[GSoC] Ways to make the x86_64 port work with UEFI
Amaan Cheval amaan.cheval at gmail.com
Wed May 30 11:13:58 UTC 2018
On Wed, May 30, 2018 at 4:30 AM, Joel Sherrill <joel at rtems.org> wrote:
> On Tue, May 29, 2018 at 11:26 AM, Amaan Cheval <amaan.cheval at gmail.com>
> wrote:
>> On Tue, May 29, 2018 at 9:28 PM, Amaan Cheval <amaan.cheval at gmail.com>
>> wrote:
>> > Noted, thanks a ton for the details! Unrelated to the topic at hand,
>> > but out of interest, is this the only reading material for further
>> > details? http://ceur-ws.org/Vol-1697/EWiLi16_12.pdf
>> > In brief: My tests for keeping a libfake.a (compiled without -fpic)
>> > and a loader.so with a user-appXYZ.c have been successful, but I'm not
>> > sure if my assumptions hold for all cases. See the details below for
>> > more.
>> > Next actions:
>> > - Read more of Linkers and Loaders since it seems to be the only
>> > detailed resource I've found at this point
>> > - Experiment with actually using the existing librtems*.a I've got and
>> > making them boot as a PE UEFI application image
>> > In more detail:
>> > The problem:
>> > That UEFI needs a relocatable PE file, i.e. one that can function
>> > regardless of the physical address it's loaded at (no virtual
>> > addresses that early).
>> > To build an ELF of that kind, the resources I've seen all build their
>> > source with -fpic, and then use objcopy to convert the ELF into a
>> > relocatable PE, with an embedded runtime self-relocator (akin to
>> > load-time relocation, if I'm understanding correctly).
>> > What Joel suggested seems to be the simplest option - see if not using
>> > -fpic for _all_ of RTEMS' build system is fine. I think it might be
>> > from some testing, but I'm not sure if this is conclusive since I need
>> > to understand the specifics of the entire development process better.
>> > So here's my understanding of the situation at the moment:
>> > - librtems*.a is made up of object files, compiled without -fpic, and
>> > that should be fine because I believe object files will use RIP
>> > relative addressing code by default on x64 where it can, and leave the
>> > rest for link-time relocations to handle. IF this is true, this works
>> > perfectly for us because all memory accesses and jumps/calls are
>> > relative.
> Just to be clear. For Deos, I am compiling all code with -fPIC. This
> includes all librtemscpu.a and librtemsbsp.a. When I accidentally
> missed an adapter file, that caused an issue.
Oh my, that's me misreading majorly, sorry about that. I'm still
unclear on how this works:
> Unless the loader forces something, you can use PIC with no build system changes.
I meant that to build with fpic for x86_64/amd64 and nothing else,
we'd end up having to add a lot of special cases within the build
system for even the "generic" parts of RTEMS, such as what's in cpukit
(all the subdirs except cpukit/score/cpu), right? My concern was that
in doing this, the already overcomplicated build system gets more
complicated. If y'all don't think that kind of "if amd64, then use
-fPIC" logic feels hacky, I'm okay with this approach 100%, and we can
work to find a way to make that special-casing as explicit as
possible.
>> > - We can have a loader.c which acts as the core with the efi_main
>> > function - compile it with -fpic into loader.so, and then link
>> > loader.so, librtems*.a, and user-appXYZ.c together to form a
>> > relocatable ELF, then convert it into a PE using objcopy. Note that
>> > from what I can tell, the ELF generated from this still has type EXEC,
>> > not DYN, according to readelf.
>> Correction: This was a leftover file that I'd forgotten to take out
>> after renaming a target. Sorry about the confusion. Just using the
>> "-shared" flag does cause the resulting ELF to be of type DYN.
>> > The concerns I have are about my assumptions; if GCC generates any
>> > code that uses absolute addressing and that is resolved as a link-time
>> > relocation, that could be problematic because the final relocatable PE
>> > may not match up with the resolved absolute address.
