[PATCH] Updating trace buffer configuration
Amaan Cheval amaan.cheval at gmail.com
Wed May 30 13:35:23 UTC 2018
On Wed, May 30, 2018 at 6:33 PM, Vidushi Vashishth <reachvidu at gmail.com> wrote:
> Could you please change the
> struct _Thread_Control
> to
> Thread_Control
> and check if it still works.
> In RTEMS, we use typedefs for structures in general.
> I tried to include the threadq.h header file so that I could use the
> variable Thread_Control instead of _Thread_Control. This header file has the
> following typedef statement:
> typedef struct _Thread_Control Thread_Control;
> However this leads to the following error:
> fileio-wrapper.c:389:31: warning: initialization from incompatible pointer
> type [-Wincompatible-pointer-types]
>    struct Thread_Control* tc = _Thread_Get_executing();
Based on this error, I believe you need to drop the "struct", given
that Thread_Control is the typedef for "struct _Thread_Control".
Minor, but in most other places in RTEMS, I've seen pointers declared
with the asterisk on the variable not on the type ("int *ptr;" instead
of "int* ptr;").
> fileio-wrapper.c:390:32: warning: passing argument 1 of
> '_Thread_Get_priority' from incompatible pointer type
>    return (_Thread_Get_priority(tc) << 8) | tc->Real_priority.priority;
> I had tried this earlier too. So it doesn't work.
> On Wed, May 30, 2018 at 10:59 AM, Sebastian Huber
> <sebastian.huber at embedded-brains.de> wrote:
>> On 29/05/18 17:36, Vidushi Vashishth wrote:
>>>   linkers/rtld-trace-buffer.ini | 5 +++--
>>>   1 file changed, 3 insertions(+), 2 deletions(-)
>>> diff --git a/linkers/rtld-trace-buffer.ini
>>> b/linkers/rtld-trace-buffer.ini
>>> index af9fc31..ee68d55 100644
>>> --- a/linkers/rtld-trace-buffer.ini
>>> +++ b/linkers/rtld-trace-buffer.ini
>>> @@ -26,6 +26,7 @@ buffer-local = " uint8_t* in;"
>>>   header = "#include <stdint.h>"
>>>   header = "#include <rtems.h>"
>>>   header = "#include <rtems/rtems/tasksimpl.h>"
>>> +header = "#include <rtems/score/threadimpl.h>"
>>>     [trace-buffer-tracers]
>>>   code = <<<CODE
>>> @@ -84,8 +85,8 @@ static inline uint32_t __rtld_tbg_executing_id(void)
>>>   static inline uint32_t __rtld_tbg_executing_status(void)
>>>     /* @fixme Add the current CPU for SMP. */
>>> -  struct Thread_Control* tc = _Thread_Get_executing();
>> to
>> Thread_Control
>>> -  return (tc->current_priority << 8) | tc->real_priority;
>>> +  struct _Thread_Control* tc = _Thread_Get_executing();
>>> +  return (_Thread_Get_priority(tc) << 8) | tc->Real_priority.priority;
>>>     static inline uint32_t __rtld_tbg_executing_state(void)
>> Sebastian Huber, embedded brains GmbH
>> Address : Dornierstr. 4, D-82178 Puchheim, Germany
>> Phone   : +49 89 189 47 41-16
>> Fax     : +49 89 189 47 41-09
>> E-Mail  : sebastian.huber at embedded-brains.de
>> PGP     : Public key available on request.
>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
>> devel mailing list
>> devel at rtems.org
> devel mailing list
> devel at rtems.org
