[PATCH v2] tester: Add script to generate html coverage report from covoar output
Cillian O'Donnell
cpodonnell8 at gmail.com
Thu May 31 20:27:12 UTC 2018
So is it checking whether it's --coverage or --coverage=set1,set2? Are
those the 2 possibilities your checking?
On Thu, 31 May 2018, 20:52 Vijay Kumar Banerjee, <vijaykumar9597 at gmail.com>
wrote:
> On 1 June 2018 at 01:19, Gedare Bloom <gedare at rtems.org> wrote:
>> On Thu, May 31, 2018 at 3:47 PM, Vijay Kumar Banerjee
>> <vijaykumar9597 at gmail.com> wrote:
>> > On 1 June 2018 at 01:07, Cillian O'Donnell <cpodonnell8 at gmail.com>
>> wrote:
>> >> On 31 May 2018 at 19:07, Vijay Kumar Banerjee <
>> >> wrote:
>> >>> Add support in tester to run covoar and generate an html report to
>> >>> display
>> >>> the summary of the coverage reports generated from covoar.
>> >>> Co-authored-by : Cillian O'Donnell <cpodonnell8 at gmail.com>
>> >>> tester/rt/coverage.py | 379
>> >>> tester/rt/test.py | 36 ++-
>> >>> tester/rtems/testing/bsps/leon3-qemu-cov.ini | 3 +-
>> >>> tester/rtems/testing/coverage/symbol-sets.ini | 36 +++
>> >>> tester/rtems/testing/qemu.cfg | 4 +-
>> >>> 5 files changed, 446 insertions(+), 12 deletions(-)
>> >>> create mode 100644 tester/rt/coverage.py
>> >>> create mode 100644 tester/rtems/testing/coverage/symbol-sets.ini
>> >>> diff --git a/tester/rt/coverage.py b/tester/rt/coverage.py
>> >>> new file mode 100644
>> >>> index 0000000..25fbb9d
>> >>> --- /dev/null
>> >>> +++ b/tester/rt/coverage.py
>> >>> @@ -0,0 +1,379 @@
>> >>> +# RTEMS Tools Project (http://www.rtems.org/)
>> >>> +# Copyright 2014 Krzysztof Miesowicz (krzysztof.miesowicz at gmail.com)
>> >>> +# All rights reserved.
>> >>> +# This file is part of the RTEMS Tools package in 'rtems-tools'.
>> >>> +# Redistribution and use in source and binary forms, with or without
>> >>> +# modification, are permitted provided that the following conditions
>> are
>> >>> met:
>> >>> +# 1. Redistributions of source code must retain the above copyright
>> >>> notice,
>> >>> +# this list of conditions and the following disclaimer.
>> >>> +# 2. Redistributions in binary form must reproduce the above
>> copyright
>> >>> notice,
>> >>> +# this list of conditions and the following disclaimer in the
>> >>> documentation
>> >>> +# and/or other materials provided with the distribution.
>> >>> +# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
>> >>> 'AS IS'
>> >>> +# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED
>> TO,
>> >>> THE
>> >>> +# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
>> >>> PURPOSE
>> >>> +# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR
>> CONTRIBUTORS
>> >>> BE
>> >>> +# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
>> >>> +# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT
>> OF
>> >>> +# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
>> >>> BUSINESS
>> >>> +# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
>> WHETHER
>> >>> IN
>> >>> +# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
>> >>> OTHERWISE)
>> >>> +# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF
>> ADVISED OF
>> >>> THE
>> >>> +# POSSIBILITY OF SUCH DAMAGE.
