[PATCH] Generate coverage analysis Report
Cillian O'Donnell
cpodonnell8 at gmail.com
Wed May 30 17:58:04 UTC 2018
On Wed, 30 May 2018, 18:54 Vijay Kumar Banerjee, <vijaykumar9597 at gmail.com>
wrote:
> On 30 May 2018 at 22:51, Gedare Bloom <gedare at rtems.org> wrote:
>> Please provide your name in your commits (git config --user.name "My
>> Name") that you submit.
>> OK Noted :)
>> The first line of this commit, and therefore the email subject, is
>> overly vague. Provide a slightly more specific description.
> On Wed, May 30, 2018 at 1:00 PM, thelunatic <vijaykumar9597 at gmail.com>
>> wrote:
>> > + Add script to run covoar and generate an html report from
>> > the output generated from covoar
>> > + Add symbol-sets ini file for library addresses of the symbol-sets
>> > + tester/rt/test : Add options for running coverage
>> I'd rather see a narrative paragraph than this list of + bullet items.
>> Are all of these changes required to run the report? Should they be
>> broken into smaller commits that are logically related but separately
>> reviewable and commited?
>> OK, I will write in a descriptive paragraph.
> These changes are all needed to run coverage.
>> > Co-author : Cillian O'Donnel <cpodonnell8 at gmail.com>
>> I don't know what Co-Author should mean. I would prefer to receive
>> separate commits/patches for contributions made by different people if
>> that is possible.
>> Plese refer below...
>> > tester/rt/coverage.py | 380
>> > tester/rt/test.py | 36 ++-
>> > tester/rtems/testing/bsps/leon3-qemu-cov.ini | 3 +-
>> > tester/rtems/testing/coverage/symbol-sets.ini | 36 +++
>> > tester/rtems/testing/qemu.cfg | 4 +-
>> > 5 files changed, 447 insertions(+), 12 deletions(-)
>> > create mode 100644 tester/rt/coverage.py
>> > create mode 100644 tester/rtems/testing/coverage/symbol-sets.ini
>> > diff --git a/tester/rt/coverage.py b/tester/rt/coverage.py
>> > new file mode 100644
>> > index 0000000..38dcce6
>> > --- /dev/null
>> > +++ b/tester/rt/coverage.py
>> > @@ -0,0 +1,380 @@
>> > +# RTEMS Tools Project (http://www.rtems.org/)
>> > +# Copyright 2014 Krzysztof Miesowicz (krzysztof.miesowicz at gmail.com)
>> Is this Krzysztof's code? if so, it should be added as a commit with
>> him as the --author="" field of git-commit option.
>> Actually this script has undergone a lot of updates.
> It doesn't even work the same way it used to. I am uncertain
> about the portions of the code that are written by him and still in
> the script. Basically I left the copyright notice untouched and
> let it be there because I am unsure of what to include there.
> Same is true in case of Cillian. I don't really know how much
> of Code is authored by him.
> It surely isn't the proper way to add him as the co-author in
> the log but that seemed like the only way to include him.
>> > +# All rights reserved.
>> > +# This file is part of the RTEMS Tools package in 'rtems-tools'.
>> > +# Redistribution and use in source and binary forms, with or without
>> > +# modification, are permitted provided that the following conditions
>> are met:
>> > +# 1. Redistributions of source code must retain the above copyright
>> notice,
>> > +# this list of conditions and the following disclaimer.
>> > +# 2. Redistributions in binary form must reproduce the above copyright
>> notice,
>> > +# this list of conditions and the following disclaimer in the
>> documentation
>> > +# and/or other materials provided with the distribution.
>> > +# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
>> 'AS IS'
>> > +# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED
>> TO, THE
>> > +# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
>> PURPOSE
>> > +# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR
>> CONTRIBUTORS BE
>> > +# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
>> > +# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
>> > +# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
>> BUSINESS
>> > +# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER
>> IN
>> > +# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
>> OTHERWISE)
>> > +# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED
>> OF THE
>> > +# POSSIBILITY OF SUCH DAMAGE.
