APA Scheduler Documentation Missing?
Wed May 23 19:23:22 UTC 2018
I don't think it is fully functional, but maybe I'm mistaken.
On Wed, May 23, 2018 at 11:43 AM, Joel Sherrill <joel at rtems.org> wrote:
> Hi
> Looking at the list of schedulers available in confdefs.h based on the
> following comment block:
> *  - CONFIGURE_SCHEDULER_PRIORITY - Deterministic Priority Scheduler
>  *  - CONFIGURE_SCHEDULER_PRIORITY_SMP - Deterministic Priority SMP
> Scheduler
>  *  - CONFIGURE_SCHEDULER_PRIORITY_AFFINITY_SMP - Deterministic
>  *    Priority SMP Affinity Scheduler
>  *  - CONFIGURE_SCHEDULER_STRONG_APA - Strong APA Scheduler
>  *  - CONFIGURE_SCHEDULER_SIMPLE - Light-weight Priority Scheduler
>  *  - CONFIGURE_SCHEDULER_SIMPLE_SMP - Simple SMP Priority Scheduler
>  *  - CONFIGURE_SCHEDULER_EDF - EDF Scheduler
>  *  - CONFIGURE_SCHEDULER_EDF_SMP - EDF SMP Scheduler
>  *  - CONFIGURE_SCHEDULER_CBS - CBS Scheduler
>  *  - CONFIGURE_SCHEDULER_USER  - user provided scheduler
> I don't think Strong APA is documented in configuring a system or
> scheduler concepts. Arbitrary Priority is used as the name.
> I suspect most of the information is here but there is some naming
> inconsistency and APA as an acronym or the configure_xxx constant
> is not documented.
> --joel
> devel mailing list
> devel at rtems.org
