[PATCH] Generate coverage analysis Report
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Wed May 30 18:34:18 UTC 2018
On 30 May 2018 at 23:29, Joel Sherrill <joel at rtems.org> wrote:
> On Wed, May 30, 2018 at 12:54 PM, Vijay Kumar Banerjee <
> vijaykumar9597 at gmail.com> wrote:
>> On 30 May 2018 at 22:51, Gedare Bloom <gedare at rtems.org> wrote:
>>> Please provide your name in your commits (git config --user.name "My
>>> Name") that you submit.
>>> OK Noted :)
>>> The first line of this commit, and therefore the email subject, is
>>> overly vague. Provide a slightly more specific description.
>> On Wed, May 30, 2018 at 1:00 PM, thelunatic <vijaykumar9597 at gmail.com>
>>> wrote:
>>> > + Add script to run covoar and generate an html report from
>>> > the output generated from covoar
>>> > + Add symbol-sets ini file for library addresses of the symbol-sets
>>> > + tester/rt/test : Add options for running coverage
>>> I'd rather see a narrative paragraph than this list of + bullet items.
>>> Are all of these changes required to run the report? Should they be
>>> broken into smaller commits that are logically related but separately
>>> reviewable and commited?
>>> OK, I will write in a descriptive paragraph.
>> These changes are all needed to run coverage.
>>> > Co-author : Cillian O'Donnel <cpodonnell8 at gmail.com>
>>> I don't know what Co-Author should mean. I would prefer to receive
>>> separate commits/patches for contributions made by different people if
>>> that is possible.
>>> Plese refer below...
>>> > tester/rt/coverage.py | 380
>>> > tester/rt/test.py | 36 ++-
>>> > tester/rtems/testing/bsps/leon3-qemu-cov.ini | 3 +-
>>> > tester/rtems/testing/coverage/symbol-sets.ini | 36 +++
>>> > tester/rtems/testing/qemu.cfg | 4 +-
>>> > 5 files changed, 447 insertions(+), 12 deletions(-)
>>> > create mode 100644 tester/rt/coverage.py
>>> > create mode 100644 tester/rtems/testing/coverage/symbol-sets.ini
>>> > diff --git a/tester/rt/coverage.py b/tester/rt/coverage.py
>>> > new file mode 100644
>>> > index 0000000..38dcce6
>>> > --- /dev/null
>>> > +++ b/tester/rt/coverage.py
>>> > @@ -0,0 +1,380 @@
>>> > +# RTEMS Tools Project (http://www.rtems.org/)
>>> > +# Copyright 2014 Krzysztof Miesowicz (krzysztof.miesowicz at gmail.com)
>>> Is this Krzysztof's code? if so, it should be added as a commit with
>>> him as the --author="" field of git-commit option.
>>> Actually this script has undergone a lot of updates.
>> It doesn't even work the same way it used to. I am uncertain
>> about the portions of the code that are written by him and still in
>> the script. Basically I left the copyright notice untouched and
>> let it be there because I am unsure of what to include there.
>> Same is true in case of Cillian. I don't really know how much
>> of Code is authored by him.
>> It surely isn't the proper way to add him as the co-author in
>> the log but that seemed like the only way to include him.
> OK. I was afraid of it being technically impossible to separate out the
> work
> for revision control purposes.
> Just make sure credit due is given.
>>> > +# All rights reserved.
>>> > +# This file is part of the RTEMS Tools package in 'rtems-tools'.
>>> > +# Redistribution and use in source and binary forms, with or without
>>> > +# modification, are permitted provided that the following conditions
>>> are met:
>>> > +# 1. Redistributions of source code must retain the above copyright
>>> notice,
>>> > +# this list of conditions and the following disclaimer.
>>> > +# 2. Redistributions in binary form must reproduce the above
>>> copyright notice,
>>> > +# this list of conditions and the following disclaimer in the
>>> documentation
>>> > +# and/or other materials provided with the distribution.