> The Deos kernel guys had me check readelf on a known good executable
> with the ones I was producing. The loadable sections should match up.
> For example, on one architecture I missed an alignment in the linkcmds
> and on another, an argument hidden in bsp_specs made a section writable
> which should have been read-only. Just check what you can with readelf
> and objdump section headers.
>> > My tests with a fake static archive library, and creating a PE have
>> > been successful, but I'm unsure of how to trigger the relocation
>> > behavior by the UEFI firmware (i.e. loading the UEFI image at an
>> > address other than it's preferred one). One idea is to have a UEFI
>> > application image that loads this test UEFI application image through
>> > the "LoadImage" function UEFI provides as a service and then to use
>> > QEMU's monitor / gdb inspection capabilities to see if the address the
>> > image is loaded at genuinely changes.
> That's the question. Does the executable end up at a reliably known address?
_Usually_, yes. This can't be guaranteed, though, so we definitely
need a completely relocatable file if we're going with the option
where we create a completely self-contained hello.efi instead of a
loader.efi+hello.elf pair method.
Joel, if you can spare the time today, should we perhaps chat about
this before/after the GSoC IRC meeting later today? I think a quick
chat will help resolve this quicker.
>> > If any of you have any resources, that'd be highly appreciated. Some
>> > resources I'm using so far are:
>> > https://eli.thegreenplace.net/2011/11/03/position-independent-code-pic-in-shared-libraries/
>> > https://eli.thegreenplace.net/2011/08/25/load-time-relocation-of-shared-libraries/
>> > https://eli.thegreenplace.net/2012/01/03/understanding-the-x64-code-models
>> > Sorry about the length of the email!
>> > On Fri, May 25, 2018 at 10:51 PM, Joel Sherrill <joel at rtems.org> wrote:
>> >> On Fri, May 25, 2018, 12:11 PM Amaan Cheval <amaan.cheval at gmail.com>
>> >> wrote:
>> >>> Hey! Could you link me to some code that you used for the Deos setup
>> >>> you mentioned?
>> >>> My understanding is that the -shared option can link static archives
>> >>> to create a "shared" library in the sense that it doesn't include the
>> >>> usual crt0 runtime environment and whatnot, but the code within is
>> >>> still position-dependent. Given that the PE image that EFI needs is
>> >>> one that needs to be truly relocatable, this may not work - BUT, I've
>> >>> only just noticed the ./gnuefi/reloc_x86_64.c file which seems to
>> >>> handle some kinds of runtime relocations encoded within the converted
>> >>> PE file, so maybe this will work after all. I'll continue to
>> >>> investigate and let you know how it goes!
>> >> Deos isn't a good example except that you can compile with -fPIC and
>> >> put
>> >> that code into a static library. Deos is a closed source Level A (man
>> >> rated
>> >> flight) ARINC 653 RTOS. It's boot process reads configuration
>> >> information
>> >> about each partition and associates .so's with each address space per
>> >> the
>> >> configuration. It can't change after that.
>> >> The RTEMS exe is mostly linked as normal except to use some arguments
>> >> to say
>> >> some symbols are from a shared library.
>> >> The base address of the exe is that of the provided virtual address
>> >> space
>> >> with .data and .bss in their respective spaces.
>> >> And our entry point is in C so there is no asm before that. Great
>> >> simplification.
>> >>> Regarding how TLS differs with PIC - could you elaborate? Is it
>> >>> something we'll need to solve for if we go with the -fPIC option, or
>> >>> is it something we need to keep in mind as a limitation, but isn't
>> >>> really a blocker?
>> >> I don't think PIC changes the TLS mechanism on arm or PowerPC but on
>> >> i386,
>> >> when not PIC the TLS base is in %gs and it's a subroutine call when
>> >> PIC.
>> >> Just as well for Deos since they assume an application won't change the
>> >> segment register values.
>> >> Other than this one TLS difference, it is a normal exe to me. They just
>> >> magically provide their .so's before we run.
