[PATCH] covoar.cc: Correct build path checks for multiple executables.
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Sun May 20 14:35:37 UTC 2018
On 20 May 2018 at 00:53, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com>
wrote:
> On Sun, 20 May 2018, 00:45 Cillian O'Donnell, <cpodonnell8 at gmail.com>
> wrote:
>> It works.. Sorry I was using the right covoar but the wrong rtems-test.
>> Ahh its nice to see the data back in the reports again. Did you manage to
>> track down 2 exes with the mismatch in symbol size?
> Great! so next is the parsing of the symbol file.
> I couldn't manage to track down the mismatch.
> I have pushed these to my master branch.
The latest update to cov-tester-support branch (please have a look)
parses the symbol-set ini file from the coverage script. The parsing
is working but currently it's not generating reports, as covoar
needs to be updated .
Here are the things that I have done and that needs to be
done in order to generate reports :
I have added a symbol-sets.ini file and parsed it from the coverage script
this is how it works :
- The ini file can be updated with all the symbols, separated by ' , '
(comma)
- The coverages splits them and makes a list of all the sets
- The respective libraries are parsed from the libraries section.
- It returns a dict with all the symbols and thir resp. library
addresses.
- The library addresses are absolute so it can be run from anywhere
top of build tree is not necessary.
This way we can parse all the symbols from the same ini file.
what needs to be done :
- I have added #FIXME s in the code , those are the small fixes that
would be needed .
- The covoar needs to be updated. My proposal is that we can feed the
parsed dict to the covoar instead of feeding the symbol file and
letting
covoar parse it ( As I mentioned previously).
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180520/a5df47ff/attachment.html>