>>> > +# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
>>> 'AS IS'
>>> > +# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED
>>> TO, THE
>>> > +# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
>>> PURPOSE
>>> > +# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR
>>> CONTRIBUTORS BE
>>> > +# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
>>> > +# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
>>> > +# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
>>> BUSINESS
>>> > +# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
>>> WHETHER IN
>>> > +# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
>>> OTHERWISE)
>>> > +# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED
>>> OF THE
>>> > +# POSSIBILITY OF SUCH DAMAGE.
>>> > +from rtemstoolkit import error
>>> > +from rtemstoolkit import path
>>> > +from rtemstoolkit import log
>>> > +from rtemstoolkit import execute
>>> > +from rtemstoolkit import macros
>>> > +from datetime import datetime
>>> > +from . import options
>>> > +import shutil
>>> > +import os
>>> > +try:
>>> > + import configparser
>>> > +except:
>>> > + import ConfigParser as configparser
>>> > +class summary:
>>> > + def __init__(self, p_summary_dir):
>>> > + self.summary_file_path = path.join(p_summary_dir,
>>> 'summary.txt')
>>> > + self.index_file_path = path.join(p_summary_dir, 'index.html')
>>> > + self.bytes_analyzed = 0
>>> > + self.bytes_not_executed = 0
>>> > + self.percentage_executed = 0.0
>>> > + self.percentage_not_executed = 100.0
>>> > + self.ranges_uncovered = 0
>>> > + self.branches_uncovered = 0
>>> > + self.branches_total = 0
>>> > + self.branches_always_taken = 0
>>> > + self.branches_never_taken = 0
>>> > + self.percentage_branches_covered = 0.0
>>> > + self.is_failure = False
>>> > + def parse(self):
>>> > + if(not path.exists(self.summary_file_path)):
>>> > + log.notice('summary file %s does not exist!' %
>>> > + self.is_failure = True
>>> > + return
>>> > + with open(self.summary_file_path,'r') as summary_file:
>>> > + self.bytes_analyzed = self._get_next_with_colon(summ
>>> ary_file)
>>> > + self.bytes_not_executed = self._get_next_with_colon(summ
>>> ary_file)
>>> > + self.percentage_executed = self._get_next_with_colon(summ
>>> ary_file)
>>> self._get_next_with_colon(summary_file)
>>> > + self.ranges_uncovered = self._get_next_with_colon(summ
>>> ary_file)
>>> > + self.branches_total = self._get_next_with_colon(summ
>>> ary_file)
>>> > + self.branches_uncovered = self._get_next_with_colon(summ
>>> ary_file)
>>> > + self.branches_always_taken = self._get_next_without_colon(s
>>> ummary_file)
>>> > + self.branches_never_taken = self._get_next_without_colon(s
>>> ummary_file)
>>> > + if len(self.branches_uncovered) > 0 and
>>> len(self.branches_total) > 0:
>>> > + self.percentage_branches_covered = \
>>> > + 1 - (float(self.branches_uncovered) /
>>> float(self.branches_total))
>>> > + else:
>>> > + return
>>> > + def _get_next_with_colon(self, summary_file):
>>> > + line = summary_file.readline()
>>> > + if ':' in line:
>>> > + return line.split(':')[1].strip()
>>> > + else:
>>> > + return ''
>>> > + def _get_next_without_colon(self, summary_file):
>>> > + return line.strip().split(' ')[0]
>>> > +class report_gen_html:
>>> > + def __init__(self, p_symbol_sets_list, build_dir, rtdir):
>>> > + self.symbol_sets_list = ['score']
>>> > + self.build_dir = build_dir
>>> > + self.partial_reports_files = list(["index.html",
>>> "summary.txt"])
>>> > + self.number_of_columns = 1
>>> > + self.covoar_src_path = path.join(rtdir, 'covoar')
>>> > + def _find_partial_reports(self):
>>> > + partial_reports = {}
>>> > + for symbol_set in self.symbol_sets_list:
>>> > + set_summary = summary(path.join(self.build_dir,