>> >>> On Fri, May 25, 2018 at 10:13 PM, Joel Sherrill <joel at rtems.org>
>> >>> wrote:
>> >>> > On Fri, May 25, 2018, 11:15 AM Amaan Cheval <amaan.cheval at gmail.com>
>> >>> > wrote:
>> >>> >> Hey!
>> >>> >> Skippable details about how FreeBSD handles the UEFI boot process!
>> >>> >> Having looked into it a bit more, my understanding of how FreeBSD
>> >>> >> handles this process is:
>> >>> >> - They build a two-stage bootloader for EFI, called boot1.efi and
>> >>> >> loader.efi[1]
>> >>> >> - loader.efi is an interactive prompt which may autoboot, or a
>> >>> >> "boot
>> >>> >> kernelImg" command can be used to load the actual kernel
>> >>> >> - The kernel is loaded as an ELF through helper functions. The
>> >>> >> command_boot[2] function drives this:
>> >>> >>   - In brief, through calls go through:
>> >>> >>     command_boot -> mod_loadkld -> file_load ->
>> >>> >> file_formats[i]->l_load (actually the loadfile function in
>> >>> >> load_elf.c[3])
>> >>> >>   - The loadfile function parses the program and section headers of
>> >>> >> the ELF file (through more function detours that are not really
>> >>> >> important)
>> >>> >>   - Once the ELF has been loaded at the correct entry_addr that it
>> >>> >> expects to be loaded at in memory, the l_exec[4] function is
>> >>> >> called,
>> >>> >> which is actually elf64_exec in elf64_freebsd.c[5], at which
>> >>> >> hopefully
>> >>> >> through trampolining magic, the control flow will transfer to the
>> >>> >> kernel or ELF module
>> >>> >> What this means for RTEMS if we go with gnu-efi is essentially 2
>> >>> >> options, given that the objcopy method of converting from ELF->PE
>> >>> >> requires the ELF to be a position-independent shared library:
>> >>> >> - Using -fPIC to compile all of RTEMS, including the RTEMS user's
>> >>> >> application code. This way we'd have librtemsbso.so,
>> >>> >> librtemscpu.so,
>> >>> >> etc. which would then be linked into user_app.c through -fPIC and
>> >>> >> -shared flags still, creating one singular hello.so, which can then
>> >>> >> finally be converted into hello.efi and put on a FAT filesystem and
>> >>> >> booted. This seems doable, but I'm fairly concerned about it
>> >>> >> further
>> >>> >> complicating our build system and likely being quite singular in
>> >>> >> its
>> >>> >> focus on EFI.
>> >>> > I'm using PIC on the Deos BSP. RTEMS is still a .a and exes are
>> >>> > linked
>> >>> > with
>> >>> > our static libraries and Deos .so.
>> >>> > system
>> >>> > changes.
>> >>> > note that thread local storage is different on i386 with and without
>> >>> > PIC.
>> >>> >> - The FreeBSD way of a (loader.efi) and a hello.exe (ELF64) put on
>> >>> >> possibly the same partition on the FAT filesystem required for UEFI
>> >>> >> application images anyway. The loader.efi can find the hello.exe
>> >>> >> file
>> >>> >> through perhaps a config file it can read or by having a magic-name
>> >>> >> like rtems.exe or something. This effectively means we need an ELF
>> >>> >> dynamic linker / loader (akin to ld.so) within RTEMS' source. I
>> >>> >> think
>> >>> >> using FreeBSD's code for this should be fine. One added benefit of
>> >>> >> this method is that librtems* and user applications remain as
>> >>> >> ELF64s,
>> >>> >> which in the future could also be used with Multiboot with a
>> >>> >> slightly
>> >>> >> modified "loader" (i.e. one which generates the apt Multiboot magic
>> >>> >> header, and boots the PC from 32-bit protected mode to 64-bit long
>> >>> >> mode).
>> >>> >> I prefer the latter approach personally. If both of these seem too
>> >>> >> complicated, we can of course go back to considering generating the
>> >>> >> PE
>> >>> >> header format in ASM the way Linux distros use EFISTUB and the code
>> >>> >> Chris shared (as I mentioned in my original blog post) for wimboot.