>> >>> +from rtemstoolkit import error
>> >>> +from rtemstoolkit import path
>> >>> +from rtemstoolkit import log
>> >>> +from rtemstoolkit import execute
>> >>> +from rtemstoolkit import macros
>> >>> +from datetime import datetime
>> >>> +from . import options
>> >>> +import shutil
>> >>> +import os
>> >>> +try:
>> >>> + import configparser
>> >>> +except:
>> >>> + import ConfigParser as configparser
>> >>> +class summary:
>> >>> + def __init__(self, p_summary_dir):
>> >>> + self.summary_file_path = path.join(p_summary_dir,
>> 'summary.txt')
>> >>> + self.index_file_path = path.join(p_summary_dir, 'index.html')
>> >>> + self.bytes_analyzed = 0
>> >>> + self.bytes_not_executed = 0
>> >>> + self.percentage_executed = 0.0
>> >>> + self.percentage_not_executed = 100.0
>> >>> + self.ranges_uncovered = 0
>> >>> + self.branches_uncovered = 0
>> >>> + self.branches_total = 0
>> >>> + self.branches_always_taken = 0
>> >>> + self.branches_never_taken = 0
>> >>> + self.percentage_branches_covered = 0.0
>> >>> + self.is_failure = False
>> >>> + def parse(self):
>> >>> + if(not path.exists(self.summary_file_path)):
>> >>> + log.notice('summary file %s does not exist!' %
>> >>> + self.is_failure = True
>> >>> + return
>> >>> + with open(self.summary_file_path,'r') as summary_file:
>> self._get_next_with_colon(summary_file)
>> >>> self._get_next_without_colon(summary_file)
>> >>> + if len(self.branches_uncovered) > 0 and
>> len(self.branches_total)
>> >>> > 0:
>> >>> + self.percentage_branches_covered = \
>> >>> + 1 - (float(self.branches_uncovered) /
>> >>> float(self.branches_total))
>> >>> + else:
>> >>> + return
>> >>> + def _get_next_with_colon(self, summary_file):
>> >>> + line = summary_file.readline()
>> >>> + if ':' in line:
>> >>> + return line.split(':')[1].strip()
>> >>> + else:
>> >>> + return ''
>> >>> + def _get_next_without_colon(self, summary_file):
>> >>> + return line.strip().split(' ')[0]
>> >>> +class report_gen_html:
>> >>> + def __init__(self, p_symbol_sets_list, build_dir, rtdir):
>> >>> + self.symbol_sets_list = ['score']
>> >>> + self.build_dir = build_dir
>> >>> + self.partial_reports_files = list(["index.html",
>> "summary.txt"])
>> >>> + self.number_of_columns = 1
>> >>> + self.covoar_src_path = path.join(rtdir, 'covoar')
>> >>> + def _find_partial_reports(self):
>> >>> + partial_reports = {}
>> >>> + for symbol_set in self.symbol_sets_list:
>> >>> + set_summary = summary(path.join(self.build_dir,
>> "coverage",
>> >>> + symbol_set))
>> >>> + set_summary.parse()
>> >>> + partial_reports[symbol_set] = set_summary
>> >>> + return partial_reports
>> >>> + def _prepare_head_section(self):
>> >>> + head_section = '''
>> >>> + <head>
>> >>> + <title>RTEMS coverage report</title>
>> >>> + <style type="text/css">
>> >>> + progress[value] {
>> >>> + -webkit-appearance: none;
>> >>> + appearance: none;
>> >>> + width: 150px;
>> >>> + height: 15px;
>> >>> + </style>
>> >>> + </head>'''
>> >>> + return head_section
>> >>> + def _prepare_index_content(self, partial_reports):
>> >>> + header = "<h1> RTEMS coverage analysis report </h1>"
>> >>> + header += "<h3>Coverage reports by symbols sets:</h3>"
>> >>> + table = "<table>"
>> >>> + table += self._header_row()
>> >>> + for symbol_set in partial_reports:
>> >>> + table += self._row(symbol_set,
