Covoar address to line to DWARF updates.
Thu May 24 21:22:39 UTC 2018
On 25/5/18 7:11 am, Vijay Kumar Banerjee wrote:
> On Fri, 25 May 2018, 00:35 Joel Sherrill, <joel at rtems.org
> <mailto:joel at rtems.org>> wrote:
>     On Thu, May 24, 2018, 10:43 AM Vijay Kumar Banerjee
>     <vijaykumar9597 at gmail.com <mailto:vijaykumar9597 at gmail.com>> wrote:
>         On 24 May 2018 at 18:58, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com
>             On 24 May 2018 at 18:21, Gedare Bloom <gedare at rtems.org
>             <mailto:gedare at rtems.org>> wrote:
>                 Vijay,
>                 Please test Chris' modifications.
>                 On Thu, May 24, 2018 at 2:23 AM, Chris Johns <chrisj at rtems.org
>                 <mailto:chrisj at rtems.org>> wrote:
>                 > Hi,
>                 > I have pushed my latest set of changes to my personal repo to remove covoar
>                 > exec'ing addr2line and to directly use the DWARF debug info.
>                 > I have not been able to fully test the results because I do not have a suitable
>                 > .exe and .cov pair with match source. The executable and coverage data I have
>                 > received has helped but objdump fails because I do not have the source in the
>                 > executable path so does not find the source.
>                 > I would like to get these changes on to master as soon as possible so if a
>                 > covoar built from my repo can be tested I can then push the changes to master.
>                 > I have added to RTEMS Tools an addr2line utility as I needed a tool to test the
>                 > DWARF support I have added to the rtemstoolkit.
>                 > The repo is https://git.rtems.org/chrisj/rtems-tools.git and the changes are on
>                 > the branch 'covoar-dwarf'.
>              Hello ,
>             I have added the .cov trace file and the objdump output of hello.exe
>             that I'm getting.
>             Is there anything else I should be doing to test it ?
>             Shall I send the txt reports generated from covoar ?
>         I merged your branch with my current working branch that's
>         producing html reports.
>         When I run in for samples/ I'm getting some report that looks good.
>         But when I run for the whole testsuites. It trips in the middle after a
>         lot of
>         INFO messages. It shows the following error:
>         INFO: DesiredSymbols::createCoverageMap - Attempt to create unified
>         coverage maps for CSWTCH.1 with different sizes
>         (/home/lunatic/development/rtems/kernel/leon3/sparc-rtems5/c/leon3/testsuites/libtests/mghttpd01/mghttpd01.exe/2148!=
>         /home/lunatic/development/rtems/kernel/leon3/sparc-rtems5/c/leon3/testsuites/benchmarks/dhrystone/dhrystone.exe/16)
>         error: SymbolTable::addSymbol: Different lengths for the symbol CSWTCH.1
>         (16 and 544)
>         error: covoar failure exit code:
Is this the error that stops covoar?
>     This is the symbol loading picking up rodata merged into the text segment.
>     Chris know about this and it is on his to-do list.
>     Can you ignore these and see how the results look?
> it doesn't show results, it exits in the middle with the error, even before
> coverage starts generating reports.
Is that the error message above?
