[PATCH] covoar.cc: Correct build path checks for multiple executables.
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Mon May 21 17:01:37 UTC 2018
On 21 May 2018 at 21:42, Joel Sherrill <joel at rtems.org> wrote:
> On Mon, May 21, 2018 at 10:13 AM, Vijay Kumar Banerjee <
> vijaykumar9597 at gmail.com> wrote:
>> On 21 May 2018 at 20:37, Joel Sherrill <joel at rtems.org> wrote:
>>> On Mon, May 21, 2018 at 9:52 AM, Vijay Kumar Banerjee <
>>>> On 21 May 2018 at 17:39, Joel Sherrill <joel at rtems.org> wrote:
>>>>> CPU-rtems5-objdump
>>>>> sparc-rtems5-objdump worked , thanks .
>>>> I can see some mismatches in the disassembly .
>>> I'm building sparc now. What mismatches do you see?
>>> I started another thread for CSWTCH.*. That's not the type of mismatch
>>> Cillian
>>> worked on last summer. It is a symbol that isn't even code and shouldn't
>>> be
>>> in the symbol set.
>> I saw the other thread . In sparc I'm getting CSWTCH.* in local text
>> segment "t" .
> Grr... this may require us to toss out some symbol patterns that are
> generated
> by GCC.
>> [lunatic at lunatic samples]$ sparc-rtems5-nm base_sp/base_sp.exe | grep -i
>> csw
>> 40010c18 t CSWTCH.1
> I see this also on the sparc. On the i386, it is rodata.
>> I followed the INFO messages for a mismatch in
>> _Workspace_Allocate_or_fatal_error
>> here's what I came up with
>> --------------- capture.exe
>> [lunatic at lunatic samples]$ sparc-rtems5-objdump -d capture/capture.exe |
>> grep "_Workspace_Allocate_or_fatal_error"
>> 40010c5c: 40 00 15 8c call 4001628c <_Workspace_Allocate_or_fatal_error>
>> 400117ac: 40 00 12 b8 call 4001628c <_Workspace_Allocate_or_fatal_error>
>> 40011938: 40 00 12 55 call 4001628c <_Workspace_Allocate_or_fatal_error>
>> 40015c94: 40 00 01 7e call 4001628c <_Workspace_Allocate_or_fatal_error>
>> 4001628c <_Workspace_Allocate_or_fatal_error>:
>> 400162ac: 02 80 00 04 be 400162bc <_Workspace_Allocate_or_fatal_
>> error+0x30>
>> 4002cb14: 7f ff a5 de call 4001628c <_Workspace_Allocate_or_fatal_error>
>> -------------- base_sp.exe
>> [lunatic at lunatic samples]$ sparc-rtems5-objdump -d base_sp/base_sp.exe |
>> 40008068: 40 00 11 49 call 4000c58c <_Workspace_Allocate_or_fatal_error>
>> 400089f4: 40 00 0e e6 call 4000c58c <_Workspace_Allocate_or_fatal_error>
>> 40008b80: 40 00 0e 83 call 4000c58c <_Workspace_Allocate_or_fatal_error>
>> 4000c0e0: 40 00 01 2b call 4000c58c <_Workspace_Allocate_or_fatal_error>
>> 4000c58c <_Workspace_Allocate_or_fatal_error>:
>> 4000c5ac: 02 80 00 04 be 4000c5bc <_Workspace_Allocate_or_fatal_
>> error+0x30>
> That shows the references to the symbol not the size. You need to look at
> the start of
> the symbol and start of the following symbol.
> I looked at the "nm -N" output for base_sp.
> 0200ba0c T _Workspace_Allocate_or_fatal_error
> 0200ba48 T _SPARC_Counter_read_address
> I get this for base_sp
4000c58c T _Workspace_Allocate_or_fatal_error
4000c5e0 T syscall
0xe0 - 0x8c = 0x54 ==> 84
> And for capture:
> 02015c3c T _Workspace_Allocate_or_fatal_error
> 02015c78 T rtems_shell_wait_for_explicit_input
> 4001628c T _Workspace_Allocate_or_fatal_error
400162c8 T rtems_shell_wait_for_explicit_input
0xc8 - 0x8c = 0x3C ==> 60
base_sp: 0x48 - 0x0c = 0x3C ==> 60
> capture: 0x78 - 0x3c = 0x3c ==> 60
> Based on that alone, they are the same size. Now let's look at the objdump
> and see what's
> at the end that might look like padding:
> base_sp.exe ========================
> _Internal_error( INTERNAL_ERROR_WORKSPACE_ALLOCATION );
> 200ba3c: 7f ff ea d4 call 200658c <_Internal_error>
> 200ba40: 90 10 20 03 mov 3, %o0
> 200ba44: 01 00 00 00 nop
> The nop would be considered padding by covoar since it is at the end of
> the method.
