on what the gcc master for x86_64-rtems looks like.
> > Apparently I owe committing a patch to add i386/rtemself64.h since it is
> > missing on the master. And the comment is wrong. What else?
> >> On Fri, May 18, 2018 at 12:59 AM, Amaan Cheval <amaan.cheval at gmail.com>
> >> wrote:
> >> > Hey!
> >> > Thanks so much for sharing this, it's quite useful to put your earlier
> >> > email[1] about minimzing the bsp_specs in context.
> >> > From looking ahead a bit without testing (still compiling), the patch
> >> > may need an ENDFILE_SPEC definition as well for "crtend.o" (it defines
> >> > __TMC_END__ which crtbegin.o has left undefined for eg.) and possibly
> >> > "crtn.o", at least to eliminate the x86_64 port's bsp_specs entirely
> >> > (see here[2]).
> >> Just noticed that ENDFILE_SPEC already includes crtend in i386elf.h,
> >> so there's no need for this change.
> >> > I've also left some comments inline below.
> >> > +1 on upstreaming this into GCC (making sure it also backports to 7.3
> >> > for simplicity, so we don't need to write a 7.3-specific patch for the
> >> > RSB as well) with a few additons (at least for the x86_64 target, to
> >> > try to have an empty bsp_specs to begin with).
> >> > [1] https://lists.rtems.org/pipermail/devel/2018-May/021430.html
> >> > [2]
> >> > https://github.com/AmaanC/rtems-gsoc18/blob/ac/daily-01-
> compile-stub/bsps/x86_64/amd64/start/bsp_specs
> >> > On Wed, May 16, 2018 at 8:46 PM, Joel Sherrill <joel at rtems.org>
> wrote:
> >> >> gcc/config.gcc | 2 +-
> >> >> gcc/config/arm/rtems.h | 4 ++++
> >> >> gcc/config/bfin/rtems.h | 4 ++++
> >> >> gcc/config/i386/rtemself.h | 6 +++++-
> >> >> gcc/config/i386/rtemself64.h | 39
> >> >> gcc/config/m68k/rtemself.h | 4 ++++
> >> >> gcc/config/microblaze/rtems.h | 4 ++++
> >> >> gcc/config/mips/rtems.h | 4 ++++
> >> >> gcc/config/moxie/rtems.h | 4 ++++
> >> >> gcc/config/nios2/rtems.h | 4 ++++
> >> >> gcc/config/riscv/rtems.h | 4 ++++
> >> >> gcc/config/rs6000/rtems.h | 5 +++++
> >> >> gcc/config/rtems.h | 6 +++++-
> >> >> gcc/config/sh/rtems.h | 4 ++++
> >> >> gcc/config/sh/rtemself.h | 4 ++++
> >> >> gcc/config/sparc/rtemself.h | 4 ++++
> >> >> gcc/config/v850/rtems.h | 4 ++++
> >> >> 17 files changed, 103 insertions(+), 3 deletions(-)
> >> >> create mode 100644 gcc/config/i386/rtemself64.h
> >> >> diff --git a/gcc/config.gcc b/gcc/config.gcc
> >> >> index d509800..de27e5c 100644
> >> >> --- a/gcc/config.gcc
> >> >> +++ b/gcc/config.gcc
> >> >> @@ -1499,7 +1499,7 @@ x86_64-*-elf*)
> >> >> tm_file="${tm_file} i386/unix.h i386/att.h dbxelf.h elfos.h
> >> >> newlib-stdint.h i386/i386elf.h i386/x86-64.h"
> >> >> x86_64-*-rtems*)
> >> >> - tm_file="${tm_file} i386/unix.h i386/att.h dbxelf.h elfos.h
> >> >> newlib-stdint.h i386/i386elf.h i386/x86-64.h i386/rtemself.h rtems.h"
> >> >> + tm_file="${tm_file} i386/unix.h i386/att.h dbxelf.h elfos.h
> >> >> newlib-stdint.h i386/i386elf.h i386/x86-64.h i386/rtemself64.h"
> >> > In rebasing with upstream, this commit must have silently mistakenly
> >> > also dropped rtems.h (which my patch earlier added to support the
> >> > -qrtems, -qnolinkcmds, etc. flags).
