[PATCH] covoar.cc: Correct build path checks for multiple executables.
Joel Sherrill
joel at rtems.org
Fri May 18 22:56:38 UTC 2018
If you run nm on some of the executables, do you see the
Is symbol? We need to.know its type.
On Fri, May 18, 2018, 5:24 PM Vijay Kumar Banerjee <vijaykumar9597 at gmail.com>
wrote:
> On 19 May 2018 at 03:29, Joel Sherrill <joel at rtems.org> wrote:
>> On Fri, May 18, 2018 at 4:53 PM, Vijay Kumar Banerjee <
>> vijaykumar9597 at gmail.com> wrote:
>>> On Sat, 19 May 2018, 03:06 Joel Sherrill, <joel at rtems.org> wrote:
>>>> On Fri, May 18, 2018 at 4:01 PM, Vijay Kumar Banerjee <
>>>>> On 19 May 2018 at 02:29, Vijay Kumar Banerjee <
>>>>>> On 19 May 2018 at 01:30, Cillian O'Donnell <cpodonnell8 at gmail.com>
>>>>>> wrote:
>>>>>>> On Fri, 18 May 2018, 14:55 Vijay Kumar Banerjee, <
>>>>>>>> On 18 May 2018 at 19:09, Cillian O'Donnell <cpodonnell8 at gmail.com>
>>>>>>>> wrote:
>>>>>>>>> On Fri, 18 May 2018, 12:36 Vijay Kumar Banerjee, <
>>>>>>>>>> On 18 May 2018 at 12:30, Cillian O'Donnell <cpodonnell8 at gmail.com
>>>>>>>>>> > wrote:
>>>>>>>>>>> Cool, you should run it for the full testsuite and take a look
>>>>>>>>>>> at that report (takes a while.. around 575 tests)
>>>>>>>>>>>>> When I try to run the full testsuites it gives the following
>>>>>>>>>> error . What could be causing this ?
>>>>>>>>> If you run the full testsuite without the coverage options, does
>>>>>>>>> it still happen?
>>>>>>>> No it seems to run fine without coverage.
>>>>>>> I vaguely remember seeing this before last year, I suspect that when
>>>>>>> things are cleared up in coverage.py it will dissappear. So don't worry
>>>>>>> about it for now, carry on with what you're doing. What branch are you
>>>>>>> working on at the moment?
>>>>>> The path to build directory from the executable path is working now !
>>>>>> I'm working in this branch currently, I'll send a patch to all of it
>>>>>> together when it starts working.
>>>>> I meant to say once the parsing of ini file starts working. the path
>>>>> to build directory is already working.
>>>>>> Please have a look and also suggest improvements where applicable .
>>>>>> https://github.com/thelunatic/rtems-tools/tree/cov-tester-support.
>>>>>> after this update, running it on full testsuits doesn't give that
>>>>>> error anymore but it has some other issue. The report doesn't shows data
>>>>>> only for samples even after running it for full testsuites
>>>> Do you have coverage output on all the tests?
>>> I have coverage output on tests under samples/ only .
>>> running it for the whole testsuits gives the same coverage output as
>>> with samples/
>>>> Is the verbose output indicating that all the tests are being looped
>>>> over?
>>>>>> and I'm getting this error :
>>>>>> ERROR==> Different lengths for the symbol CSWTCH.1 (16 and 544)
>>>> Cillian must want to purge all memory of this type of message. :)
>>>> This message indicates that a symbol of interest (e.g. a function) has
>>>> one length
>>>> in one executable file and a completely different one in a second.
>>>> Cillian worked
>>>> on one of these last summer which was because the method was padded with
>>>> a different number of nops in each executable. That was supposed to be
>>>> handled
>>>> by covoar but he found a nasty bug.
>>>> This particular one looks like it is for a GCC generated symbol which
>>>> should
>>>> have been ignored in the symbols of interest. My bet is that the way we
>>>> formerly
>>>> got the DesiredSymbols only got real methods. The new way must also be
>>>> picking up some "local" symbols that gcc is generating.
>>>> If we know either of those executables, we should be able to look at
>>>> the
>>>> symbol table with nm and figure out what Chris is pulling in that he
>>>> shouldn't.
>>>> Is this a fatal error or just a "give up" on this symbol in this
>>>> executable?
>>> it doesn't break in the middle. Coverage does run but the report doesn't
>>> look proper
>> This is an auto-generated symbol by gcc which will be in the middle of a
>> method.
>> DesiredSymbols should be ignoring symbols like this. I don't think seeing
>> them
>> will cause a horrible problem but it is quite likely that the method(s)
>> these are
>> seen in will have quite incorrect results.
>> If running on samples looks OK, try running coverage from just tmtests and
>> see if that is better. You need to find a set small enough to trip the
>> problem
>> but easy to analyse.
> Coverage from tmtests looks OK .
> psxtmtests , psxtests, libtests gives the same error and doesn't show
> proper coverage report.
> Also, I can see these INFO lines even with the ones that are showing
> proper coverage output
> INFO: DesiredSymbols::mergeCoverageMap - Unable to merge coverage map for
> CSWTCH.1 because the sizes are different
> _Thread_queue_Operations_default because the sizes are different
> hex2ascii_data because the sizes are different
> _Workspace_Allocate_or_fatal_error because the sizes are different
> Coverage run for score finished successfully.
>> --joel
>>>> --joel
>>>>> _______________________________________________
>>>>> devel mailing list
>>>>> devel at rtems.org
>>>>> http://lists.rtems.org/mailman/listinfo/devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180518/87ceaa99/attachment-0001.html>
