[PATCH] covoar.cc: Correct build path checks for multiple executables.
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Sun May 27 19:25:01 UTC 2018
On 28 May 2018 at 00:49, Joel Sherrill <joel at rtems.org> wrote:
> It sounds like great progress is being made but this thread is very long
> and I am losing track of what needs committing.
> We can start a new thread. :)
> Plus there is Chris' work to merge as well.
> How close is everything to moving back to master on the main repo?
> It seems to be close.
currently the only significant change that's needed
is the covoar update that I suggested. Other than that
there are a few #FIXMEs in the code that I added.
They are small issues and need a quick fix.
We can start a new thread with these topics as
it's very close to merging.
BTW, the coverage can now run from outside the
build directory as well :)
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180528/66a07152/attachment.html>
