[PATCH] Generate coverage analysis Report
thelunatic
vijaykumar9597 at gmail.com
Wed May 30 17:00:11 UTC 2018
+ Add script to run covoar and generate an html report from
the output generated from covoar
+ Add symbol-sets ini file for library addresses of the symbol-sets
+ tester/rt/test : Add options for running coverage
Co-author : Cillian O'Donnel <cpodonnell8 at gmail.com>
tester/rt/coverage.py | 380 ++++++++++++++++++++++++++
tester/rt/test.py | 36 ++-
tester/rtems/testing/bsps/leon3-qemu-cov.ini | 3 +-
tester/rtems/testing/coverage/symbol-sets.ini | 36 +++
tester/rtems/testing/qemu.cfg | 4 +-
5 files changed, 447 insertions(+), 12 deletions(-)
create mode 100644 tester/rt/coverage.py
create mode 100644 tester/rtems/testing/coverage/symbol-sets.ini
diff --git a/tester/rt/coverage.py b/tester/rt/coverage.py
new file mode 100644
index 0000000..38dcce6
--- /dev/null
+++ b/tester/rt/coverage.py
@@ -0,0 +1,380 @@
+# RTEMS Tools Project (http://www.rtems.org/)
+# Copyright 2014 Krzysztof Miesowicz (krzysztof.miesowicz at gmail.com)
+# All rights reserved.
+# This file is part of the RTEMS Tools package in 'rtems-tools'.
+# Redistribution and use in source and binary forms, with or without
+# modification, are permitted provided that the following conditions are met:
+# 1. Redistributions of source code must retain the above copyright notice,
+# this list of conditions and the following disclaimer.
+# 2. Redistributions in binary form must reproduce the above copyright notice,
+# this list of conditions and the following disclaimer in the documentation
+# and/or other materials provided with the distribution.
+# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS 'AS IS'
+# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE
+# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE
+# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
+# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
+# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS
+# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN
+# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE)
+# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE
+# POSSIBILITY OF SUCH DAMAGE.
+from rtemstoolkit import error
+from rtemstoolkit import path
+from rtemstoolkit import log
+from rtemstoolkit import execute
+from rtemstoolkit import macros
+from datetime import datetime
+from . import options
+import shutil
+import os
+try:
+ import configparser
+except:
+ import ConfigParser as configparser
+class summary:
+ def __init__(self, p_summary_dir):
+ self.summary_file_path = path.join(p_summary_dir, 'summary.txt')
+ self.index_file_path = path.join(p_summary_dir, 'index.html')
+ self.bytes_analyzed = 0
+ self.bytes_not_executed = 0
+ self.percentage_executed = 0.0
+ self.percentage_not_executed = 100.0
+ self.ranges_uncovered = 0
+ self.branches_uncovered = 0
+ self.branches_total = 0
+ self.branches_always_taken = 0
+ self.branches_never_taken = 0
+ self.percentage_branches_covered = 0.0
+ self.is_failure = False
+ def parse(self):
+ if(not path.exists(self.summary_file_path)):
+ log.notice('summary file %s does not exist!' % (self.summary_file_path))
+ self.is_failure = True
+ return
+ with open(self.summary_file_path,'r') as summary_file:
+ self.bytes_analyzed = self._get_next_with_colon(summary_file)
+ self.bytes_not_executed = self._get_next_with_colon(summary_file)
+ self.percentage_executed = self._get_next_with_colon(summary_file)
+ self.percentage_not_executed = self._get_next_with_colon(summary_file)
+ self.ranges_uncovered = self._get_next_with_colon(summary_file)
