LIST OF IO BENCHMARKS
Mon May 21 13:08:22 UTC 2018
"License type customized" is not clear to me what that means, it would
be worth explaining
On Sun, May 20, 2018 at 7:32 PM, Joel Sherrill <joel at rtems.org> wrote:
> On Sat, May 19, 2018, 5:06 PM Udit agarwal <dev.madaari at gmail.com> wrote:
>> Hi,
>> On Fri, May 18, 2018 at 11:19 PM, Gedare Bloom <gedare at rtems.org> wrote:
>>> Udit,
>>> Can you please compare pros/cons of FIO, IOZONE, and Bonnie++,
>>> probably in a blog post is a good idea.
>> Done, here is the comparison.
> That url has a hard-coded IP address in it. GSoC blogs should be hosted
> somewhere where they will have a long life with stable URLs.
> It looks nice though. :)
>>> The GPLv2 is not a problem for test suites / benchmarks. It is only a
>>> problem for code that should get merged into the rtems.git.
>>> Gedare
>>> On Thu, May 17, 2018 at 5:20 AM, Udit agarwal <dev.madaari at gmail.com>
>>> wrote:
>>> > Hi all,
>>> > As discussed in yesterday's IRC meeting, here is the list of different
>>> > IO
>>> > benchmarks(which are supported by FreeBSD) in the decreasing order of
>>> > their
>>> > popularity  :
>>> > FIO - License type:  GPLv2 - Widely accepted for storage device
>>> > benchmarking
>>> > IOZONE - License: Customized - Large number of features, Also used for
>>> > storage benchmarking
>>> > Bonnie++ - GPLv2 - Widely known filesystem benchmark, Not much used for
>>> > storage benchmarking.
>>> > IOMETER -  GPLv2 - Out of active development.
>>> > IORATE - Flexible - Out of active development
>>> > I have performed SDIO-SDHCI performance analysis using IOZONE. Here are
>>> > the
>>> > results. And i have documented the process on my blog.
>>> > Regards,
>>> > Udit Agarwal
>>> > _______________________________________________
>>> > devel mailing list
>>> > devel at rtems.org
>>> > http://lists.rtems.org/mailman/listinfo/devel
>> devel mailing list
>> devel at rtems.org