>> partial_reports[symbol_set])
>> >>> + table += "</table> </br>"
>> >>> + timestamp = "Analysis performed on " + datetime.now().ctime()
>> >>> + return "<body>\n" + header + table + timestamp + "\n</body>"
>> >>> + def _row(self, symbol_set, summary):
>> >>> + row = "<tr>"
>> >>> + row += "<td>" + symbol_set + "</td>"
>> >>> + if summary.is_failure:
>> >>> + row += ' <td colspan="' + str(self.number_of_columns-1) \
>> >>> + + '" style="background-color:red">FAILURE</td>'
>> >>> + else:
>> >>> + row += " <td>" +
>> self._link(summary.index_file_path,"Index")
>> >>> + + "</td>"
>> >>> + row += " <td>" +
>> >>> self._link(summary.summary_file_path,"Summary") \
>> >>> + + "</td>"
>> >>> + row += " <td>" + summary.bytes_analyzed + "</td>"
>> >>> + row += " <td>" + summary.bytes_not_executed + "</td>"
>> >>> + row += " <td>" + summary.ranges_uncovered + "</td>"
>> >>> + row += " <td>" + summary.percentage_executed + "%</td>"
>> >>> + row += " <td>" + summary.percentage_not_executed +
>> "%</td>"
>> >>> + row += ' <td><progress value="' +
>> >>> summary.percentage_executed \
>> >>> + + '" max="100"></progress></td>'
>> >>> + row += " <td>" + summary.branches_uncovered + "</td>"
>> >>> + row += " <td>" + summary.branches_total + "</td>"
>> >>> + row += " <td> {:.3%}
>> >>> </td>".format(summary.percentage_branches_covered)
>> >>> + row += ' <td><progress value="{:.3}"
>> max="100"></progress></td>'.format(100*summary.percentage_branches_covered)
>> >>> + row += "</tr>\n"
>> >>> + return row
>> >>> + def _header_row(self):
>> >>> + row = "<tr>"
>> >>> + row += "<th> Symbols set name </th>"
>> >>> + row += "<th> Index file </th>"
>> >>> + row += "<th> Summary file </th>"
>> >>> + row += "<th> Bytes analyzed </th>"
>> >>> + row += "<th> Bytes not executed </th>"
>> >>> + row += "<th> Uncovered ranges </th>"
>> >>> + row += "<th> Percentage covered </th>"
>> >>> + row += "<th> Percentage uncovered </th>"
>> >>> + row += "<th> Instruction coverage </th>"
>> >>> + row += "<th> Branches uncovered </th>"
>> >>> + row += "<th> Branches total </th>"
>> >>> + row += "<th> Branches covered percentage </th>"
>> >>> + row += "<th> Branches coverage </th>"
>> >>> + row += "</tr>\n"
>> >>> + self.number_of_columns = row.count('<th>')
>> >>> + return row
>> >>> + def _link(self, address, text):
>> >>> + return '<a href="' + address + '">' + text + '</a>'
>> >>> + def _create_index_file(self, head_section, content):
>> >>> + with open(path.join(self.build_dir,"report.html"),'w') as f:
>> >>> + f.write(head_section)
>> >>> + f.write(content)
>> >>> + def generate(self):
>> >>> + partial_reports = self._find_partial_reports()
>> >>> + head_section = self._prepare_head_section()
>> >>> + index_content = self._prepare_index_content(partial_reports)
>> >>> + self._create_index_file(head_section,index_content)
>> >>> + def add_covoar_src_path(self):
>> >>> + table_js_path = path.join(self.covoar_src_path, 'table.js')
>> >>> + covoar_css_path = path.join(self.covoar_src_path,
>> 'covoar.css')
>> >>> + symbol_set_dir = path.join(self.build_dir, "coverage",
>> >>> symbol_set)
>> >>> + html_files = os.listdir(symbol_set_dir)
>> >>> + for html_file in html_files:
>> >>> + html_file = path.join(symbol_set_dir, html_file)
>> >>> + if path.exists(html_file) and 'html' in html_file:
>> >>> + with open(html_file, 'r') as f:
>> >>> + file_data = f.read()
>> >>> + file_data = file_data.replace('table.js',
>> >>> table_js_path)
>> >>> + file_data = file_data.replace('covoar.css',
>> >>> + covoar_css_path)
>> >>> + with open(html_file, 'w') as f:
>> >>> + f.write(file_data)
>> >>> +class build_path_generator(object):
>> >>> + Generates the build path from the path to executables
>> >>> + def __init__(self, executables, target):
>> >>> + self.executables = executables
>> >>> + self.target = target
>> >>> + def run(self):
>> >>> + build_path = '/'
>> >>> + Path = self.executables[0].split('/')
>> >>> + for P in Path:
>> >>> + if P == self.target:
>> >>> + break;
>> >>> + else:
>> >>> + build_path = path.join(build_path, P)
>> >>> + return build_path
>> >>> +class symbol_parser(object):
>> >>> + Parse the symbol sets ini and create custom ini file for covoar
>> >>> + def __init__(self, symbol_config_path,
>> >>> + symbol_select_path, coverage_arg, build_dir):
>> >>> + self.symbol_select_file = symbol_select_path
>> >>> + self.symbol_file = symbol_config_path
>> >>> + self.symbol_sets = {}
>> >>> + self.cov_arg = coverage_arg
>> >>> + self.ssets = []
>> >>> + def parse(self):
>> >>> + config = configparser.ConfigParser()
>> >>> + try:
>> >>> + config.read(self.symbol_file)
>> >>> + if self.cov_arg:
>> >>> + self.ssets = self.cov_arg.split(',')
>> >>> + else:
>> >>> + self.ssets = config.get('symbol-sets',
>> >>> 'sets').split(',')
>> >>> + self.ssets = [ sset.encode('utf-8') for sset in
>> >>> self.ssets]
>> >>> + for sset in self.ssets:
>> >>> + lib = path.join(self.build_dir,
>> >>> + config.get('libraries', sset))
>> >>> + self.symbol_sets[sset] = lib.encode('utf-8')
>> >>> + except:
>> >>> + raise error.general('Symbol set parsing failed')
>> >>> + def _write_ini(self):
>> >>> + try:
>> >>> + sets = ', '.join(self.symbol_sets.keys())
>> >>> + config.add_section('symbol-sets')
>> >>> + config.set('symbol-sets', 'sets', sets)
>> >>> + for key in self.symbol_sets.keys():
>> >>> + config.add_section(key)
>> >>> + config.set(key, 'libraries', self.symbol_sets[key])
>> >>> + with open(self.symbol_select_file, 'w') as conf:
>> >>> + config.write(conf)
>> >>> + except:
>> >>> + raise error.general('write failed')
>> >>> + def run(self):
>> >>> + self.parse()
>> >>> + self._write_ini()
>> >>> +class covoar(object):
>> >>> + Covoar runner
>> >>> + def __init__(self, base_result_dir, config_dir, executables,
>> >>> explanations_txt):
>> >>> + self.base_result_dir = base_result_dir
>> >>> + self.config_dir = config_dir
>> >>> + self.executables = ' '.join(executables)
>> >>> + self.explanations_txt = explanations_txt
>> >>> + self.project_name = 'RTEMS-5'
>> >>> + def run(self, set_name, symbol_file):
>> >>> + covoar_result_dir = path.join(self.base_result_dir, set_name)
>> >>> + if (not path.exists(covoar_result_dir)):
>> >>> + path.mkdir(covoar_result_dir)
>> >>> + if (not path.exists(symbol_file)):
>> >>> + raise error.general('symbol set file: coverage %s was not
>> >>> created for covoar, skipping %s'% (symbol_file, set_name))
>> >>> + command = ('covoar -S ' + symbol_file
>> >>> + + ' -O ' + covoar_result_dir
>> >>> + + ' -E ' + self.explanations_txt
>> >>> + + ' -p ' + self.project_name + ' ' +
>> self.executables)
>> >>> + log.notice('Running covoar for %s' % (set_name))