>> > +from rtemstoolkit import error
>> > +from rtemstoolkit import path
>> > +from rtemstoolkit import log
>> > +from rtemstoolkit import execute
>> > +from rtemstoolkit import macros
>> > +from datetime import datetime
>> > +from . import options
>> > +import shutil
>> > +import os
>> > +try:
>> > + import configparser
>> > +except:
>> > + import ConfigParser as configparser
>> > +class summary:
>> > + def __init__(self, p_summary_dir):
>> > + self.summary_file_path = path.join(p_summary_dir,
>> 'summary.txt')
>> > + self.index_file_path = path.join(p_summary_dir, 'index.html')
>> > + self.bytes_analyzed = 0
>> > + self.bytes_not_executed = 0
>> > + self.percentage_executed = 0.0
>> > + self.percentage_not_executed = 100.0
>> > + self.ranges_uncovered = 0
>> > + self.branches_uncovered = 0
>> > + self.branches_total = 0
>> > + self.branches_always_taken = 0
>> > + self.branches_never_taken = 0
>> > + self.percentage_branches_covered = 0.0
>> > + self.is_failure = False
>> > + def parse(self):
>> > + if(not path.exists(self.summary_file_path)):
>> > + log.notice('summary file %s does not exist!' %
>> > + self.is_failure = True
>> > + return
>> > + with open(self.summary_file_path,'r') as summary_file:
>> self._get_next_with_colon(summary_file)
>> self._get_next_without_colon(summary_file)
>> > + if len(self.branches_uncovered) > 0 and
>> len(self.branches_total) > 0:
>> > + self.percentage_branches_covered = \
>> > + 1 - (float(self.branches_uncovered) /
>> float(self.branches_total))
>> > + else:
>> > + return
>> > + def _get_next_with_colon(self, summary_file):
>> > + line = summary_file.readline()
>> > + if ':' in line:
>> > + return line.split(':')[1].strip()
>> > + else:
>> > + return ''
>> > + def _get_next_without_colon(self, summary_file):
>> > + return line.strip().split(' ')[0]
>> > +class report_gen_html:
>> > + def __init__(self, p_symbol_sets_list, build_dir, rtdir):
>> > + self.symbol_sets_list = ['score']
>> > + self.build_dir = build_dir
>> > + self.partial_reports_files = list(["index.html",
>> "summary.txt"])
>> > + self.number_of_columns = 1
>> > + self.covoar_src_path = path.join(rtdir, 'covoar')
>> > + def _find_partial_reports(self):
>> > + partial_reports = {}
>> > + for symbol_set in self.symbol_sets_list:
>> > + set_summary = summary(path.join(self.build_dir, "coverage",
>> > + symbol_set))
>> > + set_summary.parse()
>> > + partial_reports[symbol_set] = set_summary
>> > + return partial_reports
>> > + def _prepare_head_section(self):
>> > + head_section = '''
>> > + <head>
>> > + <title>RTEMS coverage report</title>
>> > + <style type="text/css">
>> > + progress[value] {
>> > + -webkit-appearance: none;
>> > + appearance: none;
>> > + width: 150px;
>> > + height: 15px;
>> > + </style>
>> > + </head>'''
>> > + return head_section
>> > + def _prepare_index_content(self, partial_reports):
>> > + header = "<h1> RTEMS coverage analysis report </h1>"
>> > + header += "<h3>Coverage reports by symbols sets:</h3>"
>> > + table = "<table>"
>> > + table += self._header_row()
>> > + for symbol_set in partial_reports:
>> > + table += self._row(symbol_set, partial_reports[symbol_set])
>> > + table += "</table> </br>"
>> > + timestamp = "Analysis performed on " + datetime.now().ctime()
>> > + return "<body>\n" + header + table + timestamp + "\n</body>"
>> > + def _row(self, symbol_set, summary):
>> > + row = "<tr>"
>> > + row += "<td>" + symbol_set + "</td>"
>> > + if summary.is_failure:
>> > + row += ' <td colspan="' + str(self.number_of_columns-1) \
>> > + + '" style="background-color:red">FAILURE</td>'
>> > + else:
>> > + row += " <td>" +
>> self._link(summary.index_file_path,"Index") \
>> > + + "</td>"
>> > + row += " <td>" +
