<offllist> Coverage support for tester
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Wed May 30 14:29:57 UTC 2018
On 30 May 2018 at 00:54, Joel Sherrill <joel at rtems.org> wrote:
> On Tue, May 29, 2018 at 11:27 AM, Vijay Kumar Banerjee <
> vijaykumar9597 at gmail.com> wrote:
>> On Tue, 29 May 2018, 20:10 Joel Sherrill, <joel at rtems.org> wrote:
>>> On Mon, May 28, 2018 at 11:08 PM, Chris Johns <chrisj at rtems.org> wrote:
>>>> On 29/5/18 4:26 am, Joel Sherrill wrote:
>>>> > On Mon, May 28, 2018 at 5:43 AM, Vijay Kumar Banerjee <
>>>> > <mailto:vijaykumar9597 at gmail.com>> wrote:
>>>> > Hello,
>>>> > The coverage reports are now showing results.
>>>> > The current branch that holds all the changes is
>>>> > the cov-tester-support branch in my forked repo
>>>> > https://github.com/thelunatic/rtems-tools/tree/cov-tester-support
>>>> > <https://github.com/thelunatic/rtems-tools/tree/cov-tester-
>>>> support>
>>>> > (Please have a look into the code and test it.)
>>>> > It is close to merging (hopefully). These are the issues
>>>> > that would need a fix before it can be merged :
>>>> > 1. I have added some #FIXME in the code (have a look)
>>>> > in coverage script. I have set the value of the targe to be
>>>> > sparc-rtems5, which makes it limited to sparc-rtems5 only. We
>>>> can
>>>> > include the target in the bsp ini file, That would
>>>> > be a quick fix for this.
>>>> > Yes. This needs to be fixed.
>>>> > My hack to add 4 in ObjdumpProcessor.cc needs to be addressed also.
>>>> > I am thinking of adding a method to Target_*.cc to ask for the size
>>>> of an
>>>> > instruction.
>>>> > Then pass it the last instruction. That way we can throw on other
>>>> architectures for
>>>> > now. If Chris solves this with his changes before we try another
>>>> architecture,
>>>> > great.
>>>> > If not, it will be easy to fix.
>>>> What is the overall requirement?
>>> To know the ending address of the function.
>>> Technically there are three pieces of information:
>>> + start address
>>> + end address
>>> + size
>>> If you know two of those, you can compute the third.
>>> I don't care if this comes from DWARF, ELF, or parsing the disassembly.
>>> It just needs to be reliable.
>>> And.. I am not proposing my solution as permanent. Just to keep us
>>> moving. You want to change to an internal disassembler (which
>>> would also need to have the source interspersed) and DWARF. So
>>> this code would go away then.
>>>> What defines the function and so size are attempting to get coverage
>>>> of? What if
>>>> that function calls an inline function and that function is inlined?
>>>> What if
>>>> that inlined function calls another inlined function?
>>> Then it is all inlined. It is done consistently now. I have never seen a
>>> case
>>> where two instances of a method differed as the assembly level. [1]
>>> The actual body of the inlined method is evaluated at each expansion
>>> point.
>>> That is why a few years ago, I pushed hard to reduce the complexity of
>>> inline methods because we got test patch explosion when an inlined method
>>> included complex conditionals.
>>> Similarly, I think it would be helpful to coverage and verification
>>> efforts to
>>> follow the **shudder** MISRA rule which want you to write simple
>>> conditional
>>> expressions rather than compound ones. I have taken to writing code this
>>> way as much as possible. But haven't pushed it as a coding rule.
>>> if (a) {
>>> if (b) {
>>> do x;
>>> Versus
>>> if (a && b) {
>>> do x;
>>> The reason is that the first is easier to analyse coverage on.
>>> [1] We both expect LTO could change this.
>>> [2] ESA did specifically mention this one though. Also in general terms,
>>> an RTEMS Project response to MISRA rules. Which ones we follow,
>>> reject, etc.. But I refuse to adopt hard rules which can't be enforced
>>> by free open source tools.
>>>> The DWARF data provides details about the PC low and PC high of what is
>>>> called
>>>> concrete functions and then it provides the details about inlines.
>>> We don't (currently) report on the inlines as independent methods.
>>>> > 2. coverage used to feed ini file for each symbol to covoar
>>>> > in a loop and store the result in a separate directory
>>>> > for each symbol . Which is needed no more needed as
>>>> > covoar can now process multi sets from a
>>>> > single ini file. I think the results from covoar should be
>>>> > store in a separate directory for each symbol
>>>> > example :- score/
>>>> > A bit of history will help here. Originally covoar was run against a
>>>> single set of
>>>> > code by the scripting framework. We would do coverage on either "core
>>>> parts"
>>>> > or "developmental" (e.g. nearly all non-networked code). The
>>>> optimization was
>>>> > either at -O2 or -Os. So there were four coverage variants.
>>>> > Turned out that when we added something to "all", the percentage
>>>> would drop
>>>> > and reflect badly on the rest of the code. I remember adding the
>>>> dosfs and
>>>> > the coverage dropped almost 20 percent.
>>>> > This led to the idea that we should report on a per
>>>> directory/subsystem basis.
>>>> > The score, rtems, posix, sapi, and libcsupport should have high
>>>> coverage now
>>>> > and the reports should reflect that independent of whether the dosfs
>>>> needs a
>>>> > lot more tests.
>>>> > Before each directory/subsystem required a completely separate run of
>>>> covoar.
>>>> > If we are headed to a solution where one analysis run of covoar
>>>> generates different
>>>> > reports, that should speed up the processing time a lot!
>>>> > The other issue is what should the top directory look like/contain
>>>> when a single
>>>> > run produces multiple subsystem reports. Seems like we would need at
>>>> least a
>>>> > top level html and text file.
>>>> > 3. currently we are using the leon3-qemu-cov as the bsp.
>>>> > Are we going to have two ini file for each bsp ? ( one
>>>> without coverage
>>>> > and one with coverage support)
>>>> > Earlier the approach was to include a section 'coverage'
>>>> > to the bsp ini to put the values we needed for coverage.
>>>> > I think that approach would be more "convenient" for the user.
>>>> > This was something Chris suggested. I think it was to avoid adding to
>>>> > the bsp ini file until the code was closer to merging.
>>>> > Chris.. what do you think? Long term, a section would be nice.
>>>> Sorry I cannot remember without looking it up and I am currently buried
>>>> in
>>>> family issues.
>>> OK. Having the Python scripting loop over the sets or covoar looping
>>> over them
>>> is an open issue. Historically, looping over desired symbol sets was
>>> outside
>>> covoar. So looping inside covoar may take some work.
>> covoar can already loop over the
>> sets it seems, which is implemented
>> in DesiredSymbols. But it stores all the
>> reports generated from into the same directory.
> If there is an index that makes its possible to navigate through the
> different "subsystems", then that's the key thing. You don't want
> to think score is poorly covered due to dosfs.
>> P.S:Sorry for the previous mail with no message
>>> --joel
>>>> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180530/5841c37a/attachment-0001.html>