>>> "coverage",
>>> > + symbol_set))
>>> > + set_summary.parse()
>>> > + partial_reports[symbol_set] = set_summary
>>> > + return partial_reports
>>> > + def _prepare_head_section(self):
>>> > + head_section = '''
>>> > + <head>
>>> > + <title>RTEMS coverage report</title>
>>> > + <style type="text/css">
>>> > + progress[value] {
>>> > + -webkit-appearance: none;
>>> > + appearance: none;
>>> > + width: 150px;
>>> > + height: 15px;
>>> > + </style>
>>> > + </head>'''
>>> > + return head_section
>>> > + def _prepare_index_content(self, partial_reports):
>>> > + header = "<h1> RTEMS coverage analysis report </h1>"
>>> > + header += "<h3>Coverage reports by symbols sets:</h3>"
>>> > + table = "<table>"
>>> > + table += self._header_row()
>>> > + for symbol_set in partial_reports:
>>> > + table += self._row(symbol_set,
>>> partial_reports[symbol_set])
>>> > + table += "</table> </br>"
>>> > + timestamp = "Analysis performed on " + datetime.now().ctime()
>>> > + return "<body>\n" + header + table + timestamp + "\n</body>"
>>> > + def _row(self, symbol_set, summary):
>>> > + row = "<tr>"
>>> > + row += "<td>" + symbol_set + "</td>"
>>> > + if summary.is_failure:
>>> > + row += ' <td colspan="' + str(self.number_of_columns-1) \
>>> > + + '" style="background-color:red">FAILURE</td>'
>>> > + else:
>>> > + row += " <td>" + self._link(summary.index_file_path,"Index")
>>> > + + "</td>"
>>> > + row += " <td>" + self._link(summary.summary_file_path,"Summary")
>>> > + + "</td>"
>>> > + row += " <td>" + summary.bytes_analyzed + "</td>"
>>> > + row += " <td>" + summary.bytes_not_executed + "</td>"
>>> > + row += " <td>" + summary.ranges_uncovered + "</td>"
>>> > + row += " <td>" + summary.percentage_executed + "%</td>"
>>> > + row += " <td>" + summary.percentage_not_executed +
>>> "%</td>"
>>> > + row += ' <td><progress value="' +
>>> summary.percentage_executed \
>>> > + + '" max="100"></progress></td>'
>>> > + row += " <td>" + summary.branches_uncovered + "</td>"
>>> > + row += " <td>" + summary.branches_total + "</td>"
>>> > + row += " <td> {:.3%} </td>".format(summary.percenta
>>> ge_branches_covered)
>>> > + row += ' <td><progress value="{:.3}"
>>> max="100"></progress></td>'.format(100*summary.percentage_br
>>> anches_covered)
>>> > + row += "</tr>\n"
>>> > + return row
>>> > + def _header_row(self):
>>> > + row = "<tr>"
>>> > + row += "<th> Symbols set name </th>"
>>> > + row += "<th> Index file </th>"
>>> > + row += "<th> Summary file </th>"
>>> > + row += "<th> Bytes analyzed </th>"
>>> > + row += "<th> Bytes not executed </th>"
>>> > + row += "<th> Uncovered ranges </th>"
>>> > + row += "<th> Percentage covered </th>"
>>> > + row += "<th> Percentage uncovered </th>"
>>> > + row += "<th> Instruction coverage </th>"
>>> > + row += "<th> Branches uncovered </th>"
>>> > + row += "<th> Branches total </th>"
>>> > + row += "<th> Branches covered percentage </th>"
>>> > + row += "<th> Branches coverage </th>"
>>> > + row += "</tr>\n"
>>> > + self.number_of_columns = row.count('<th>')
>>> > + return row
>>> > + def _link(self, address, text):
>>> > + return '<a href="' + address + '">' + text + '</a>'
>>> > + def _create_index_file(self, head_section, content):
>>> > + with open(path.join(self.build_dir,"report.html"),'w') as f:
>>> > + f.write(head_section)
>>> > + f.write(content)
>>> > + def generate(self):
>>> > + partial_reports = self._find_partial_reports()
>>> > + head_section = self._prepare_head_section()
>>> > + index_content = self._prepare_index_content(partial_reports)
>>> > + self._create_index_file(head_section,index_content)
>>> > + def add_covoar_src_path(self):
>>> > + table_js_path = path.join(self.covoar_src_path, 'table.js')
>>> > + covoar_css_path = path.join(self.covoar_src_path,