+ self.branches_total = self._get_next_with_colon(summary_file)
+ self.branches_uncovered = self._get_next_with_colon(summary_file)
+ self.branches_always_taken = self._get_next_without_colon(summary_file)
+ self.branches_never_taken = self._get_next_without_colon(summary_file)
+ if len(self.branches_uncovered) > 0 and len(self.branches_total) > 0:
+ self.percentage_branches_covered = \
+ 1 - (float(self.branches_uncovered) / float(self.branches_total))
+ else:
+ return
+ def _get_next_with_colon(self, summary_file):
+ line = summary_file.readline()
+ if ':' in line:
+ return line.split(':')[1].strip()
+ else:
+ return ''
+ def _get_next_without_colon(self, summary_file):
+ return line.strip().split(' ')[0]
+class report_gen_html:
+ def __init__(self, p_symbol_sets_list, build_dir, rtdir):
+ self.symbol_sets_list = ['score']
+ self.build_dir = build_dir
+ self.partial_reports_files = list(["index.html", "summary.txt"])
+ self.number_of_columns = 1
+ self.covoar_src_path = path.join(rtdir, 'covoar')
+ def _find_partial_reports(self):
+ partial_reports = {}
+ for symbol_set in self.symbol_sets_list:
+ set_summary = summary(path.join(self.build_dir, "coverage",
+ symbol_set))
+ set_summary.parse()
+ partial_reports[symbol_set] = set_summary
+ return partial_reports
+ def _prepare_head_section(self):
+ head_section = '''
+ <head>
+ <title>RTEMS coverage report</title>
+ <style type="text/css">
+ progress[value] {
+ -webkit-appearance: none;
+ appearance: none;
+ width: 150px;
+ height: 15px;
+ </style>
+ </head>'''
+ return head_section
+ def _prepare_index_content(self, partial_reports):
+ header = "<h1> RTEMS coverage analysis report </h1>"
+ header += "<h3>Coverage reports by symbols sets:</h3>"
+ table = "<table>"
+ table += self._header_row()
+ for symbol_set in partial_reports:
+ table += self._row(symbol_set, partial_reports[symbol_set])
+ table += "</table> </br>"
+ timestamp = "Analysis performed on " + datetime.now().ctime()
+ return "<body>\n" + header + table + timestamp + "\n</body>"
+ def _row(self, symbol_set, summary):
+ row = "<tr>"
+ row += "<td>" + symbol_set + "</td>"
+ if summary.is_failure:
+ row += ' <td colspan="' + str(self.number_of_columns-1) \
+ + '" style="background-color:red">FAILURE</td>'
+ else:
+ row += " <td>" + self._link(summary.index_file_path,"Index") \
+ + "</td>"
+ row += " <td>" + self._link(summary.summary_file_path,"Summary") \
+ + "</td>"
+ row += " <td>" + summary.bytes_analyzed + "</td>"
+ row += " <td>" + summary.bytes_not_executed + "</td>"
+ row += " <td>" + summary.ranges_uncovered + "</td>"
+ row += " <td>" + summary.percentage_executed + "%</td>"
+ row += " <td>" + summary.percentage_not_executed + "%</td>"
+ row += ' <td><progress value="' + summary.percentage_executed \
+ + '" max="100"></progress></td>'
+ row += " <td>" + summary.branches_uncovered + "</td>"
+ row += " <td>" + summary.branches_total + "</td>"
+ row += " <td> {:.3%} </td>".format(summary.percentage_branches_covered)
+ row += ' <td><progress value="{:.3}" max="100"></progress></td>'.format(100*summary.percentage_branches_covered)
+ row += "</tr>\n"
+ return row
+ def _header_row(self):
+ row = "<tr>"
+ row += "<th> Symbols set name </th>"
+ row += "<th> Index file </th>"
+ row += "<th> Summary file </th>"
+ row += "<th> Bytes analyzed </th>"
+ row += "<th> Bytes not executed </th>"
+ row += "<th> Uncovered ranges </th>"
+ row += "<th> Percentage covered </th>"
+ row += "<th> Percentage uncovered </th>"
+ row += "<th> Instruction coverage </th>"
+ row += "<th> Branches uncovered </th>"
+ row += "<th> Branches total </th>"
+ row += "<th> Branches covered percentage </th>"
