[PATCH] covoar.cc: Correct build path checks for multiple executables.
Cillian O'Donnell
cpodonnell8 at gmail.com
Sat May 19 19:15:19 UTC 2018
It works.. Sorry I was using the right covoar but the wrong rtems-test. Ahh
its nice to see the data back in the reports again. Did you manage to track
down 2 exes with the mismatch in symbol size?
On 19 May 2018 at 13:59, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com>
wrote:
> On 19 May 2018 at 18:28, Cillian O'Donnell <cpodonnell8 at gmail.com> wrote:
>> On Sat, 19 May 2018, 13:28 Vijay Kumar Banerjee, <
>> vijaykumar9597 at gmail.com> wrote:
>>> On 19 May 2018 at 17:56, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com>
>>> wrote:
>>>> On 19 May 2018 at 17:50, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com
>>>> > wrote:
>>>>> On 19 May 2018 at 17:44, Cillian O'Donnell <cpodonnell8 at gmail.com>
>>>>> wrote:
>>>>>> On Sat, 19 May 2018, 12:28 Vijay Kumar Banerjee, <
>>>>>>> On 19 May 2018 at 16:47, Cillian O'Donnell <cpodonnell8 at gmail.com>
>>>>>>> wrote:
>>>>>>>> God these messages again... at least I'm an expert in fixing these
>>>>>>>> :) Vijay I'm only seeing the headings in the report on my end using your
>>>>>>>> branch. How are you running it and from where? Is there any changes you
>>>>>>>> haven't pushed?
>>>>>>> I'm rurrning it from top of build tree, the latest change I pushed
>>>>>>> was yesterday
>>>>>>> <https://github.com/thelunatic/rtems-tools/commit/8b4d90821c2af3dc37282c06722cd3eadb5223f4> and
>>>>>>> I haven't made any changes after that. the report seems to be running here.
>>>>>> Strange.. if you clean everything away that covoar outputs and run it
>>>>>> again, can it still find the data?
>>>>> please see the attached image.
>>>>> It seems to be working pretty fine.
>>>>> Can you please try cleaning out everything, fetching my
>>>> cov-tester-support branch, ./waf build install it and then try running
>>>> tester form the top of the build tree?
>>> please run it for samples only, running it for whole testsuites is not
>>> generating proper report currently.
>> Yeah I'll give it another try when I get home. At the beach at the moment.
> sure , enjoy !
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180519/a28930c8/attachment-0001.html>