>>> 'covoar.css')
>>> > + symbol_set_dir = path.join(self.build_dir, "coverage",
>>> symbol_set)
>>> > + html_files = os.listdir(symbol_set_dir)
>>> > + for html_file in html_files:
>>> > + html_file = path.join(symbol_set_dir, html_file)
>>> > + if path.exists(html_file) and 'html' in html_file:
>>> > + with open(html_file, 'r') as f:
>>> > + file_data = f.read()
>>> > + file_data = file_data.replace('table.js',
>>> table_js_path)
>>> > + file_data = file_data.replace('covoar.css',
>>> > + covoar_css_path)
>>> > + with open(html_file, 'w') as f:
>>> > + f.write(file_data)
>>> > +class build_path_generator(object):
>>> > + Generates the build path from the path to executables
>>> > + def __init__(self, executables, target):
>>> > + self.executables = executables
>>> > + self.target = target
>>> > + def run(self):
>>> > + build_path = '/'
>>> > + Path = self.executables[0].split('/')
>>> > + for P in Path:
>>> > + if P == self.target:
>>> > + break;
>>> > + else:
>>> > + build_path = path.join(build_path, P)
>>> > + return build_path
>>> > +class symbol_parser(object):
>>> > + Parse the symbol sets ini and create custom ini file for covoar
>>> > + def __init__(self, symbol_config_path,
>>> > + symbol_select_path, coverage_arg, build_dir):
>>> > + self.symbol_select_file = symbol_select_path
>>> > + self.symbol_file = symbol_config_path
>>> > + self.symbol_sets = {}
>>> > + self.cov_arg = coverage_arg
>>> > + self.ssets = []
>>> > + def parse(self):
>>> > + config = configparser.ConfigParser()
>>> > + try:
>>> > + config.read(self.symbol_file)
>>> > + if self.cov_arg:
>>> > + self.ssets = self.cov_arg.split(',')
>>> > + else:
>>> > + self.ssets = config.get('symbol-sets',
>>> 'sets').split(',')
>>> > + self.ssets = [ sset.encode('utf-8') for sset in
>>> self.ssets]
>>> > + for sset in self.ssets:
>>> > + lib = path.join(self.build_dir,
>>> > + config.get('libraries', sset))
>>> > + self.symbol_sets[sset] = lib.encode('utf-8')
>>> > + except:
>>> > + raise error.general('Symbol set parsing failed')
>>> > + def _write_ini(self):
>>> > + try:
>>> > + sets = ', '.join(self.symbol_sets.keys())
>>> > + config.add_section('symbol-sets')
>>> > + config.set('symbol-sets', 'sets', sets)
>>> > + for key in self.symbol_sets.keys():
>>> > + config.add_section(key)
>>> > + config.set(key, 'libraries', self.symbol_sets[key])
>>> > + with open(self.symbol_select_file, 'w') as conf:
>>> > + config.write(conf)
>>> > + except:
>>> > + raise error.general('write failed')
>>> > + def run(self):
>>> > + self.parse()
>>> > + self._write_ini()
>>> > +class covoar(object):
>>> > + Covoar runner
>>> > + def __init__(self, base_result_dir, config_dir, executables,
>>> explanations_txt):
>>> > + self.base_result_dir = base_result_dir
>>> > + self.config_dir = config_dir
>>> > + self.executables = ' '.join(executables)
>>> > + self.explanations_txt = explanations_txt
>>> > + self.project_name = 'RTEMS-5'
>>> > + def run(self, set_name, symbol_file):
>>> > + covoar_result_dir = path.join(self.base_result_dir, set_name)
>>> > + if (not path.exists(covoar_result_dir)):
>>> > + path.mkdir(covoar_result_dir)
>>> > + if (not path.exists(symbol_file)):
>>> > + raise error.general('symbol set file: coverage %s was not
>>> created for covoar, skipping %s'% (symbol_file, set_name))
>>> > + command = ('covoar -S ' + symbol_file
>>> > + + ' -O ' + covoar_result_dir
>>> > + + ' -E ' + self.explanations_txt
>>> > + + ' -p ' + self.project_name + ' ' +
>>> self.executables)
>>> > + log.notice('Running covoar for %s' % (set_name))
>>> > + print( 'covoar results directory:\n' + covoar_result_dir )
>>> > + executor = execute.execute(verbose = True, output =
>>> self.output_handler)