+ row += "<th> Branches coverage </th>"
+ row += "</tr>\n"
+ self.number_of_columns = row.count('<th>')
+ return row
+ def _link(self, address, text):
+ return '<a href="' + address + '">' + text + '</a>'
+ def _create_index_file(self, head_section, content):
+ with open(path.join(self.build_dir,"report.html"),'w') as f:
+ f.write(head_section)
+ f.write(content)
+ def generate(self):
+ partial_reports = self._find_partial_reports()
+ head_section = self._prepare_head_section()
+ index_content = self._prepare_index_content(partial_reports)
+ self._create_index_file(head_section,index_content)
+ def add_covoar_src_path(self):
+ table_js_path = path.join(self.covoar_src_path, 'table.js')
+ covoar_css_path = path.join(self.covoar_src_path, 'covoar.css')
+ symbol_set_dir = path.join(self.build_dir, "coverage", symbol_set)
+ html_files = os.listdir(symbol_set_dir)
+ for html_file in html_files:
+ html_file = path.join(symbol_set_dir, html_file)
+ if path.exists(html_file) and 'html' in html_file:
+ with open(html_file, 'r') as f:
+ file_data = f.read()
+ file_data = file_data.replace('table.js', table_js_path)
+ file_data = file_data.replace('covoar.css',
+ covoar_css_path)
+ with open(html_file, 'w') as f:
+ f.write(file_data)
+class build_path_generator(object):
+ Generates the build path from the path to executables
+ def __init__(self, executables, target):
+ self.executables = executables
+ self.target = target
+ def run(self):
+ build_path = '/'
+ Path = self.executables[0].split('/')
+ for P in Path:
+ if P == self.target:
+ break;
+ else:
+ build_path = path.join(build_path, P)
+ return build_path
+class symbol_parser(object):
+ Parse the symbol sets ini and create custom ini file for covoar
+ def __init__(self, symbol_config_path,
+ symbol_select_path, coverage_arg, build_dir):
+ self.symbol_select_file = symbol_select_path
+ self.symbol_file = symbol_config_path
+ self.symbol_sets = {}
+ self.cov_arg = coverage_arg
+ self.ssets = []
+ def parse(self):
+ config = configparser.ConfigParser()
+ try:
+ config.read(self.symbol_file)
+ if self.cov_arg:
+ self.ssets = self.cov_arg.split(',')
+ else:
+ self.ssets = config.get('symbol-sets', 'sets').split(',')
+ self.ssets = [ sset.encode('utf-8') for sset in self.ssets]
+ for sset in self.ssets:
+ lib = path.join(self.build_dir,
+ config.get('libraries', sset))
+ self.symbol_sets[sset] = lib.encode('utf-8')
+ except:
+ raise error.general('Symbol set parsing failed')
+ def _write_ini(self):
+ try:
+ sets = ', '.join(self.symbol_sets.keys())
+ config.add_section('symbol-sets')
+ config.set('symbol-sets', 'sets', sets)
+ for key in self.symbol_sets.keys():
+ config.add_section(key)
+ config.set(key, 'libraries', self.symbol_sets[key])
+ with open(self.symbol_select_file, 'w') as conf:
+ config.write(conf)
+ except:
+ raise error.general('write failed')
+ def run(self):
+ self.parse()
+ self._write_ini()
+class covoar(object):
+ Covoar runner
+ def __init__(self, base_result_dir, config_dir, executables, explanations_txt):
+ self.base_result_dir = base_result_dir
+ self.config_dir = config_dir
+ self.executables = ' '.join(executables)
+ self.explanations_txt = explanations_txt
+ self.project_name = 'RTEMS-5'
+ def run(self, set_name, symbol_file):
+ covoar_result_dir = path.join(self.base_result_dir, set_name)
+ if (not path.exists(covoar_result_dir)):
+ path.mkdir(covoar_result_dir)
+ if (not path.exists(symbol_file)):
+ raise error.general('symbol set file: coverage %s was not created for covoar, skipping %s'% (symbol_file, set_name))
+ command = ('covoar -S ' + symbol_file
+ + ' -O ' + covoar_result_dir