> >> >> i[34567]86-*-rdos*)
> >> >> newlib-stdint.h i386/i386elf.h i386/rdos.h"
> >> >> diff --git a/gcc/config/arm/rtems.h b/gcc/config/arm/rtems.h
> >> >> index 1123f4a..e79ce90 100644
> >> >> --- a/gcc/config/arm/rtems.h
> >> >> +++ b/gcc/config/arm/rtems.h
> >> >> @@ -34,3 +34,7 @@
> >> >> } while (0)
> >> >> #define ARM_DEFAULT_SHORT_ENUMS false
> >> >> +#undef STARTFILE_SPEC
> >> >> +#define STARTFILE_SPEC "\
> >> >> +%{!nostdlib: %{!qrtems: crt0.o%s} crti.o%s crtbegin.o%s}"
> >> >> diff --git a/gcc/config/bfin/rtems.h b/gcc/config/bfin/rtems.h
> >> >> index 6a9a41f..28a69b9 100644
> >> >> --- a/gcc/config/bfin/rtems.h
> >> >> +++ b/gcc/config/bfin/rtems.h
> >> >> @@ -31,3 +31,7 @@
> >> >> builtin_assert ("system=rtems"); \
> >> >> while (0)
> >> >> diff --git a/gcc/config/i386/rtemself.h b/gcc/config/i386/rtemself.h
> >> >> index 65e8dad..3a09354 100644
> >> >> --- a/gcc/config/i386/rtemself.h
> >> >> +++ b/gcc/config/i386/rtemself.h
> >> >> @@ -1,4 +1,4 @@
> >> >> -/* Definitions for rtems targeting an ix86 using ELF.
> >> >> +/* Definitions for rtems targeting an x86_64 using ELF.
> >> > I think you meant to have this comment in rtemself64.h, which says
> >> > ix86 currently?
> >> >> Copyright (C) 1996-2018 Free Software Foundation, Inc.
> >> >> Contributed by Joel Sherrill (joel at OARcorp.com).
> >> >> @@ -33,3 +33,7 @@
> >> >> while (0)
> >> >> +%{!nostdlib: %{!qrtems: crt0.o%s} crtbegin.o%s}"
> >> >> diff --git a/gcc/config/i386/rtemself64.h
> >> >> b/gcc/config/i386/rtemself64.h
> >> >> new file mode 100644
> >> >> index 0000000..34e5937
> >> >> --- /dev/null
> >> >> +++ b/gcc/config/i386/rtemself64.h
> >> >> @@ -0,0 +1,39 @@
> >> >> +/* Definitions for rtems targeting an ix86 using ELF.
> >> > See above.
> >> >> + Copyright (C) 1996-2018 Free Software Foundation, Inc.
> >> >> + Contributed by Joel Sherrill (joel at OARcorp.com).
> >> >> + This file is part of GCC.
> >> >> + GCC is free software; you can redistribute it and/or modify it
> >> >> + under the terms of the GNU General Public License as published
> >> >> + by the Free Software Foundation; either version 3, or (at your
> >> >> + option) any later version.
> >> >> + GCC is distributed in the hope that it will be useful, but
> WITHOUT
> >> >> + ANY WARRANTY; without even the implied warranty of
> MERCHANTABILITY
> >> >> + or FITNESS FOR A PARTICULAR PURPOSE. See the GNU General Public
> >> >> + License for more details.
> >> >> + Under Section 7 of GPL version 3, you are granted additional
> >> >> + permissions described in the GCC Runtime Library Exception,
> version
> >> >> + 3.1, as published by the Free Software Foundation.
> >> >> + You should have received a copy of the GNU General Public License
> >> >> and
> >> >> + a copy of the GCC Runtime Library Exception along with this
> >> >> program;
> >> >> + see the files COPYING3 and COPYING.RUNTIME respectively. If not,
> >> >> see
> >> >> + <http://www.gnu.org/licenses/>. */
> >> >> +/* Specify predefined symbols in preprocessor. */
> >> >> +#define TARGET_OS_CPP_BUILTINS() \
> >> >> + do \
> >> >> + builtin_define ("__rtems__"); \
> >> >> + builtin_define ("__USE_INIT_FINI__"); \
> >> >> + builtin_assert ("system=rtems"); \
> >> >> + while (0)
> >> >> diff --git a/gcc/config/m68k/rtemself.h b/gcc/config/m68k/rtemself.h
> >> >> index e18a06e..6f31aa5 100644
> >> >> --- a/gcc/config/m68k/rtemself.h
> >> >> +++ b/gcc/config/m68k/rtemself.h
> >> >> @@ -36,3 +36,7 @@
> >> >> while (0)
> >> >> diff --git a/gcc/config/microblaze/rtems.h
> >> >> b/gcc/config/microblaze/rtems.h
> >> >> index 5f23321..fc8914c 100644
> >> >> --- a/gcc/config/microblaze/rtems.h
> >> >> +++ b/gcc/config/microblaze/rtems.h
> >> >> @@ -35,3 +35,7 @@
> >> >> %{mbig-endian:-EB --oformat=elf32-microblaze} \
> >> >> %{mlittle-endian:-EL --oformat=elf32-microblazeel} \
> >> >> %{mxl-gp-opt:%{G*}} %{!mxl-gp-opt: -G 0}"
> >> >> diff --git a/gcc/config/mips/rtems.h b/gcc/config/mips/rtems.h
> >> >> index 66e00bf..6e96853 100644
> >> >> --- a/gcc/config/mips/rtems.h
> >> >> +++ b/gcc/config/mips/rtems.h
> >> >> @@ -37,3 +37,7 @@ do { \
> >> >> #undef MIPS_DEFAULT_GVALUE
> >> >> #define MIPS_DEFAULT_GVALUE 0
> >> >> diff --git a/gcc/config/moxie/rtems.h b/gcc/config/moxie/rtems.h
> >> >> index bc28d6e..6c79063 100644
> >> >> --- a/gcc/config/moxie/rtems.h
> >> >> +++ b/gcc/config/moxie/rtems.h
> >> >> @@ -38,3 +38,7 @@
> >> >> #undef PTRDIFF_TYPE
> >> >> #undef WCHAR_TYPE
> >> >> #undef WCHAR_TYPE_SIZE
> >> >> diff --git a/gcc/config/nios2/rtems.h b/gcc/config/nios2/rtems.h
> >> >> index b4a6082..f6eedf6 100644
> >> >> --- a/gcc/config/nios2/rtems.h
> >> >> +++ b/gcc/config/nios2/rtems.h
> >> >> This is done so RTEMS targets have Thread Local Storage like
> Linux.