>>> > + exit_code = executor.shell(command, cwd=os.getcwd())
>>> > + if (exit_code[0] != 0):
>>> > + raise error.general('covoar failure exit code: %d' %
>>> (exit_code[0]))
>>> > + log.notice('Coverage run for %s finished successfully.' %
>>> (set_name))
>>> > + log.notice('-----------------------------------------------')
>>> > + def output_handler(self, text):
>>> > + log.notice('%s' % (text))
>>> > +class coverage_run(object):
>>> > + Coverage analysis support for rtems-test
>>> > + def __init__(self, p_macros, coverage_arg, target):
>>> > + Constructor
>>> > + self.macros = p_macros
>>> > + self.build_dir = self.macros['_cwd']
>>> > + self.explanations_txt = self.macros.expand(self.macros
>>> ['cov_explanations'])
>>> > + self.test_dir = path.join(self.build_dir, 'coverage')
>>> > + if (not path.exists(self.test_dir)):
>>> > + path.mkdir(self.test_dir)
>>> > + self.rtdir = path.abspath(self.macros['_rtdir'])
>>> > + self.rtscripts = self.macros.expand(self.macros
>>> ['_rtscripts'])
>>> > + self.coverage_config_path = path.join(self.rtscripts,
>>> 'coverage')
>>> > + self.symbol_config_path = path.join(self.coverage_config
>>> _path,
>>> > + 'symbol-sets.ini')
>>> > + self.symbol_select_path = path.join(self.coverage_config
>>> _path,
>>> > + 'symbol-select.ini')
>>> > + self.executables = None
>>> > + self.symbol_sets = []
>>> > + self.no_clean = int(self.macros['_no_clean'])
>>> > + self.report_format = self.macros['cov_report_format']
>>> > + self.coverage_arg = coverage_arg
>>> > + def run(self):
>>> > + try:
>>> > + if self.executables is None:
>>> > + raise error.general('no test executables provided.')
>>> > + build_dir = build_path_generator(self.executables,
>>> self.target).run()
>>> > + parser = symbol_parser(self.symbol_config_path,
>>> > + self.symbol_select_path,
>>> > + self.coverage_arg,
>>> > + build_dir)
>>> > + parser.run()
>>> > + covoar_runner = covoar(self.test_dir,
>>> > + self.executables,
>>> self.explanations_txt)
>>> > + covoar_runner.run('score', self.symbol_select_path)
>>> > + self._generate_reports();
>>> > + self._summarize();
>>> > + finally:
>>> > + self._cleanup();
>>> > + def _generate_reports(self):
>>> > + log.notice('Generating reports')
>>> > + if self.report_format == 'html':
>>> > + report = report_gen_html(self.symbol_sets,
>>> > + self.build_dir,
>>> > + self.rtdir)
>>> > + report.generate()
>>> > + report.add_covoar_src_path()
>>> > + def _cleanup(self):
>>> > + if not self.no_clean:
>>> > + log.notice('***Cleaning tempfiles***')
>>> > + for exe in self.executables:
>>> > + trace_file = exe + '.cov'
>>> > + if path.exists(trace_file):
>>> > + os.remove(trace_file)
>>> > + def _summarize(self):
>>> > + log.notice('Coverage analysis finished. You can find results
>>> in %s' % (self.build_dir))
>>> > diff --git a/tester/rt/test.py b/tester/rt/test.py
>>> > index f4d9b5c..cabec7b 100644
>>> > --- a/tester/rt/test.py
>>> > +++ b/tester/rt/test.py
>>> > @@ -48,12 +48,14 @@ from rtemstoolkit import mailer
>>> > from rtemstoolkit import reraise
>>> > from rtemstoolkit import stacktraces
>>> > from rtemstoolkit import version
>>> > +from rtemstoolkit import check
>>> > from . import bsps
>>> > from . import config
>>> > from . import console
>>> > from . import report
>>> > +from . import coverage
>>> > class log_capture(object):
>>> > def __init__(self):
>>> > @@ -147,7 +149,7 @@ class test_run(object):
>>> > def run(self):
>>> > self.thread = threading.Thread(target = self.runner,
>>> > - name = 'test[%s]' %
>>> path.basename(self.executable))
>>> > + name = 'test[%s]' %
>>> > self.thread.start()
>>> > def is_alive(self):
>>> > @@ -214,6 +216,11 @@ def killall(tests):
>>> > for test in tests:
>>> > test.kill()
>>> why extra new line here?