+ + ' -E ' + self.explanations_txt
+ + ' -p ' + self.project_name + ' ' + self.executables)
+ log.notice('Running covoar for %s' % (set_name))
+ print( 'covoar results directory:\n' + covoar_result_dir )
+ executor = execute.execute(verbose = True, output = self.output_handler)
+ exit_code = executor.shell(command, cwd=os.getcwd())
+ if (exit_code[0] != 0):
+ raise error.general('covoar failure exit code: %d' % (exit_code[0]))
+ log.notice('Coverage run for %s finished successfully.' % (set_name))
+ log.notice('-----------------------------------------------')
+ def output_handler(self, text):
+ log.notice('%s' % (text))
+class coverage_run(object):
+ Coverage analysis support for rtems-test
+ def __init__(self, p_macros, coverage_arg, target):
+ Constructor
+ self.macros = p_macros
+ self.build_dir = self.macros['_cwd']
+ self.explanations_txt = self.macros.expand(self.macros['cov_explanations'])
+ self.test_dir = path.join(self.build_dir, 'coverage')
+ if (not path.exists(self.test_dir)):
+ path.mkdir(self.test_dir)
+ self.rtdir = path.abspath(self.macros['_rtdir'])
+ self.rtscripts = self.macros.expand(self.macros['_rtscripts'])
+ self.coverage_config_path = path.join(self.rtscripts, 'coverage')
+ self.symbol_config_path = path.join(self.coverage_config_path,
+ 'symbol-sets.ini')
+ self.symbol_select_path = path.join(self.coverage_config_path,
+ 'symbol-select.ini')
+ self.executables = None
+ self.symbol_sets = []
+ self.no_clean = int(self.macros['_no_clean'])
+ self.report_format = self.macros['cov_report_format']
+ self.coverage_arg = coverage_arg
+ def run(self):
+ try:
+ if self.executables is None:
+ raise error.general('no test executables provided.')
+ build_dir = build_path_generator(self.executables, self.target).run()
+ parser = symbol_parser(self.symbol_config_path,
+ self.symbol_select_path,
+ self.coverage_arg,
+ build_dir)
+ parser.run()
+ covoar_runner = covoar(self.test_dir, self.symbol_select_path,
+ self.executables, self.explanations_txt)
+ covoar_runner.run('score', self.symbol_select_path)
+ self._generate_reports();
+ self._summarize();
+ finally:
+ self._cleanup();
+ def _generate_reports(self):
+ log.notice('Generating reports')
+ if self.report_format == 'html':
+ report = report_gen_html(self.symbol_sets,
+ self.build_dir,
+ self.rtdir)
+ report.generate()
+ report.add_covoar_src_path()
+ def _cleanup(self):
+ if not self.no_clean:
+ log.notice('***Cleaning tempfiles***')
+ for exe in self.executables:
+ trace_file = exe + '.cov'
+ if path.exists(trace_file):
+ os.remove(trace_file)
+ def _summarize(self):
+ log.notice('Coverage analysis finished. You can find results in %s' % (self.build_dir))
diff --git a/tester/rt/test.py b/tester/rt/test.py
index f4d9b5c..cabec7b 100644
--- a/tester/rt/test.py
+++ b/tester/rt/test.py
@@ -48,12 +48,14 @@ from rtemstoolkit import mailer
from rtemstoolkit import reraise
from rtemstoolkit import stacktraces
from rtemstoolkit import version
+from rtemstoolkit import check
from . import bsps
from . import config
from . import console
from . import report
+from . import coverage
class log_capture(object):
def __init__(self):
@@ -147,7 +149,7 @@ class test_run(object):
def run(self):
self.thread = threading.Thread(target = self.runner,
- name = 'test[%s]' % path.basename(self.executable))
+ name = 'test[%s]' % path.basename(self.executable))
self.thread.start()
def is_alive(self):
@@ -214,6 +216,11 @@ def killall(tests):
for test in tests:
test.kill()
+def coverage_run(opts, coverage, executables):
+ coverage.executables = executables
+ coverage.run()
def run(command_path = None):
import sys
tests = []