>> self._link(summary.summary_file_path,"Summary") \
>> > + + "</td>"
>> > + row += " <td>" + summary.bytes_analyzed + "</td>"
>> > + row += " <td>" + summary.bytes_not_executed + "</td>"
>> > + row += " <td>" + summary.ranges_uncovered + "</td>"
>> > + row += " <td>" + summary.percentage_executed + "%</td>"
>> > + row += " <td>" + summary.percentage_not_executed + "%</td>"
>> > + row += ' <td><progress value="' +
>> summary.percentage_executed \
>> > + + '" max="100"></progress></td>'
>> > + row += " <td>" + summary.branches_uncovered + "</td>"
>> > + row += " <td>" + summary.branches_total + "</td>"
>> > + row += " <td> {:.3%}
>> </td>".format(summary.percentage_branches_covered)
>> > + row += ' <td><progress value="{:.3}"
>> max="100"></progress></td>'.format(100*summary.percentage_branches_covered)
>> > + row += "</tr>\n"
>> > + return row
>> > + def _header_row(self):
>> > + row = "<tr>"
>> > + row += "<th> Symbols set name </th>"
>> > + row += "<th> Index file </th>"
>> > + row += "<th> Summary file </th>"
>> > + row += "<th> Bytes analyzed </th>"
>> > + row += "<th> Bytes not executed </th>"
>> > + row += "<th> Uncovered ranges </th>"
>> > + row += "<th> Percentage covered </th>"
>> > + row += "<th> Percentage uncovered </th>"
>> > + row += "<th> Instruction coverage </th>"
>> > + row += "<th> Branches uncovered </th>"
>> > + row += "<th> Branches total </th>"
>> > + row += "<th> Branches covered percentage </th>"
>> > + row += "<th> Branches coverage </th>"
>> > + row += "</tr>\n"
>> > + self.number_of_columns = row.count('<th>')
>> > + return row
>> > + def _link(self, address, text):
>> > + return '<a href="' + address + '">' + text + '</a>'
>> > + def _create_index_file(self, head_section, content):
>> > + with open(path.join(self.build_dir,"report.html"),'w') as f:
>> > + f.write(head_section)
>> > + f.write(content)
>> > + def generate(self):
>> > + partial_reports = self._find_partial_reports()
>> > + head_section = self._prepare_head_section()
>> > + index_content = self._prepare_index_content(partial_reports)
>> > + self._create_index_file(head_section,index_content)
>> > + def add_covoar_src_path(self):
>> > + table_js_path = path.join(self.covoar_src_path, 'table.js')
>> > + covoar_css_path = path.join(self.covoar_src_path, 'covoar.css')
>> > + symbol_set_dir = path.join(self.build_dir, "coverage",
>> symbol_set)
>> > + html_files = os.listdir(symbol_set_dir)
>> > + for html_file in html_files:
>> > + html_file = path.join(symbol_set_dir, html_file)
>> > + if path.exists(html_file) and 'html' in html_file:
>> > + with open(html_file, 'r') as f:
>> > + file_data = f.read()
>> > + file_data = file_data.replace('table.js',
>> table_js_path)
>> > + file_data = file_data.replace('covoar.css',
>> > + covoar_css_path)
>> > + with open(html_file, 'w') as f:
>> > + f.write(file_data)
>> > +class build_path_generator(object):
>> > + Generates the build path from the path to executables
>> > + def __init__(self, executables, target):
>> > + self.executables = executables
>> > + self.target = target
>> > + def run(self):
>> > + build_path = '/'
>> > + Path = self.executables[0].split('/')
>> > + for P in Path:
>> > + if P == self.target:
>> > + break;
>> > + else:
>> > + build_path = path.join(build_path, P)
>> > + return build_path
>> > +class symbol_parser(object):
>> > + Parse the symbol sets ini and create custom ini file for covoar
>> > + def __init__(self, symbol_config_path,
>> > + symbol_select_path, coverage_arg, build_dir):
>> > + self.symbol_select_file = symbol_select_path
>> > + self.symbol_file = symbol_config_path
>> > + self.symbol_sets = {}
>> > + self.cov_arg = coverage_arg
>> > + self.ssets = []
>> > + def parse(self):