>> >>> >> Those approaches may be significantly simpler in a sense, but may
>> >>> >> limit how we use UEFI Services - I'm not sure about the details of
>> >>> >> this yet - I can investigate if y'all aren't fond of the option I
>> >>> >> laid
>> >>> >> down above.
>> >>> >> Let me know!
>> >>> >> [1]
>> >>> >> https://www.freebsd.org/cgi/man.cgi?query=loader&apropos=0&sektion=8&manpath=FreeBSD+11.1-RELEASE+and+Ports&arch=default&format=html
>> >>> >> [2]
>> >>> >> https://github.com/freebsd/freebsd/blob/433bd38e3a0349f9f89f9d54594172c75b002b74/stand/common/boot.c#L53
>> >>> >> [3]
>> >>> >> https://github.com/freebsd/freebsd/blob/d8596f6f687a64b994b065f3058155405dfc39db/stand/common/load_elf.c#L150
>> >>> >> [4]
>> >>> >> https://github.com/freebsd/freebsd/blob/433bd38e3a0349f9f89f9d54594172c75b002b74/stand/common/boot.c#L107
>> >>> >> [5]
>> >>> >> https://github.com/freebsd/freebsd/blob/d8596f6f687a64b994b065f3058155405dfc39db/stand/efi/loader/arch/amd64/elf64_freebsd.c#L93
>> >>> >> On Sun, May 20, 2018 at 10:52 PM, Joel Sherrill <joel at rtems.org>
>> >>> >> wrote:
>> >>> >> > On Sun, May 20, 2018, 12:10 PM Amaan Cheval
>> >>> >> > wrote:
>> >>> >> >> On Sat, May 19, 2018 at 6:51 PM, Gedare Bloom <gedare at rtems.org>
>> >>> >> >> wrote:
>> >>> >> >> > On Fri, May 18, 2018 at 5:53 PM, Joel Sherrill
>> >>> >> >> > <joel at rtems.org>
>> >>> >> >> > wrote:
>> >>> >> >> >> On Fri, May 18, 2018 at 3:24 PM, Amaan Cheval
>> >>> >> >> >> wrote:
>> >>> >> >> >>> Hi everyone!
>> >>> >> >> >>> I've written a quick blog post summarizing the options I've
>> >>> >> >> >>> considered
>> >>> >> >> >>> to make the x86_64 port work with UEFI firmware - the
>> >>> >> >> >>> primary
>> >>> >> >> >>> winner
>> >>> >> >> >>> seems to be in my eyes to use "gnu-efi" and to add support
>> >>> >> >> >>> for
>> >>> >> >> >>> the
>> >>> >> >> >>> target "pei-x86-64" (aliased to "efi-app-x86_64") to
>> >>> >> >> >>> "x86_64-rtems5-objcopy" in binutils. I've submitted a patch
>> >>> >> >> >>> for
>> >>> >> >> >>> this
>> >>> >> >> >>> here[1].
>> >>> >> >> >> That patch is quite simple so shouldn't be a problem if this
>> >>> >> >> >> is
>> >>> >> >> >> the
>> >>> >> >> >> direction
>> >>> >> >> >> that gets consensus.
>> >>> >> >> >>> The blog post is here:
>> >>> >> >> >>> https://blog.whatthedude.com/post/uefi-app-options/
>> >>> >> >> >>> I'd appreciate all feedback (and please do let me know if I
>> >>> >> >> >>> haven't
>> >>> >> >> >>> provided enough context)!
>> >>> >> >> >>> Specifically, some concerns I'd like to discuss are:
>> >>> >> >> >>> - Does everyone agree with me on choosing gnu-efi + objcopy
>> >>> >> >> >>> as
>> >>> >> >> >>> our
>> >>> >> >> >>> method of choice?
>> >>> >> >> >> Does using gnu-efi add code that runs on the target? Can you
>> >>> >> >> >> point
>> >>> >> >> >> us to the files, if so.
