RISC-V tool chain
Hesham Almatary heshamelmatary at gmail.com
Mon May 28 09:14:12 UTC 2018
On Mon, May 28, 2018 at 6:23 AM, Sebastian Huber
> Hello,
> we currently have a riscv32-rtems* and riscv64-rtems* tool chain. However,
> the RISC-V GCC is a bi-arch compiler, e.g. we have
> riscv32-rtems5-gcc --print-multi-lib
> rv32i/ilp32;@march=rv32i at mabi=ilp32
> rv32im/ilp32;@march=rv32im at mabi=ilp32
> rv32iac/ilp32;@march=rv32iac at mabi=ilp32
> rv32imac/ilp32;@march=rv32imac at mabi=ilp32
> rv32imafc/ilp32f;@march=rv32imafc at mabi=ilp32f
> rv64imac/lp64;@march=rv64imac at mabi=lp64
> rv64imafdc/lp64d;@march=rv64imafdc at mabi=lp64d
> riscv64-rtems5-gcc --print-multi-lib
> The only difference is the default ISA.
> I suggest to merge the two tool chains into one riscv-rtems* variant.
We can get rid of riscv32* and just use riscv64* to build 32-bit
RTEMS. The question is whether it's easy/feasible to have just
"riscv-rtems*" toolchain (i.e. without 32 or 64 suffixes ), from
gcc/source-builder.
> The riscv64_generic BSP uses -mcmodel=medany. Is this ABI compatible to the
> multilibs which use the default (-mcmodel=medlow)?
Hesham
