[PATCH] bsps/riscv: Rename riscv_generic to riscv32_generic and add compiler flags
Hesham Almatary heshamelmatary at gmail.com
Mon May 28 11:19:04 UTC 2018
On Mon, May 28, 2018 at 12:01 PM, Sebastian Huber
> On 28/05/18 12:02, Hesham Almatary wrote:
>> On Mon, May 28, 2018 at 10:55 AM, Sebastian Huber
>>> On 28/05/18 11:47, Hesham Almatary wrote:
>>>> This makes it explicitly 32-bit. Compiler flags are needed if built with
>>>> a non riscv32-* toolchain (e.g. riscv64-* with multilib).
>>> I would like to rename the BSPs to use the ISA name, e.g. rv32imac,
>>> rv64imafdc, etc. I also would like to add support for Qemu and use the
>>> device tree for the driver initialization (clock, console, interrupt
>>> controller).
>> Sounds good. Are you working on that?
Great! Please discard my latest rename patch then if it duplicates
with what your local-WIP changes.
> Yes:
> https://devel.rtems.org/ticket/3433
> We need also floating-point support.
>> This should make them a bit more generic. Does the spike
>>> simulator provide a device tree?
>> Yes it does.
> Ok, good. I will try to install this simulator as well.
Hesham
