[PATCH 1/1] Fix and extend error message in posix timer test
Wed May 30 18:50:07 UTC 2018
I'm having trouble standing up a sparc-rtems5/erc32 build right now,
so I can't test this.
On Wed, May 30, 2018 at 1:44 PM, Joel Sherrill <joel at rtems.org> wrote:
> On Wed, May 30, 2018 at 10:33 AM, Gedare Bloom <gedare at rtems.org> wrote:
>> This looks fine to me, and I'll commit after I can test it. (We
>> currently don't apply any significance to --signed-off-by in RTEMS
>> Project.) I'm investigating your inquiry on the 0/1 cover letter.
> I am ok with it if it tests OK with you.
>> On Tue, May 15, 2018 at 5:21 AM, Martin Erik Werner
>> <martinerikwerner.aac at gmail.com> wrote:
>> > _Timespec_Equal_to() does not set errno, hence avoid using perror(),
>> > instead use fprintf() to stderr, and extend the error message to provide
>> > information about what the error is (measured timer value after
>> > re-arming is not equal to the configured interval), and how large of a
>> > difference was measured.
>> > Signed-off-by: Martin Erik Werner <martin.werner at aacmicrotec.com>
>> >  testsuites/psxtests/psxtimer01/psxtimer.c | 14 ++++++++++++--
>> >  1 file changed, 12 insertions(+), 2 deletions(-)
>> > diff --git a/testsuites/psxtests/psxtimer01/psxtimer.c
>> > b/testsuites/psxtests/psxtimer01/psxtimer.c
>> > index 032e9f8e6c..6ec049ac54 100644
>> > --- a/testsuites/psxtests/psxtimer01/psxtimer.c
>> > +++ b/testsuites/psxtests/psxtimer01/psxtimer.c
>> > @@ -143,7 +143,12 @@ void * task_a (void *arg)
>> >         rtems_test_exit(0);
>> >       if (! _Timespec_Equal_to( &timerdata.it_value, &my_period )){
>> > -       perror ("Error in Task A timer_gettime\n");
>> > +       fprintf(
>> > +           stderr, "Error in Task A timer_gettime:\n"
>> > +           "  re-armed timer: %" PRIdtime_t ":%ld does not match
>> > interval: %" PRIdtime_t ":%ld\n",
>> > +           timerdata.it_value.tv_sec, timerdata.it_value.tv_nsec,
>> > +           my_period.tv_sec, my_period.tv_nsec
>> >       clock = time(NULL);
>> >       printf("Executing task A with count = %2i %s", params->count,
>> > ctime(&clock));
>> > @@ -291,7 +296,12 @@ void * task_c (void *arg)
>> >         rtems_test_exit(0);
>> >       if (! _Timespec_Equal_to( &timerdata.it_value, &my_period) ){
>> > -       perror ("Error in Task C timer_gettime\n");
>> > +       fprintf(
>> >       pthread_mutex_lock (&data.mutex);
>> >       while (data.updated == FALSE) {
>> > 2.11.0
>> > _______________________________________________
>> > devel mailing list
>> > devel at rtems.org
>> > http://lists.rtems.org/mailman/listinfo/devel
>> devel mailing list
>> devel at rtems.org