@@ -221,15 +228,16 @@ def run(command_path = None):
opts = None
default_exefilter = '*.exe'
try:
- optargs = { '--rtems-tools': 'The path to the RTEMS tools',
- '--rtems-bsp': 'The RTEMS BSP to run the test on',
- '--user-config': 'Path to your local user configuration INI file',
- '--report-mode': 'Reporting modes, failures (default),all,none',
- '--list-bsps': 'List the supported BSPs',
- '--debug-trace': 'Debug trace based on specific flags',
- '--filter': 'Glob that executables must match to run (default: ' +
+ optargs = { '--rtems-tools': 'The path to the RTEMS tools',
+ '--rtems-bsp': 'The RTEMS BSP to run the test on',
+ '--user-config': 'Path to your local user configuration INI file',
+ '--report-mode': 'Reporting modes, failures (default),all,none',
+ '--list-bsps': 'List the supported BSPs',
+ '--debug-trace': 'Debug trace based on specific flags',
+ '--filter': 'Glob that executables must match to run (default: ' +
default_exefilter + ')',
- '--stacktrace': 'Dump a stack trace on a user termination (^C)' }
+ '--stacktrace': 'Dump a stack trace on a user termination (^C)',
+ '--coverage': 'Perform coverage analysis of test exectuables.'}
mailer.append_options(optargs)
opts = options.load(sys.argv,
optargs = optargs,
@@ -279,6 +287,14 @@ def run(command_path = None):
raise error.general('RTEMS BSP not provided or an invalid option')
bsp = config.load(bsp[1], opts)
bsp_config = opts.defaults.expand(opts.defaults['tester'])
+ coverage_enabled = opts.find_arg('--coverage')
+ if coverage_enabled:
+ if len(coverage_enabled) == 2:
+ coverage_runner = coverage.coverage_run(opts.defaults,
+ coverage_enabled[1],
+ opts.defaults['target'])
+ else:
+ coverage_runner = coverage.coverage_run(opts.defaults, 0)
report_mode = opts.find_arg('--report-mode')
if report_mode:
if report_mode[1] != 'failures' and \
@@ -365,6 +381,8 @@ def run(command_path = None):
reports.failures(),
'Log', '===', ''] + output.get()
mail.send(to_addr, subject, os.linesep.join(body))
+ coverage_run(opts, coverage_runner, executables)
except error.general as gerr:
print(gerr)
diff --git a/tester/rtems/testing/bsps/leon3-qemu-cov.ini b/tester/rtems/testing/bsps/leon3-qemu-cov.ini
index 6b5e7e6..2f89117 100644
--- a/tester/rtems/testing/bsps/leon3-qemu-cov.ini
+++ b/tester/rtems/testing/bsps/leon3-qemu-cov.ini
@@ -31,9 +31,10 @@
# The Leon 3 QEMU BSP
-[leon3-qemu]
+[leon3-qemu-cov]
bsp = leon3-qemu
arch = sparc
+target = sparc-rtems5
tester = %{_rtscripts}/qemu.cfg
bsp_qemu_opts = %{qemu_opts_base} -M leon3_generic
bsp_qemu_cov_opts = -exec-trace %{test_executable}.cov
diff --git a/tester/rtems/testing/coverage/symbol-sets.ini b/tester/rtems/testing/coverage/symbol-sets.ini
index 0000000..a2ec7bc
--- /dev/null
+++ b/tester/rtems/testing/coverage/symbol-sets.ini
@@ -0,0 +1,36 @@
+# Copyright 2018 Chris Johns (chrisj at rtems.org)
+# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
+[symbol-sets]
+sets = score,rtems
+[libraries]
+score = @BUILD-TARGET@/c/@BSP@/cpukit/score/libscore.a
+rtems = @BUILD-TARGET@/c/@BSP@/cpukit/rtems/librtems.a
diff --git a/tester/rtems/testing/qemu.cfg b/tester/rtems/testing/qemu.cfg
index bfcd2f5..52a3752 100644
--- a/tester/rtems/testing/qemu.cfg
+++ b/tester/rtems/testing/qemu.cfg
@@ -51,8 +51,8 @@
# Qemu common option patterns.
-#%define qemu_opts_base -no-reboot -monitor none -serial stdio -nographic
-%define qemu_opts_base -no-reboot -serial null -serial mon:stdio -nographic
+%define qemu_opts_base -no-reboot -monitor none -serial stdio -nographic
+#%define qemu_opts_base -no-reboot -serial null -serial mon:stdio -nographic
%define qemu_opts_no_net -net none
2.14.3