>> Will correct it. Thanks.
>>> > +def coverage_run(opts, coverage, executables):
>>> > + coverage.executables = executables
>>> > + coverage.run()
>>> > def run(command_path = None):
>>> > import sys
>>> > tests = []
>>> > @@ -221,15 +228,16 @@ def run(command_path = None):
>>> > opts = None
>>> > default_exefilter = '*.exe'
>>> > try:
>>> > - optargs = { '--rtems-tools': 'The path to the RTEMS tools',
>>> > - '--rtems-bsp': 'The RTEMS BSP to run the test
>>> on',
>>> > - '--user-config': 'Path to your local user
>>> configuration INI file',
>>> > - '--report-mode': 'Reporting modes, failures
>>> (default),all,none',
>>> > - '--list-bsps': 'List the supported BSPs',
>>> > - '--debug-trace': 'Debug trace based on specific
>>> flags',
>>> > - '--filter': 'Glob that executables must
>>> match to run (default: ' +
>>> > + optargs = { '--rtems-tools': 'The path to the RTEMS tools',
>>> > + '--rtems-bsp': 'The RTEMS BSP to run the
>>> test on',
>>> > + '--user-config': 'Path to your local user
>>> > + '--report-mode': 'Reporting modes, failures
>>> > + '--list-bsps': 'List the supported BSPs',
>>> > + '--debug-trace': 'Debug trace based on
>>> specific flags',
>>> > + '--filter': 'Glob that executables must
>>> > default_exefilter + ')',
>>> > - '--stacktrace': 'Dump a stack trace on a user
>>> termination (^C)' }
>>> > + '--stacktrace': 'Dump a stack trace on a user
>>> termination (^C)',
>>> > + '--coverage': 'Perform coverage analysis of
>>> test exectuables.'}
>>> Why are there changes outside of the last two lines (stacktrace and
>>> coverage)? Only those two need to be modified to add the new option.
>>> Typo: s/exectuables/executables
>> Thanks
>>> > mailer.append_options(optargs)
>>> > opts = options.load(sys.argv,
>>> > optargs = optargs,
>>> > @@ -279,6 +287,14 @@ def run(command_path = None):
>>> > raise error.general('RTEMS BSP not provided or an invalid
>>> option')
>>> > bsp = config.load(bsp[1], opts)
>>> > bsp_config = opts.defaults.expand(opts.defaults['tester'])
>>> > + coverage_enabled = opts.find_arg('--coverage')
>>> > + if coverage_enabled:
>>> > + if len(coverage_enabled) == 2:
>>> What is this len() check doing? This seems horribly hackish to me. It
>>> is obviously assuming something, but I can't tell what that is. It
>>> might be better to do an error check (like what is done with the bsp
>>> variable before this) to see if len(coverage_enabled) != 2. From what
>>> I see here, I have no clue what should be the arguments to this
>>> --coverage, it seems like a binary value to me (on/off).
>>> it's supposed to work this way ...
>> --coverage option is supposed to run coverage for all the sets
>> mentioned in the ini file.
>> --coverage=set1,set2
>> will run it specifically for set1 and set 2.
>>> > + coverage_runner = coverage.coverage_run(opts.def
>>> aults,
>>> > + coverage_enabled[1],
>>> opts.defaults['target'])
>>> > + else:
>>> > + coverage_runner = coverage.coverage_run(opts.defaults,
>>> 0)
>>> > report_mode = opts.find_arg('--report-mode')
>>> > if report_mode:
>>> > if report_mode[1] != 'failures' and \
>>> > @@ -365,6 +381,8 @@ def run(command_path = None):
>>> > reports.failures(),
>>> > 'Log', '===', ''] + output.get()
>>> > mail.send(to_addr, subject, os.linesep.join(body))
>>> > + coverage_run(opts, coverage_runner, executables)
>>> Design question: Should the coverage run replace the test_run? Or
>>> should coverage be an option to test_run instead of how this is being
>>> done?