>> > + config = configparser.ConfigParser()
>> > + try:
>> > + config.read(self.symbol_file)
>> > + if self.cov_arg:
>> > + self.ssets = self.cov_arg.split(',')
>> > + else:
>> > + self.ssets = config.get('symbol-sets',
>> 'sets').split(',')
>> > + self.ssets = [ sset.encode('utf-8') for sset in
>> self.ssets]
>> > + for sset in self.ssets:
>> > + lib = path.join(self.build_dir,
>> > + config.get('libraries', sset))
>> > + self.symbol_sets[sset] = lib.encode('utf-8')
>> > + except:
>> > + raise error.general('Symbol set parsing failed')
>> > + def _write_ini(self):
>> > + try:
>> > + sets = ', '.join(self.symbol_sets.keys())
>> > + config.add_section('symbol-sets')
>> > + config.set('symbol-sets', 'sets', sets)
>> > + for key in self.symbol_sets.keys():
>> > + config.add_section(key)
>> > + config.set(key, 'libraries', self.symbol_sets[key])
>> > + with open(self.symbol_select_file, 'w') as conf:
>> > + config.write(conf)
>> > + except:
>> > + raise error.general('write failed')
>> > + def run(self):
>> > + self.parse()
>> > + self._write_ini()
>> > +class covoar(object):
>> > + Covoar runner
>> > + def __init__(self, base_result_dir, config_dir, executables,
>> explanations_txt):
>> > + self.base_result_dir = base_result_dir
>> > + self.config_dir = config_dir
>> > + self.executables = ' '.join(executables)
>> > + self.explanations_txt = explanations_txt
>> > + self.project_name = 'RTEMS-5'
>> > + def run(self, set_name, symbol_file):
>> > + covoar_result_dir = path.join(self.base_result_dir, set_name)
>> > + if (not path.exists(covoar_result_dir)):
>> > + path.mkdir(covoar_result_dir)
>> > + if (not path.exists(symbol_file)):
>> > + raise error.general('symbol set file: coverage %s was not
>> created for covoar, skipping %s'% (symbol_file, set_name))
>> > + command = ('covoar -S ' + symbol_file
>> > + + ' -O ' + covoar_result_dir
>> > + + ' -E ' + self.explanations_txt
>> > + + ' -p ' + self.project_name + ' ' +
>> self.executables)
>> > + log.notice('Running covoar for %s' % (set_name))
>> > + print( 'covoar results directory:\n' + covoar_result_dir )
>> > + executor = execute.execute(verbose = True, output =
>> self.output_handler)
>> > + exit_code = executor.shell(command, cwd=os.getcwd())
>> > + if (exit_code[0] != 0):
>> > + raise error.general('covoar failure exit code: %d' %
>> (exit_code[0]))
>> > + log.notice('Coverage run for %s finished successfully.' %
>> (set_name))
>> > + log.notice('-----------------------------------------------')
>> > + def output_handler(self, text):
>> > + log.notice('%s' % (text))
>> > +class coverage_run(object):
>> > + Coverage analysis support for rtems-test
>> > + def __init__(self, p_macros, coverage_arg, target):
>> > + Constructor
>> > + self.macros = p_macros
>> > + self.build_dir = self.macros['_cwd']
>> self.macros.expand(self.macros['cov_explanations'])
>> > + self.test_dir = path.join(self.build_dir, 'coverage')
>> > + if (not path.exists(self.test_dir)):
>> > + path.mkdir(self.test_dir)
>> > + self.rtdir = path.abspath(self.macros['_rtdir'])
>> > + self.rtscripts = self.macros.expand(self.macros['_rtscripts'])
>> > + self.coverage_config_path = path.join(self.rtscripts,
>> 'coverage')
>> > + self.symbol_config_path = path.join(self.coverage_config_path,
>> > + 'symbol-sets.ini')
>> > + self.symbol_select_path = path.join(self.coverage_config_path,
>> > + 'symbol-select.ini')
>> > + self.executables = None
>> > + self.symbol_sets = []
>> > + self.no_clean = int(self.macros['_no_clean'])
>> > + self.report_format = self.macros['cov_report_format']
>> > + self.coverage_arg = coverage_arg
>> > + def run(self):
>> > + try:
>> > + if self.executables is None:
>> > + raise error.general('no test executables provided.')
