[GSOC] CTF generator configuration files
Tue May 29 20:42:25 UTC 2018
Vidushi,
You might find some ideas from the 2016 RTEMS CTF GSoC Project:
 http://rtems-tracing-tweaks.blogspot.com/
 https://github.com/vivek9191/rtems/commits/master
Nothing more recent was done with any success that I know of. I don't
know if anyone ever wrote the configuration needed for babeltrace to
convert rtems trace output into CTF. Much of the previous 2 GSoC
efforts tried to integrate barectf code generation with the
trace/capture code base.
Gedare
On Tue, May 29, 2018 at 1:43 PM, Vidushi Vashishth <reachvidu at gmail.com> wrote:
> Hello!
> I am in the process of writing a CTF generator configuration file. This will
> be used in converting trace data into Common Trace Format. I am following
> the flow of events as described in [1] for the conversion process. Have
> there been previous attempts to create CTF generator configuration? Is there
> any change to the CTF conversion process? The wiki page I am referring to
> for this purpose was last updated in 2016 hence I needed to ask this. I have
> followed the documentation provided in [2] and [3] to understand how
> configuration files are written and function. Have I left any relevant
> documentation which could help in this process?
> Best,
> Vidushi
> References:
> [1] https://devel.rtems.org/wiki/Developer/Tracing
> [2] https://devel.rtems.org/wiki/Developer/Tracing/Trace_Linker
> [3] https://devel.rtems.org/wiki/Developer/Tracing/Trace_Buffering
> devel mailing list
> devel at rtems.org
