[PATCH] bsps/riscv: Rename riscv_generic to riscv32_generic and add compiler flags
Hesham Almatary heshamelmatary at gmail.com
Mon May 28 10:02:28 UTC 2018
On Mon, May 28, 2018 at 10:55 AM, Sebastian Huber
> On 28/05/18 11:47, Hesham Almatary wrote:
>> This makes it explicitly 32-bit. Compiler flags are needed if built with
>> a non riscv32-* toolchain (e.g. riscv64-* with multilib).
> I would like to rename the BSPs to use the ISA name, e.g. rv32imac,
> rv64imafdc, etc. I also would like to add support for Qemu and use the
> device tree for the driver initialization (clock, console, interrupt
> controller).
Sounds good. Are you working on that?
This should make them a bit more generic. Does the spike
> simulator provide a device tree?
Yes it does.
> devel mailing list
> devel at rtems.org
Hesham