>>> It should be an option to test_run
>> just adding --coverage will run coverage analysis.
> Can this change be a follow up patch? I know Chris and I just want to get
> work focused on the master.
Sorry I couldn't understand.
Which change ?
>>> > except error.general as gerr:
>>> > print(gerr)
>>> > diff --git a/tester/rtems/testing/bsps/leon3-qemu-cov.ini
>>> b/tester/rtems/testing/bsps/leon3-qemu-cov.ini
>>> > index 6b5e7e6..2f89117 100644
>>> > --- a/tester/rtems/testing/bsps/leon3-qemu-cov.ini
>>> > +++ b/tester/rtems/testing/bsps/leon3-qemu-cov.ini
>>> > @@ -31,9 +31,10 @@
>>> > # The Leon 3 QEMU BSP
>>> > -[leon3-qemu]
>>> > +[leon3-qemu-cov]
>>> > bsp = leon3-qemu
>>> > arch = sparc
>>> > +target = sparc-rtems5
>>> > tester = %{_rtscripts}/qemu.cfg
>>> > bsp_qemu_opts = %{qemu_opts_base} -M leon3_generic
>>> > bsp_qemu_cov_opts = -exec-trace %{test_executable}.cov
>>> > diff --git a/tester/rtems/testing/coverage/symbol-sets.ini
>>> b/tester/rtems/testing/coverage/symbol-sets.ini
>>> > index 0000000..a2ec7bc
>>> > --- /dev/null
>>> > +++ b/tester/rtems/testing/coverage/symbol-sets.ini
>>> > @@ -0,0 +1,36 @@
>>> > +# Copyright 2018 Chris Johns (chrisj at rtems.org)
>>> are met:
>>> notice,
>>> copyright notice,
>>> documentation
>>> "AS IS"
>>> TO, THE
>>> PURPOSE
>>> CONTRIBUTORS BE
>>> BUSINESS
>>> WHETHER IN
>>> OTHERWISE)
>>> OF THE
>>> > +[symbol-sets]
>>> > +sets = score,rtems
>>> > +[libraries]
>>> > +score = @BUILD-TARGET@/c/@BSP@/cpukit/score/libscore.a
>>> > +rtems = @BUILD-TARGET@/c/@BSP@/cpukit/rtems/librtems.a
>>> > diff --git a/tester/rtems/testing/qemu.cfg b/tester/rtems/testing/
>>> qemu.cfg
>>> > index bfcd2f5..52a3752 100644
>>> > --- a/tester/rtems/testing/qemu.cfg
>>> > +++ b/tester/rtems/testing/qemu.cfg
>>> > @@ -51,8 +51,8 @@
>>> > # Qemu common option patterns.
>>> > -#%define qemu_opts_base -no-reboot -monitor none -serial stdio
>>> -nographic
>>> > -%define qemu_opts_base -no-reboot -serial null -serial mon:stdio
>>> -nographic
>>> > +%define qemu_opts_base -no-reboot -monitor none -serial stdio
>>> -nographic
>>> > +#%define qemu_opts_base -no-reboot -serial null -serial mon:stdio
>>> -nographic
>>> Why changing the common options for qemu?
>>> actually it's a bit experimental on advice of Cillian.
>> It stayed in the patch.
> I know the impact of some of those options but maybe it would make sense
> to add a comment block with the impact of each option? It would help future
> readers.
> And, from personal experience, qemu changes arguments from time to time.
> Knowing
> what the old intent was helps mapping to different versions and target
> architectures.
> That's a good Idea.
>> > %define qemu_opts_no_net -net none
>>> > 2.14.3
>>> > _______________________________________________
>>> > devel mailing list
>>> > devel at rtems.org
>>> > http://lists.rtems.org/mailman/listinfo/devel
>> devel mailing list
>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180531/78ca1743/attachment-0001.html>
