Covoar address to line to DWARF updates.
Thu May 24 12:51:28 UTC 2018
Vijay,
Please test Chris' modifications.
On Thu, May 24, 2018 at 2:23 AM, Chris Johns <chrisj at rtems.org> wrote:
> Hi,
> I have pushed my latest set of changes to my personal repo to remove covoar
> exec'ing addr2line and to directly use the DWARF debug info.
> I have not been able to fully test the results because I do not have a suitable
> .exe and .cov pair with match source. The executable and coverage data I have
> received has helped but objdump fails because I do not have the source in the
> executable path so does not find the source.
> I would like to get these changes on to master as soon as possible so if a
> covoar built from my repo can be tested I can then push the changes to master.
> I have added to RTEMS Tools an addr2line utility as I needed a tool to test the
> DWARF support I have added to the rtemstoolkit.
> The repo is https://git.rtems.org/chrisj/rtems-tools.git and the changes are on
> the branch 'covoar-dwarf'.
> Thanks
> Chris
> devel mailing list
> devel at rtems.org
