[PATCH 1/1] Fix and extend error message in posix timer test
Joel Sherrill
joel at rtems.org
Wed May 30 17:44:23 UTC 2018
On Wed, May 30, 2018 at 10:33 AM, Gedare Bloom <gedare at rtems.org> wrote:
> This looks fine to me, and I'll commit after I can test it. (We
> currently don't apply any significance to --signed-off-by in RTEMS
> Project.) I'm investigating your inquiry on the 0/1 cover letter.
I am ok with it if it tests OK with you.
> On Tue, May 15, 2018 at 5:21 AM, Martin Erik Werner
> <martinerikwerner.aac at gmail.com> wrote:
> > _Timespec_Equal_to() does not set errno, hence avoid using perror(),
> > instead use fprintf() to stderr, and extend the error message to provide
> > information about what the error is (measured timer value after
> > re-arming is not equal to the configured interval), and how large of a
> > difference was measured.
> > Signed-off-by: Martin Erik Werner <martin.werner at aacmicrotec.com>
> > testsuites/psxtests/psxtimer01/psxtimer.c | 14 ++++++++++++--
> > 1 file changed, 12 insertions(+), 2 deletions(-)
> > diff --git a/testsuites/psxtests/psxtimer01/psxtimer.c
> b/testsuites/psxtests/psxtimer01/psxtimer.c
> > index 032e9f8e6c..6ec049ac54 100644
> > --- a/testsuites/psxtests/psxtimer01/psxtimer.c
> > +++ b/testsuites/psxtests/psxtimer01/psxtimer.c
> > @@ -143,7 +143,12 @@ void * task_a (void *arg)
> > rtems_test_exit(0);
> > if (! _Timespec_Equal_to( &timerdata.it_value, &my_period )){
> > - perror ("Error in Task A timer_gettime\n");
> > + fprintf(
> > + stderr, "Error in Task A timer_gettime:\n"
> > + " re-armed timer: %" PRIdtime_t ":%ld does not match
> interval: %" PRIdtime_t ":%ld\n",
> > + timerdata.it_value.tv_sec, timerdata.it_value.tv_nsec,
> > + my_period.tv_sec, my_period.tv_nsec
> > clock = time(NULL);
> > printf("Executing task A with count = %2i %s", params->count,
> ctime(&clock));
> > @@ -291,7 +296,12 @@ void * task_c (void *arg)
> > rtems_test_exit(0);
> > if (! _Timespec_Equal_to( &timerdata.it_value, &my_period) ){
> > - perror ("Error in Task C timer_gettime\n");
> > + fprintf(
> > pthread_mutex_lock (&data.mutex);
> > while (data.updated == FALSE) {
> > 2.11.0
> > devel mailing list
> > devel at rtems.org
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180530/b505bd9b/attachment.html>
