[PATCH] Updating trace buffer configuration
Wed May 30 05:29:20 UTC 2018
On 29/05/18 17:36, Vidushi Vashishth wrote:
>   linkers/rtld-trace-buffer.ini | 5 +++--
>   1 file changed, 3 insertions(+), 2 deletions(-)
> diff --git a/linkers/rtld-trace-buffer.ini b/linkers/rtld-trace-buffer.ini
> index af9fc31..ee68d55 100644
> --- a/linkers/rtld-trace-buffer.ini
> +++ b/linkers/rtld-trace-buffer.ini
> @@ -26,6 +26,7 @@ buffer-local = " uint8_t* in;"
>   header = "#include <stdint.h>"
>   header = "#include <rtems.h>"
>   header = "#include <rtems/rtems/tasksimpl.h>"
> +header = "#include <rtems/score/threadimpl.h>"
>   [trace-buffer-tracers]
>   code = <<<CODE
> @@ -84,8 +85,8 @@ static inline uint32_t __rtld_tbg_executing_id(void)
>   static inline uint32_t __rtld_tbg_executing_status(void)
>     /* @fixme Add the current CPU for SMP. */
> -  struct Thread_Control* tc = _Thread_Get_executing();
Could you please change the
struct _Thread_Control
to
Thread_Control
and check if it still works.
In RTEMS, we use typedefs for structures in general.
> -  return (tc->current_priority << 8) | tc->real_priority;
> +  struct _Thread_Control* tc = _Thread_Get_executing();
> +  return (_Thread_Get_priority(tc) << 8) | tc->Real_priority.priority;
>   static inline uint32_t __rtld_tbg_executing_state(void)
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