>> >>> >> >> Sure. The files would run on the target, yes. These are the ones
>> >>> >> >> listed here (as linked to in my blog post, perhaps without
>> >>> >> >> sufficient
>> >>> >> >> emphasis):
>> >>> >> >> https://wiki.osdev.org/UEFI#Developing_with_GNU-EFI
>> >>> >> >> >> Can you tell which approach FreeBSD takes?
>> >>> >> >> FreeBSD takes the gnu-efi approach I see as the "winner" here
>> >>> >> >> (also
>> >>> >> >> a
>> >>> >> >> link in the post):
>> >>> >> >> https://github.com/freebsd/freebsd/blob/996b0b6d81cf31cd8d58af5d8b45f0b4945d960d/stand/efi/loader/Makefile#L98-L1
>> >>> >> > This is (no surprise) appropriately licensed and IMO the winning
>> >>> >> > solution.
>> >>> >> > Knowing it is what FreeBSD does makes it an easy choice.
>> >>> >> > A comment in the readme mentions there is a i386 version of this
>> >>> >> > code
>> >>> >> > so
>> >>> >> > that could be used to let pc386 boot from UEFI.
>> >>> >> >> >>> - How do we integrate gnu-efi into our build process? A part
>> >>> >> >> >>> of
>> >>> >> >> >>> the
>> >>> >> >> >>> RSB, making sure the path to the libraries are in an
>> >>> >> >> >>> exported
>> >>> >> >> >>> variable? Or perhaps a part of the RTEMS kernel itself if
>> >>> >> >> >>> the
>> >>> >> >> >>> licenses
>> >>> >> >> >>> are compatible (I don't see any on the project[2], only
>> >>> >> >> >>> copyright
>> >>> >> >> >>> notices within the source files of the release versions).
>> >>> >> >> >> GNU-efi would be built like qemu or the device tree compiler
>> >>> >> >> >> would
>> >>> >> >> >> be my guess and x86_64-rtems toolset might add that to the
>> >>> >> >> >> standard
>> >>> >> >> >> set of tools. License on host tools being GPL isn't an issue.
>> >>> >> >> > It appears to be a standard 2-clause BSD released by Intel as
>> >>> >> >> > specified in the README file of gnu-efi.
>> >>> >> >> >>> - Regardless of how we manage UEFI, do we require Multiboot
>> >>> >> >> >>> support
>> >>> >> >> >>> too? Multiboot drops us in a 32-bit protected mode
>> >>> >> >> >>> environment,
>> >>> >> >> >>> whereas 64-bit UEFI firmware will boot us into 64-bit long
>> >>> >> >> >>> mode
>> >>> >> >> >>> this
>> >>> >> >> >>> would mean the kernel would need to support separate
>> >>> >> >> >>> code-paths
>> >>> >> >> >>> for
>> >>> >> >> >>> the 2 if we want to support both methods.
>> >>> >> >> >> That's a good question. For GSoC, I think UEFI is fine and
>> >>> >> >> >> perhaps a
>> >>> >> >> >> ticket
>> >>> >> >> >> under the general "modern PC support" ticket for multiboot
>> >>> >> >> >> support.
>> >>> >> >> >> Unless
>> >>> >> >> >> that eliminates a LOT of PCs.
>> >>> >> >> >> I don't want you to spend all summer getting an image to boot
>> >>> >> >> >> both
>> >>> >> >> >> ways. Personally, I want you to have a working BSP one way.
>> >>> >> >> > +1
>> >>> >> >> Noted, thanks!
>> >>> >> >> >>> [1]
>> >>> >> >> >>> https://www.sourceware.org/ml/binutils/2018-05/msg00197.html
>> >>> >> >> >>> [2] https://sourceforge.net/projects/gnu-efi/
>> >>> >> >> >> --joel
>> >>> >> >> >> _______________________________________________
>> >>> >> >> >> devel mailing list
>> >>> >> >> >> devel at rtems.org
>> >>> >> >> >> http://lists.rtems.org/mailman/listinfo/devel