> capture.exe ===========================
> 2015c6c: 7f ff e6 53 call 200f5b8 <_Internal_error>
> 2015c70: 90 10 20 03 mov 3, %o0
> 2015c74: 01 00 00 00 nop
> Comparing the body of the two methods based on objdump output, I don't
> see any difference for sparc/erc32 at -O2.
> I repeated looking at the objdump output at -Os and they were the same
> instructions
> and length.
> You will have to investigate to see why they are different on your side.
> What am I doing different ? Is it because of the covoar patches ?
(have you applied the patches ?)
> --joel
>>>> Probably i386. Aren't you running pc386?
>>>>> I'm running sparc
>>>>> Not sparc/erc32 or Leon
>>>>> On Mon, May 21, 2018, 6:35 AM Cillian O'Donnell <cpodonnell8 at gmail.com>
>>>>> wrote:
>>>>>> On Mon, 21 May 2018, 12:18 Vijay Kumar Banerjee, <
>>>>>>> On 21 May 2018 at 16:39, Cillian O'Donnell <cpodonnell8 at gmail.com>
>>>>>>> wrote:
>>>>>>>> On Mon, 21 May 2018, 12:08 Cillian O'Donnell, <
>>>>>>>> cpodonnell8 at gmail.com> wrote:
>>>>>>>>> On Mon, 21 May 2018, 11:49 Vijay Kumar Banerjee, <
>>>>>>>>>> On 21 May 2018 at 11:56, Cillian O'Donnell <cpodonnell8 at gmail.com
>>>>>>>>>> > wrote:
>>>>>>>>>>> On Sun, 20 May 2018, 22:33 Vijay Kumar Banerjee, <
>>>>>>>>>>>> On 21 May 2018 at 02:29, Cillian O'Donnell <
>>>>>>>>>>>>> On Sun, 20 May 2018, 15:35 Vijay Kumar Banerjee, <
>>>>>>>>>>>>>> On 20 May 2018 at 00:53, Vijay Kumar Banerjee <
>>>>>>>>>>>>>>> On Sun, 20 May 2018, 00:45 Cillian O'Donnell, <
>>>>>>>>>>>>>>>> It works.. Sorry I was using the right covoar but the wrong
>>>>>>>>>>>>>>>> rtems-test. Ahh its nice to see the data back in the reports again. Did you
>>>>>>>>>>>>>>>> manage to track down 2 exes with the mismatch in symbol size?
>>>>>>>>>>>>>>> Great! so next is the parsing of the symbol file.
>>>>>>>>>>>>>>> I couldn't manage to track down the mismatch.
>>>>>>>>>>>>>>> I have pushed these to my master branch.
>>>>>>>>>>>>>> The latest update to cov-tester-support branch (please have a
>>>>>>>>>>>>>> look)
>>>>>>>>>>>>>> parses the symbol-set ini file from the coverage script. The
>>>>>>>>>>>>>> parsing
>>>>>>>>>>>>>> is working but currently it's not generating reports, as
>>>>>>>>>>>>>> covoar
>>>>>>>>>>>>>> needs to be updated .
>>>>>>>>>>>>> It's best if covoar reads it's own config file, otherwise it
>>>>>>>>>>>>> creates a dependency on the tester. Scanning over the recent changes to
>>>>>>>>>>>>> covoar there, it looks like it can already handle multiple sets, so the one
>>>>>>>>>>>>> ini with multiple sets in it is the way to go.
>>>>>>>>>>>> Okay, Understood.
>>>>>>>>>>>>> Here are the things that I have done and that needs to be
>>>>>>>>>>>>>> done in order to generate reports :
>>>>>>>>>>>>>> I have added a symbol-sets.ini file and parsed it from the
>>>>>>>>>>>>>> coverage script
>>>>>>>>>>>>>> this is how it works :
>>>>>>>>>>>>>> - The ini file can be updated with all the symbols,
>>>>>>>>>>>>>> separated by ' , ' (comma)
>>>>>>>>>>>>> This is the way covoar is actually handling it now. You should
>>>>>>>>>>>>> test a multi set ini and see if that's working.
>>>>>>>>>>>> Yeah, I have seen it. will try with multiple sets.
>>>>>>>>>>>>>> - The coverages splits them and makes a list of all the
>>>>>>>>>>>>>> sets
>>>>>>>>>>>>>> - The respective libraries are parsed from the libraries
>>>>>>>>>>>>>> section.
>>>>>>>>>>>>>> - It returns a dict with all the symbols and thir resp.
