[PATCH] covoar.cc: Correct build path checks for multiple executables.
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Sat May 19 12:26:08 UTC 2018
On 19 May 2018 at 17:50, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com>
wrote:
> On 19 May 2018 at 17:44, Cillian O'Donnell <cpodonnell8 at gmail.com> wrote:
>> On Sat, 19 May 2018, 12:28 Vijay Kumar Banerjee, <
>> vijaykumar9597 at gmail.com> wrote:
>>> On 19 May 2018 at 16:47, Cillian O'Donnell <cpodonnell8 at gmail.com>
>>> wrote:
>>>> God these messages again... at least I'm an expert in fixing these :)
>>>> Vijay I'm only seeing the headings in the report on my end using your
>>>> branch. How are you running it and from where? Is there any changes you
>>>> haven't pushed?
>>> I'm rurrning it from top of build tree, the latest change I pushed was
>>> yesterday
>>> <https://github.com/thelunatic/rtems-tools/commit/8b4d90821c2af3dc37282c06722cd3eadb5223f4> and
>>> I haven't made any changes after that. the report seems to be running here.
>> Strange.. if you clean everything away that covoar outputs and run it
>> again, can it still find the data?
> please see the attached image.
> It seems to be working pretty fine.
> Can you please try cleaning out everything, fetching my cov-tester-support
branch, ./waf build install it and then try running tester form the top of
the build tree?
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180519/ad2be010/attachment.html>
