[PATCH] covoar.cc: Correct build path checks for multiple executables.
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Fri May 18 21:53:49 UTC 2018
On Sat, 19 May 2018, 03:06 Joel Sherrill, <joel at rtems.org> wrote:
> On Fri, May 18, 2018 at 4:01 PM, Vijay Kumar Banerjee <
> vijaykumar9597 at gmail.com> wrote:
>> On 19 May 2018 at 02:29, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com>
>> wrote:
>>> On 19 May 2018 at 01:30, Cillian O'Donnell <cpodonnell8 at gmail.com>
>>> wrote:
>>>> On Fri, 18 May 2018, 14:55 Vijay Kumar Banerjee, <
>>>>> On 18 May 2018 at 19:09, Cillian O'Donnell <cpodonnell8 at gmail.com>
>>>>> wrote:
>>>>>> On Fri, 18 May 2018, 12:36 Vijay Kumar Banerjee, <
>>>>>>> On 18 May 2018 at 12:30, Cillian O'Donnell <cpodonnell8 at gmail.com>
>>>>>>> wrote:
>>>>>>>> Cool, you should run it for the full testsuite and take a look at
>>>>>>>> that report (takes a while.. around 575 tests)
>>>>>>>>>> When I try to run the full testsuites it gives the following
>>>>>>> error . What could be causing this ?
>>>>>> If you run the full testsuite without the coverage options, does it
>>>>>> still happen?
>>>>> No it seems to run fine without coverage.
>>>> I vaguely remember seeing this before last year, I suspect that when
>>>> things are cleared up in coverage.py it will dissappear. So don't worry
>>>> about it for now, carry on with what you're doing. What branch are you
>>>> working on at the moment?
>>> The path to build directory from the executable path is working now !
>>> I'm working in this branch currently, I'll send a patch to all of it
>>> together when it starts working.
>> I meant to say once the parsing of ini file starts working. the path to
>> build directory is already working.
>>> Please have a look and also suggest improvements where applicable .
>>> https://github.com/thelunatic/rtems-tools/tree/cov-tester-support.
>>> after this update, running it on full testsuits doesn't give that error
>>> anymore but it has some other issue. The report doesn't shows data only for
>>> samples even after running it for full testsuites
> Do you have coverage output on all the tests?
I have coverage output on tests under samples/ only .
running it for the whole testsuits gives the same coverage output as with
samples/
> Is the verbose output indicating that all the tests are being looped over?
>>> and I'm getting this error :
>>> ERROR==> Different lengths for the symbol CSWTCH.1 (16 and 544)
> Cillian must want to purge all memory of this type of message. :)
> This message indicates that a symbol of interest (e.g. a function) has one
> length
> in one executable file and a completely different one in a second. Cillian
> worked
> on one of these last summer which was because the method was padded with
> a different number of nops in each executable. That was supposed to be
> handled
> by covoar but he found a nasty bug.
> This particular one looks like it is for a GCC generated symbol which
> should
> have been ignored in the symbols of interest. My bet is that the way we
> formerly
> got the DesiredSymbols only got real methods. The new way must also be
> picking up some "local" symbols that gcc is generating.
> If we know either of those executables, we should be able to look at the
> symbol table with nm and figure out what Chris is pulling in that he
> shouldn't.
> Is this a fatal error or just a "give up" on this symbol in this
> executable?
it doesn't break in the middle. Coverage does run but the report doesn't
look proper
> --joel
>> devel mailing list
>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180519/aaae8849/attachment.html>