>> >>> + print( 'covoar results directory:\n' + covoar_result_dir )
>> >>> + executor = execute.execute(verbose = True, output =
>> >>> self.output_handler)
>> >>> + exit_code = executor.shell(command, cwd=os.getcwd())
>> >>> + if (exit_code[0] != 0):
>> >>> + raise error.general('covoar failure exit code: %d' %
>> >>> (exit_code[0]))
>> >>> + log.notice('Coverage run for %s finished successfully.' %
>> >>> (set_name))
>> >>> + log.notice('-----------------------------------------------')
>> >>> + def output_handler(self, text):
>> >>> + log.notice('%s' % (text))
>> >>> +class coverage_run(object):
>> >>> + Coverage analysis support for rtems-test
>> >>> + def __init__(self, p_macros, coverage_arg, target):
>> >>> + Constructor
>> >>> + self.macros = p_macros
>> >>> + self.build_dir = self.macros['_cwd']
>> >>> self.macros.expand(self.macros['cov_explanations'])
>> >>> + self.test_dir = path.join(self.build_dir, 'coverage')
>> >>> + if (not path.exists(self.test_dir)):
>> >>> + path.mkdir(self.test_dir)
>> >>> + self.rtdir = path.abspath(self.macros['_rtdir'])
>> >>> + self.rtscripts =
>> self.macros.expand(self.macros['_rtscripts'])
>> >>> + self.coverage_config_path = path.join(self.rtscripts,
>> >>> 'coverage')
>> >>> + self.symbol_config_path =
>> path.join(self.coverage_config_path,
>> >>> + 'symbol-sets.ini')
>> >>> + self.symbol_select_path =
>> >>> + 'symbol-select.ini')
>> >>> + self.executables = None
>> >>> + self.symbol_sets = []
>> >>> + self.no_clean = int(self.macros['_no_clean'])
>> >>> + self.report_format = self.macros['cov_report_format']
>> >>> + self.coverage_arg = coverage_arg
>> >>> + def run(self):
>> >>> + try:
>> >>> + if self.executables is None:
>> >>> + raise error.general('no test executables provided.')
>> >>> + build_dir = build_path_generator(self.executables,
>> >>> self.target).run()
>> >>> + parser = symbol_parser(self.symbol_config_path,
>> >>> + self.symbol_select_path,
>> >>> + self.coverage_arg,
>> >>> + build_dir)
>> >>> + parser.run()
>> >>> + covoar_runner = covoar(self.test_dir,
>> >>> + self.executables,
>> >>> self.explanations_txt)
>> >>> + covoar_runner.run('score', self.symbol_select_path)
>> >>> + self._generate_reports();
>> >>> + self._summarize();
>> >>> + finally:
>> >>> + self._cleanup();
>> >>> + def _generate_reports(self):
>> >>> + log.notice('Generating reports')
>> >>> + if self.report_format == 'html':
>> >>> + report = report_gen_html(self.symbol_sets,
>> >>> + self.build_dir,
>> >>> + self.rtdir)
>> >>> + report.generate()
>> >>> + report.add_covoar_src_path()
>> >>> + def _cleanup(self):
>> >>> + if not self.no_clean:
>> >>> + log.notice('***Cleaning tempfiles***')
>> >>> + for exe in self.executables:
>> >>> + trace_file = exe + '.cov'
>> >>> + if path.exists(trace_file):
>> >>> + os.remove(trace_file)
>> >>> + def _summarize(self):
>> >>> + log.notice('Coverage analysis finished. You can find results
>> in
>> >>> %s' % (self.build_dir))
>> >>> diff --git a/tester/rt/test.py b/tester/rt/test.py
>> >>> index f4d9b5c..84dff01 100644
>> >>> --- a/tester/rt/test.py
>> >>> +++ b/tester/rt/test.py
>> >>> @@ -48,12 +48,14 @@ from rtemstoolkit import mailer
>> >>> from rtemstoolkit import reraise
>> >>> from rtemstoolkit import stacktraces
>> >>> from rtemstoolkit import version