>> > + build_dir = build_path_generator(self.executables,
>> self.target).run()
>> > + parser = symbol_parser(self.symbol_config_path,
>> > + self.symbol_select_path,
>> > + self.coverage_arg,
>> > + build_dir)
>> > + parser.run()
>> > + covoar_runner = covoar(self.test_dir,
>> > + self.executables,
>> self.explanations_txt)
>> > + covoar_runner.run('score', self.symbol_select_path)
>> > + self._generate_reports();
>> > + self._summarize();
>> > + finally:
>> > + self._cleanup();
>> > + def _generate_reports(self):
>> > + log.notice('Generating reports')
>> > + if self.report_format == 'html':
>> > + report = report_gen_html(self.symbol_sets,
>> > + self.build_dir,
>> > + self.rtdir)
>> > + report.generate()
>> > + report.add_covoar_src_path()
>> > + def _cleanup(self):
>> > + if not self.no_clean:
>> > + log.notice('***Cleaning tempfiles***')
>> > + for exe in self.executables:
>> > + trace_file = exe + '.cov'
>> > + if path.exists(trace_file):
>> > + os.remove(trace_file)
>> > + def _summarize(self):
>> > + log.notice('Coverage analysis finished. You can find results
>> in %s' % (self.build_dir))
>> > diff --git a/tester/rt/test.py b/tester/rt/test.py
>> > index f4d9b5c..cabec7b 100644
>> > --- a/tester/rt/test.py
>> > +++ b/tester/rt/test.py
>> > @@ -48,12 +48,14 @@ from rtemstoolkit import mailer
>> > from rtemstoolkit import reraise
>> > from rtemstoolkit import stacktraces
>> > from rtemstoolkit import version
>> > +from rtemstoolkit import check
>> > from . import bsps
>> > from . import config
>> > from . import console
>> > from . import report
>> > +from . import coverage
>> > class log_capture(object):
>> > def __init__(self):
>> > @@ -147,7 +149,7 @@ class test_run(object):
>> > def run(self):
>> > self.thread = threading.Thread(target = self.runner,
>> > - name = 'test[%s]' %
>> path.basename(self.executable))
>> > + name = 'test[%s]' %
>> > self.thread.start()
>> > def is_alive(self):
>> > @@ -214,6 +216,11 @@ def killall(tests):
>> > for test in tests:
>> > test.kill()
>> why extra new line here?
> Will correct it. Thanks.
>> > +def coverage_run(opts, coverage, executables):
>> > + coverage.executables = executables
>> > + coverage.run()
>> > def run(command_path = None):
>> > import sys
>> > tests = []
>> > @@ -221,15 +228,16 @@ def run(command_path = None):
>> > opts = None
>> > default_exefilter = '*.exe'
>> > try:
>> > - optargs = { '--rtems-tools': 'The path to the RTEMS tools',
>> > - '--rtems-bsp': 'The RTEMS BSP to run the test
>> on',
>> > - '--user-config': 'Path to your local user
>> configuration INI file',
>> > - '--report-mode': 'Reporting modes, failures
>> (default),all,none',
>> > - '--list-bsps': 'List the supported BSPs',
>> > - '--debug-trace': 'Debug trace based on specific
>> flags',
>> > - '--filter': 'Glob that executables must match
>> to run (default: ' +
>> > + optargs = { '--rtems-tools': 'The path to the RTEMS tools',
>> > + '--rtems-bsp': 'The RTEMS BSP to run the test
>> on',
>> > + '--user-config': 'Path to your local user
>> > + '--report-mode': 'Reporting modes, failures
>> > + '--list-bsps': 'List the supported BSPs',
>> > + '--debug-trace': 'Debug trace based on specific
>> flags',
>> > + '--filter': 'Glob that executables must
>> match to run (default: ' +
>> > default_exefilter + ')',
>> > - '--stacktrace': 'Dump a stack trace on a user
>> termination (^C)' }
>> > + '--stacktrace': 'Dump a stack trace on a user
>> termination (^C)',
>> > + '--coverage': 'Perform coverage analysis of
>> test exectuables.'}
>> Why are there changes outside of the last two lines (stacktrace and
>> coverage)? Only those two need to be modified to add the new option.
>> Typo: s/exectuables/executables
> Thanks
>> > mailer.append_options(optargs)
>> > opts = options.load(sys.argv,
>> > optargs = optargs,
>> > @@ -279,6 +287,14 @@ def run(command_path = None):
>> > raise error.general('RTEMS BSP not provided or an invalid
>> option')
>> > bsp = config.load(bsp[1], opts)
>> > bsp_config = opts.defaults.expand(opts.defaults['tester'])
>> > + coverage_enabled = opts.find_arg('--coverage')
>> > + if coverage_enabled:
>> > + if len(coverage_enabled) == 2:
>> What is this len() check doing? This seems horribly hackish to me. It
>> is obviously assuming something, but I can't tell what that is. It
>> might be better to do an error check (like what is done with the bsp
>> variable before this) to see if len(coverage_enabled) != 2. From what
>> I see here, I have no clue what should be the arguments to this
>> --coverage, it seems like a binary value to me (on/off).
