[GSOC] CTF generator configuration files
Vidushi Vashishth reachvidu at gmail.com
Tue May 29 17:43:13 UTC 2018
Hello!
I am in the process of writing a CTF generator configuration file. This
will be used in converting trace data into Common Trace Format. I am
following the flow of events as described in [1] for the conversion
process. Have there been previous attempts to create CTF generator
configuration? Is there any change to the CTF conversion process? The wiki
page I am referring to for this purpose was last updated in 2016 hence I
needed to ask this. I have followed the documentation provided in [2] and
[3] to understand how configuration files are written and function. Have I
left any relevant documentation which could help in this process?
Best,
Vidushi
References:
[1] https://devel.rtems.org/wiki/Developer/Tracing
[2] https://devel.rtems.org/wiki/Developer/Tracing/Trace_Linker
[3] https://devel.rtems.org/wiki/Developer/Tracing/Trace_Buffering
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180529/73e44261/attachment.html>