>> >>> +from rtemstoolkit import check
>> >>> from . import bsps
>> >>> from . import config
>> >>> from . import console
>> >>> from . import report
>> >>> +from . import coverage
>> >>> class log_capture(object):
>> >>> def __init__(self):
>> >>> @@ -147,7 +149,7 @@ class test_run(object):
>> >>> def run(self):
>> >>> self.thread = threading.Thread(target = self.runner,
>> >>> - name = 'test[%s]' %
>> >>> path.basename(self.executable))
>> >>> + name = 'test[%s]' %
>> >>> self.thread.start()
>> >>> def is_alive(self):
>> >>> @@ -214,6 +216,10 @@ def killall(tests):
>> >>> for test in tests:
>> >>> test.kill()
>> >>> +def coverage_run(opts, coverage, executables):
>> >>> + coverage.executables = executables
>> >>> + coverage.run()
>> >>> def run(command_path = None):
>> >>> import sys
>> >>> tests = []
>> >>> @@ -221,15 +227,16 @@ def run(command_path = None):
>> >>> opts = None
>> >>> default_exefilter = '*.exe'
>> >>> try:
>> >>> - optargs = { '--rtems-tools': 'The path to the RTEMS tools',
>> >>> - '--rtems-bsp': 'The RTEMS BSP to run the test
>> on',
>> >>> - '--user-config': 'Path to your local user
>> >>> configuration INI file',
>> >>> - '--report-mode': 'Reporting modes, failures
>> >>> (default),all,none',
>> >>> - '--list-bsps': 'List the supported BSPs',
>> >>> - '--debug-trace': 'Debug trace based on specific
>> >>> flags',
>> >>> - '--filter': 'Glob that executables must
>> match
>> >>> to run (default: ' +
>> >>> + optargs = { '--rtems-tools': 'The path to the RTEMS
>> tools',
>> >>> + '--rtems-bsp': 'The RTEMS BSP to run the
>> test
>> >>> on',
>> >>> + '--user-config': 'Path to your local user
>> >>> + '--report-mode': 'Reporting modes, failures
>> >>> + '--list-bsps': 'List the supported BSPs',
>> >>> + '--debug-trace': 'Debug trace based on
>> specific
>> >>> flags',
>> >>> + '--filter': 'Glob that executables must
>> >>> match to run (default: ' +
>> >>> default_exefilter + ')',
>> >>> - '--stacktrace': 'Dump a stack trace on a user
>> >>> termination (^C)' }
>> >>> + '--stacktrace': 'Dump a stack trace on a user
>> >>> termination (^C)',
>> >>> + '--coverage': 'Perform coverage analysis of
>> >>> test executables.'}
>> >>> mailer.append_options(optargs)
>> >>> opts = options.load(sys.argv,
>> >>> optargs = optargs,
>> >>> @@ -279,6 +286,15 @@ def run(command_path = None):
>> >>> raise error.general('RTEMS BSP not provided or an invalid
>> >>> option')
>> >>> bsp = config.load(bsp[1], opts)
>> >>> bsp_config = opts.defaults.expand(opts.defaults['tester'])
>> >>> + coverage_enabled = opts.find_arg('--coverage')
>> >>> + if coverage_enabled:
>> >>> + if len(coverage_enabled) == 2:
>> >> Is this to check if sets have been provided to --coverage=score,sapi,
>> that
>> >> kind of thing? If so the variable name coverage_enabled doesn't make
>> sense
>> >> any more. Probably if symbol_sets and if len(symbol_sets) will make
>> more
>> >> sense for both cases.
>> > That's a good point.
>> > How about changing it to just 'coverage' instead ?
>> > Because it's still checking whether the option is given or
>> > not. symbol_sets might create confusion.
>> > Will that be OK ?
>> That name might collide with your class object (coverage)?
> That's actually why I kept it as coverage_enabled.
> I think we can go for coverage_option (?)