> >> >> #define TARGET_LINUX_ABI 1
> >> >> diff --git a/gcc/config/riscv/rtems.h b/gcc/config/riscv/rtems.h
> >> >> index 231b6a0..a9d1e01 100644
> >> >> --- a/gcc/config/riscv/rtems.h
> >> >> +++ b/gcc/config/riscv/rtems.h
> >> >> @@ -29,3 +29,7 @@
> >> >> } while (0)
> >> >> diff --git a/gcc/config/rs6000/rtems.h b/gcc/config/rs6000/rtems.h
> >> >> index 54ddcb4..20a4ffa 100644
> >> >> --- a/gcc/config/rs6000/rtems.h
> >> >> +++ b/gcc/config/rs6000/rtems.h
> >> >> @@ -72,6 +72,11 @@
> >> >> while (0)
> >> >> +%{!nostdlib: %{!qrtems: crt0.o%s} ecrti.o%s crtbegin.o%s}"
> >> >> /* Copy and paste from linux64.h and freebsd64.h */
> >> >> #undef RELOCATABLE_NEEDS_FIXUP
> >> >> #define RELOCATABLE_NEEDS_FIXUP \
> >> >> diff --git a/gcc/config/rtems.h b/gcc/config/rtems.h
> >> >> index dcea95c..9a0619c 100644
> >> >> --- a/gcc/config/rtems.h
> >> >> +++ b/gcc/config/rtems.h
> >> >> @@ -30,11 +30,15 @@
> >> >> * Dummy start/end specification to let linker work as
> >> >> * needed by autoconf scripts using this compiler.
> >> >> +#if 0
> >> >> -#define STARTFILE_SPEC "crt0.o%s"
> >> >> +#define STARTFILE_SPEC "%{!qrtems: crt0.o%s}"
> >> >> +#endif
> >> >> +#if 0
> >> >> #undef ENDFILE_SPEC
> >> >> #define ENDFILE_SPEC ""
> >> >> +#endif
> >> >> * Some targets do not set up LIB_SPECS, override it, here.
> >> >> diff --git a/gcc/config/sh/rtems.h b/gcc/config/sh/rtems.h
> >> >> index d2f2b2a..f699151 100644
> >> >> --- a/gcc/config/sh/rtems.h
> >> >> +++ b/gcc/config/sh/rtems.h
> >> >> @@ -29,3 +29,7 @@
> >> >> builtin_define( "__rtems__" ); \
> >> >> builtin_assert( "system=rtems" ); \
> >> >> } while (0)
> >> >> diff --git a/gcc/config/sh/rtemself.h b/gcc/config/sh/rtemself.h
> >> >> index 6a67b49..85f26b0 100644
> >> >> --- a/gcc/config/sh/rtemself.h
> >> >> +++ b/gcc/config/sh/rtemself.h
> >> >> @@ -29,3 +29,7 @@
> >> >> } while (0)
> >> >> diff --git a/gcc/config/sparc/rtemself.h
> b/gcc/config/sparc/rtemself.h
> >> >> index e4b52d8..7c5bf43 100644
> >> >> --- a/gcc/config/sparc/rtemself.h
> >> >> +++ b/gcc/config/sparc/rtemself.h
> >> >> @@ -38,3 +38,7 @@
> >> >> /* Use the default */
> >> >> #undef LINK_GCC_C_SEQUENCE_SPEC
> >> >> diff --git a/gcc/config/v850/rtems.h b/gcc/config/v850/rtems.h
> >> >> index b20b2c3..1b56649 100644
> >> >> --- a/gcc/config/v850/rtems.h
> >> >> +++ b/gcc/config/v850/rtems.h
> >> >> @@ -39,3 +39,7 @@
> >> >> %{!mv850es:%{!mv850e1:%{mv*:-mv%*}} \
> >> >> %{m8byte-align:-m8byte-align} \
> >> >> %{mgcc-abi:-mgcc-abi}}"
> >> >> 1.8.3.1
> >> >> _______________________________________________
> >> >> devel mailing list
> >> >> devel at rtems.org
> >> >> http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180518/20c4b44b/attachment-0001.html>
