[PATCH] covoar.cc: Correct build path checks for multiple executables.
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Sat May 19 12:28:33 UTC 2018
On 19 May 2018 at 17:56, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com>
wrote:
> On 19 May 2018 at 17:50, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com>
> wrote:
>> On 19 May 2018 at 17:44, Cillian O'Donnell <cpodonnell8 at gmail.com> wrote:
>>> On Sat, 19 May 2018, 12:28 Vijay Kumar Banerjee, <
>>> vijaykumar9597 at gmail.com> wrote:
>>>> On 19 May 2018 at 16:47, Cillian O'Donnell <cpodonnell8 at gmail.com>
>>>> wrote:
>>>>> God these messages again... at least I'm an expert in fixing these :)
>>>>> Vijay I'm only seeing the headings in the report on my end using your
>>>>> branch. How are you running it and from where? Is there any changes you
>>>>> haven't pushed?
>>>> I'm rurrning it from top of build tree, the latest change I pushed was
>>>> yesterday
>>>> <https://github.com/thelunatic/rtems-tools/commit/8b4d90821c2af3dc37282c06722cd3eadb5223f4> and
>>>> I haven't made any changes after that. the report seems to be running here.
>>> Strange.. if you clean everything away that covoar outputs and run it
>>> again, can it still find the data?
>> please see the attached image.
>> It seems to be working pretty fine.
>> Can you please try cleaning out everything, fetching my
> cov-tester-support branch, ./waf build install it and then try running
> tester form the top of the build tree?
please run it for samples only, running it for whole testsuites is not
generating proper report currently.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180519/5d0e3e61/attachment-0001.html>
