APA Scheduler Documentation Missing?
Thu May 24 04:56:14 UTC 2018
On 23/05/18 17:43, Joel Sherrill wrote:
> Hi
> Looking at the list of schedulers available in confdefs.h based on the
> following comment block:
> *  - CONFIGURE_SCHEDULER_PRIORITY - Deterministic Priority Scheduler
>  *  - CONFIGURE_SCHEDULER_PRIORITY_SMP - Deterministic Priority SMP
> Scheduler
>  *  - CONFIGURE_SCHEDULER_PRIORITY_AFFINITY_SMP - Deterministic
>  *    Priority SMP Affinity Scheduler
>  *  - CONFIGURE_SCHEDULER_STRONG_APA - Strong APA Scheduler
>  *  - CONFIGURE_SCHEDULER_SIMPLE - Light-weight Priority Scheduler
>  *  - CONFIGURE_SCHEDULER_SIMPLE_SMP - Simple SMP Priority Scheduler
>  *  - CONFIGURE_SCHEDULER_EDF - EDF Scheduler
>  *  - CONFIGURE_SCHEDULER_EDF_SMP - EDF SMP Scheduler
>  *  - CONFIGURE_SCHEDULER_CBS - CBS Scheduler
>  *  - CONFIGURE_SCHEDULER_USER  - user provided scheduler
> I don't think Strong APA is documented in configuring a system or
> scheduler concepts. Arbitrary Priority is used as the name.
> I suspect most of the information is here but there is some naming
> inconsistency and APA as an acronym or the configure_xxx constant
> is not documented.
The scheduler configured with CONFIGURE_SCHEDULER_STRONG_APA has only a
stub implementation. It should not be used.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
