Generating separate coverage reports for different symbol-sets from covoar
Thu May 31 06:21:59 UTC 2018
On Wed, May 30, 2018 at 5:20 PM, Vijay Kumar Banerjee
<vijaykumar9597 at gmail.com> wrote:
> Hello,
> The covoar currently is capable of processing multisets
> from the symbol-sets ini file, however, it currently keeps
> all the reports in the same directory (../coverage/score).
> Before the recent updates to covoar it could only read
> one set/subsystem from an ini file, and the script used
> to loop over to feed covoar the ini files and store them
> in a separate directory. Now this support needs to be
> added to covoar .
> The report.html generated from coverage has the
> support for reading from different directories.
> example:- ../coverage/score , ../coverage/rtems etc.
> so just creating a directory for result in each iteration
> of sets would solve this (I think)
This sounds like a quite reasonable approach to take.
> -- vijay
> devel mailing list
> devel at rtems.org
