RISC-V tool chain
Mon May 28 05:23:02 UTC 2018
Hello,
we currently have a riscv32-rtems* and riscv64-rtems* tool chain.
However, the RISC-V GCC is a bi-arch compiler, e.g. we have
riscv32-rtems5-gcc --print-multi-lib
rv32i/ilp32;@march=rv32i at mabi=ilp32
rv32im/ilp32;@march=rv32im at mabi=ilp32
rv32iac/ilp32;@march=rv32iac at mabi=ilp32
rv32imac/ilp32;@march=rv32imac at mabi=ilp32
rv32imafc/ilp32f;@march=rv32imafc at mabi=ilp32f
rv64imac/lp64;@march=rv64imac at mabi=lp64
rv64imafdc/lp64d;@march=rv64imafdc at mabi=lp64d
riscv64-rtems5-gcc --print-multi-lib
The only difference is the default ISA.
I suggest to merge the two tool chains into one riscv-rtems* variant.
The riscv64_generic BSP uses -mcmodel=medany. Is this ABI compatible to
the multilibs which use the default (-mcmodel=medlow)?
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
