[PATCH] config: Hide CONFIGURE_INITIAL_EXTENSION_TABLE
Sebastian Huber
Fri May 25 08:15:33 UTC 2018
Rename CONFIGURE_INITIAL_EXTENSION_TABLE to
_CONFIGURE_INITIAL_EXTENSION_TABLE to emphasise that this is not a user
configuration option.
cpukit/include/rtems/confdefs.h | 6 +++---
1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/cpukit/include/rtems/confdefs.h b/cpukit/include/rtems/confdefs.h
index 985a59e8ce..4ed9c193b0 100644
--- a/cpukit/include/rtems/confdefs.h
+++ b/cpukit/include/rtems/confdefs.h
@@ -2249,7 +2249,7 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
#endif
- #define CONFIGURE_INITIAL_EXTENSION_TABLE Configuration_Initial_Extensions
+ #define _CONFIGURE_INITIAL_EXTENSION_TABLE Configuration_Initial_Extensions
#define _CONFIGURE_NUMBER_OF_INITIAL_EXTENSIONS \
RTEMS_ARRAY_SIZE(Configuration_Initial_Extensions)
@@ -2259,7 +2259,7 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
RTEMS_SYSINIT_ORDER_MIDDLE
#else
- #define CONFIGURE_INITIAL_EXTENSION_TABLE NULL
+ #define _CONFIGURE_INITIAL_EXTENSION_TABLE NULL
#define _CONFIGURE_NUMBER_OF_INITIAL_EXTENSIONS 0
#endif
@@ -3107,7 +3107,7 @@ extern rtems_initialization_tasks_table Initialization_tasks[];
#endif
#endif
_CONFIGURE_NUMBER_OF_INITIAL_EXTENSIONS, /* number of static extensions */
- CONFIGURE_INITIAL_EXTENSION_TABLE, /* pointer to static extensions */
+ _CONFIGURE_INITIAL_EXTENSION_TABLE, /* pointer to static extensions */
#if defined(RTEMS_MULTIPROCESSING)
CONFIGURE_MULTIPROCESSING_TABLE, /* pointer to MP config table */
#endif
2.13.6