>>>>>>>>>>>>>> library addresses.
>>>>>>>>>>>>>> - The library addresses are absolute so it can be run
>>>>>>>>>>>>>> from anywhere
>>>>>>>>>>>>>> top of build tree is not necessary.
>>>>>>>>>>>>>> This was a good idea but it's just that dependency issue we
>>>>>>>>>>>>> want to stay away from. Covoar has something to find the build directory
>>>>>>>>>>>>> too, it just hasn't been connected up yet, so running it from the top of
>>>>>>>>>>>>> the build directory is ok for the moment.
>>>>>>>>>>>> yes it can find the build directory. I was giving it a shot to
>>>>>>>>>>>> do it from the script.
>>>>>>>>>>>> If covoar's standalone working is a necessity then it surely
>>>>>>>>>>>> needs to be working
>>>>>>>>>>>> from covoar and shouldn't depend on the script.
>>>>>>>>>>> It should be working from covoar and it will.
>>>>>>>>>>>>> Probably the most pressing thing now is investigating those
>>>>>>>>>>>>> mismatch in symbol size.
>>>>>>>>>>>> any advice on where/how to look for it ?
>>>>>>>>>>> Before what I was doing was examining the objdump of 2 exes,
>>>>>>>>>>> looking there on the weekend i think the info messages mentioned which ones
>>>>>>>>>>> were having trouble for which symbol. It says something like "couldn't
>>>>>>>>>>> merge coverage map for some_symbol because sizes from exe != to size of
>>>>>>>>>>> other_exe. Look at the objdump of exe and other_exe, search for some_symbol
>>>>>>>>>>> and compare the dissasembly. There'll be more lines in one than the other,
>>>>>>>>>>> nop padding probably. Then you had to find a check that was strict enough
>>>>>>>>>>> to chop the end of the symbol in question at the right place but not so
>>>>>>>>>>> strict that it chopped other symbols in the wrong place. However the method
>>>>>>>>>>> of obtaining the symbols has changed, I'll have to have a look over the
>>>>>>>>>>> covoar changes tonight to see what would be the equivalent method of
>>>>>>>>>>> checking this now. Unless Chris or Joel come back with the answer before
>>>>>>>>>>> then.
>>>>>>>>>>> Please have a look into this as I'm confused .
>>>>>>>>>> From the messages it seems like there's something with
>>>>>>>>>> the base_sp.exe .
>>>>>>>>>> I tried to run objdum with -d , I'm getting an error
>>>>>>>>>> objdump: can't disassemble for architecture UNKNOWN!
>>>>>>>>>> what am I missing ?
>>>>>>>>> It'll be a sparc-objdump that was built with the rsb in 5/bin/.
>>>>>>>>> I'm not sure if we're still grabbing the objdump using rtems-tools
>>>>>>>> can't run sparc-objdump.
>>>>>> That might not be the exact name. Is there something that looks like
>>>>>> it in that directory.
>>>>>>> Sorry *rtemstoolkit
>>>>>>>>> now, so not 100% sure that this still the way to investigate this.
>>>>>>>>>> Also there will probably be multiple ini's with different
>>>>>>>>>>> collections of sets that the user could run so it would be good to give
>>>>>>>>>>> them some method of choosing which ini they want, like coverage=score will
>>>>>>>>>>> feed score.ini to covoar. You could try have a go at that.
>>>>>>>>>> yeah I was planning something similar with the script
>>>>>>>>>> to let users choose the sets, and run all by default .
>>>>>>>>>> I guess it needs to be done from covoar to avoid dependancy.
>>>>>>>>>> I can have look into this.
>>>>>>>>> This is different in that it's just allowing the user an easier
>>>>>>>>> way of choosing the right ini. So it wouldn't be a dependency like the
>>>>>>>>> other thing, if you run it manually you will still have to select the ini
>>>>>>>>> you want. So this will be part of the script.
>>>>>>>> Oh , I will look into this then. :)
>>>>>>>> This way we can parse all the symbols from the same ini file.
>>>>>>>>>>>>>> what needs to be done :
>>>>>>>>>>>>>> - I have added #FIXME s in the code , those are the small
>>>>>>>>>>>>>> fixes that
>>>>>>>>>>>>>> would be needed .
>>>>>>>>>>>>>> - The covoar needs to be updated. My proposal is that we
>>>>>>>>>>>>>> can feed the
>>>>>>>>>>>>>> parsed dict to the covoar instead of feeding the symbol
>>>>>>>>>>>>>> file and letting
>>>>>>>>>>>>>> covoar parse it ( As I mentioned previously).
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180521/ca1f4375/attachment-0001.html>
