[GSOC] CTF generator configuration files
Wed May 30 11:29:58 UTC 2018
On 30/05/18 13:27, Vidushi Vashishth wrote:
> Hi Sebastian!
> Yes I have been working on the documentation. I wrote a blog about the
> the tracing framework use cases a while ago. It can be seen here
> https://vidushivashishth.github.io/Third-post-copy/
> I will write a blog about trace buffer generation which would explain
> all the questions you have posed too. As suggested by Gedare the blog
> posts will somewhat be the first draft of what is to go in the user
> manual. I would appreciate your feedback on the blogpost.
I would highly appreciate if you do this not in a blog. The primary
medium for RTEMS development is this mailing list. Please start with a
skeleton structure for this new stuff in the user manual and send
patches to the mailing list for review.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