>> >>> + coverage_runner =
>> coverage.coverage_run(opts.defaults,
>> >>> + coverage_enabled[1],
>> opts.defaults['target'])
>> >>> + else:
>> >>> + coverage_runner =
>> >>> 0,
>> >>> report_mode = opts.find_arg('--report-mode')
>> >>> if report_mode:
>> >>> if report_mode[1] != 'failures' and \
>> >>> @@ -365,6 +381,8 @@ def run(command_path = None):
>> >>> reports.failures(),
>> >>> 'Log', '===', ''] + output.get()
>> >>> mail.send(to_addr, subject, os.linesep.join(body))
>> >>> + coverage_run(opts, coverage_runner, executables)
>> >>> except error.general as gerr:
>> >>> print(gerr)
>> >>> diff --git a/tester/rtems/testing/bsps/leon3-qemu-cov.ini
>> >>> b/tester/rtems/testing/bsps/leon3-qemu-cov.ini
>> >>> index 6b5e7e6..2f89117 100644
>> >>> --- a/tester/rtems/testing/bsps/leon3-qemu-cov.ini
>> >>> +++ b/tester/rtems/testing/bsps/leon3-qemu-cov.ini
>> >>> @@ -31,9 +31,10 @@
>> >>> # The Leon 3 QEMU BSP
>> >>> -[leon3-qemu]
>> >>> +[leon3-qemu-cov]
>> >>> bsp = leon3-qemu
>> >>> arch = sparc
>> >>> +target = sparc-rtems5
>> >>> tester = %{_rtscripts}/qemu.cfg
>> >>> bsp_qemu_opts = %{qemu_opts_base} -M leon3_generic
>> >>> bsp_qemu_cov_opts = -exec-trace %{test_executable}.cov
>> >>> diff --git a/tester/rtems/testing/coverage/symbol-sets.ini
>> >>> b/tester/rtems/testing/coverage/symbol-sets.ini
>> >>> index 0000000..a2ec7bc
>> >>> --- /dev/null
>> >>> +++ b/tester/rtems/testing/coverage/symbol-sets.ini
>> >>> @@ -0,0 +1,36 @@
>> >>> +# Copyright 2018 Chris Johns (chrisj at rtems.org)
>> are
>> >>> met:
>> >>> notice,
>> copyright
>> >>> notice,
>> >>> documentation
>> >>> "AS IS"
>> TO,
>> >>> THE
>> >>> PURPOSE
>> CONTRIBUTORS
>> >>> BE
>> OF
>> >>> BUSINESS
>> WHETHER
>> >>> IN
>> >>> OTHERWISE)
>> ADVISED OF
>> >>> THE
>> >>> +[symbol-sets]
>> >>> +sets = score,rtems
>> >>> +[libraries]
>> >>> +score = @BUILD-TARGET@/c/@BSP@/cpukit/score/libscore.a
>> >>> +rtems = @BUILD-TARGET@/c/@BSP@/cpukit/rtems/librtems.a
>> >>> diff --git a/tester/rtems/testing/qemu.cfg
>> >>> b/tester/rtems/testing/qemu.cfg
>> >>> index bfcd2f5..52a3752 100644
>> >>> --- a/tester/rtems/testing/qemu.cfg
>> >>> +++ b/tester/rtems/testing/qemu.cfg
>> >>> @@ -51,8 +51,8 @@
>> >>> # Qemu common option patterns.
>> >>> -#%define qemu_opts_base -no-reboot -monitor none -serial stdio
>> >>> -nographic
>> >>> -%define qemu_opts_base -no-reboot -serial null -serial mon:stdio
>> >>> -nographic
>> >>> +%define qemu_opts_base -no-reboot -monitor none -serial stdio
>> >>> -nographic
>> >>> +#%define qemu_opts_base -no-reboot -serial null -serial mon:stdio
>> >>> -nographic
>> >>> %define qemu_opts_no_net -net none
>> >>> 2.14.3
>> >>> _______________________________________________
>> >>> devel mailing list
>> >>> devel at rtems.org
>> >>> http://lists.rtems.org/mailman/listinfo/devel
>> > devel mailing list
>> > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180531/059b1746/attachment-0001.html>