>> it's supposed to work this way ...
> --coverage option is supposed to run coverage for all the sets
> mentioned in the ini file.
> --coverage=set1,set2
> will run it specifically for set1 and set 2.
>> > + coverage_runner = coverage.coverage_run(opts.defaults,
>> > + coverage_enabled[1],
>> opts.defaults['target'])
>> > + else:
>> 0)
>> > report_mode = opts.find_arg('--report-mode')
>> > if report_mode:
>> > if report_mode[1] != 'failures' and \
>> > @@ -365,6 +381,8 @@ def run(command_path = None):
>> > reports.failures(),
>> > 'Log', '===', ''] + output.get()
>> > mail.send(to_addr, subject, os.linesep.join(body))
>> > + coverage_run(opts, coverage_runner, executables)
>> Design question: Should the coverage run replace the test_run? Or
>> should coverage be an option to test_run instead of how this is being
>> done?
>> It should be an option to test_run
> just adding --coverage will run coverage analysis.
>> > except error.general as gerr:
>> > print(gerr)
>> > diff --git a/tester/rtems/testing/bsps/leon3-qemu-cov.ini
>> b/tester/rtems/testing/bsps/leon3-qemu-cov.ini
>> > index 6b5e7e6..2f89117 100644
>> > --- a/tester/rtems/testing/bsps/leon3-qemu-cov.ini
>> > +++ b/tester/rtems/testing/bsps/leon3-qemu-cov.ini
>> > @@ -31,9 +31,10 @@
>> > # The Leon 3 QEMU BSP
>> > -[leon3-qemu]
>> > +[leon3-qemu-cov]
>> > bsp = leon3-qemu
>> > arch = sparc
>> > +target = sparc-rtems5
>> > tester = %{_rtscripts}/qemu.cfg
>> > bsp_qemu_opts = %{qemu_opts_base} -M leon3_generic
>> > bsp_qemu_cov_opts = -exec-trace %{test_executable}.cov
>> > diff --git a/tester/rtems/testing/coverage/symbol-sets.ini
>> b/tester/rtems/testing/coverage/symbol-sets.ini
>> > index 0000000..a2ec7bc
>> > --- /dev/null
>> > +++ b/tester/rtems/testing/coverage/symbol-sets.ini
>> > @@ -0,0 +1,36 @@
>> > +# Copyright 2018 Chris Johns (chrisj at rtems.org)
>> are met:
>> notice,
>> notice,
>> documentation
>> "AS IS"
>> TO, THE
>> PURPOSE
>> CONTRIBUTORS BE
>> BUSINESS
>> IN
>> OTHERWISE)
>> OF THE
>> > +[symbol-sets]
>> > +sets = score,rtems
>> > +[libraries]
>> > +score = @BUILD-TARGET@/c/@BSP@/cpukit/score/libscore.a
>> > +rtems = @BUILD-TARGET@/c/@BSP@/cpukit/rtems/librtems.a
>> > diff --git a/tester/rtems/testing/qemu.cfg b/tester/rtems/testing/
>> qemu.cfg
>> > index bfcd2f5..52a3752 100644
>> > --- a/tester/rtems/testing/qemu.cfg
>> > +++ b/tester/rtems/testing/qemu.cfg
>> > @@ -51,8 +51,8 @@
>> > # Qemu common option patterns.
>> > -#%define qemu_opts_base -no-reboot -monitor none -serial stdio
>> -nographic
>> > -%define qemu_opts_base -no-reboot -serial null -serial mon:stdio
>> -nographic
>> > +%define qemu_opts_base -no-reboot -monitor none -serial stdio
>> -nographic
>> > +#%define qemu_opts_base -no-reboot -serial null -serial mon:stdio
>> -nographic
>> Why changing the common options for qemu?
> Those are the options that have been tested to work with couverture-qemu.
>> actually it's a bit experimental on advice of Cillian.
> It stayed in the patch.
>> > %define qemu_opts_no_net -net none
>> > 2.14.3
>> > _______________________________________________
>> > devel mailing list
>> > devel at rtems.org
>> > http://lists.rtems.org/mailman/listinfo/devel
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180530/bd4cbbdb/attachment-0001.html>
