[GSOC] Weekly report
Mon May 21 10:34:10 UTC 2018
Hello Vidushi,
do you already have something that we can try out?
----- Vidushi Vashishth <reachvidu at gmail.com> schrieb:
> Hi!
> As asked by my mentor, I am going to post my weekly project target on the
> mailing list every Monday. For this week I have the following planned:
> 1) Develop use cases (common development problems catered to, etc) for the
> rtems tracing support and identify what all needs to be implemented around
> with it. This would be documented first in my blog then the users manual.
> 2) Create a babeltrace conversion formula for CTF conversion. Document it
> with sufficient example test cases.
> 3) Fixing the buffering sample test cases which is currently failing a
> rtems-path check on execution.
> 4) Gain familiarity with barectf, identify methods of integrating it with
> rtems-tld output and working on array support for barectf.
> Best,
> Vidushi
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
