[PATCH v2] tester: Add script to generate html coverage report from covoar output
Thu May 31 20:45:54 UTC 2018
On Thu, May 31, 2018 at 4:44 PM, Cillian O'Donnell
<cpodonnell8 at gmail.com> wrote:
> There is now a seperate bsp config for coverage, leon3-qemu-cov. That is
> enough to trigger coverage now and --coverage could be reserved for picking
> sets, probably renamed to --coverage-sets=... Or require sets to be chosen
> --coverage-sets=all or specific sets --coverage-sets=score,sapi,core
Yes, and it should work for more than 1 or 2.
> On Thu, 31 May 2018, 21:29 Vijay Kumar Banerjee, <vijaykumar9597 at gmail.com>
> wrote:
>> On 1 June 2018 at 01:57, Cillian O'Donnell <cpodonnell8 at gmail.com> wrote:
>>> So is it checking whether it's --coverage or --coverage=set1,set2? Are
>>> those the 2 possibilities your checking?
>> Yes, right. :)
>>> On Thu, 31 May 2018, 20:52 Vijay Kumar Banerjee,
>>> <vijaykumar9597 at gmail.com> wrote:
>>>> On 1 June 2018 at 01:19, Gedare Bloom <gedare at rtems.org> wrote:
>>>>> On Thu, May 31, 2018 at 3:47 PM, Vijay Kumar Banerjee
>>>>> > On 1 June 2018 at 01:07, Cillian O'Donnell <cpodonnell8 at gmail.com>
>>>>> > wrote:
>>>>> >> On 31 May 2018 at 19:07, Vijay Kumar Banerjee
>>>>> >> wrote:
>>>>> >>> Add support in tester to run covoar and generate an html report to
>>>>> >>> display
>>>>> >>> the summary of the coverage reports generated from covoar.
>>>>> >>> Co-authored-by : Cillian O'Donnell <cpodonnell8 at gmail.com>
>>>>> >>>  tester/rt/coverage.py                         | 379
>>>>> >>>  tester/rt/test.py                             |  36 ++-
>>>>> >>>  tester/rtems/testing/bsps/leon3-qemu-cov.ini  |   3 +-
>>>>> >>>  tester/rtems/testing/coverage/symbol-sets.ini |  36 +++
>>>>> >>>  tester/rtems/testing/qemu.cfg                 |   4 +-
>>>>> >>>  5 files changed, 446 insertions(+), 12 deletions(-)
>>>>> >>>  create mode 100644 tester/rt/coverage.py
>>>>> >>>  create mode 100644 tester/rtems/testing/coverage/symbol-sets.ini
>>>>> >>> diff --git a/tester/rt/coverage.py b/tester/rt/coverage.py
>>>>> >>> new file mode 100644
>>>>> >>> index 0000000..25fbb9d
>>>>> >>> --- /dev/null
>>>>> >>> +++ b/tester/rt/coverage.py
>>>>> >>> @@ -0,0 +1,379 @@
>>>>> >>> +# RTEMS Tools Project (http://www.rtems.org/)
>>>>> >>> +# Copyright 2014 Krzysztof Miesowicz
>>>>> >>> (krzysztof.miesowicz at gmail.com)
>>>>> >>> +# All rights reserved.
>>>>> >>> +# This file is part of the RTEMS Tools package in 'rtems-tools'.
>>>>> >>> +# Redistribution and use in source and binary forms, with or
>>>>> >>> without
>>>>> >>> +# modification, are permitted provided that the following
>>>>> >>> conditions are
>>>>> >>> met:
>>>>> >>> +# 1. Redistributions of source code must retain the above
>>>>> >>> copyright
>>>>> >>> notice,
>>>>> >>> +# this list of conditions and the following disclaimer.
>>>>> >>> +# 2. Redistributions in binary form must reproduce the above
>>>>> >>> copyright
>>>>> >>> notice,
>>>>> >>> +# this list of conditions and the following disclaimer in the
>>>>> >>> documentation
>>>>> >>> +# and/or other materials provided with the distribution.
>>>>> >>> +# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND
>>>>> >>> CONTRIBUTORS
>>>>> >>> 'AS IS'
>>>>> >>> +# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
>>>>> >>> LIMITED TO,
>>>>> >>> THE
>>>>> >>> +# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A
>>>>> >>> PARTICULAR
>>>>> >>> PURPOSE
>>>>> >>> +# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR
>>>>> >>> CONTRIBUTORS
>>>>> >>> BE
>>>>> >>> +# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY,
>>>>> >>> OR
>>>>> >>> +# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
>>>>> >>> PROCUREMENT OF
>>>>> >>> +# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
>>>>> >>> BUSINESS
>>>>> >>> +# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
>>>>> >>> WHETHER
>>>>> >>> IN
>>>>> >>> +# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
>>>>> >>> OTHERWISE)
>>>>> >>> +# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF
>>>>> >>> ADVISED OF
>>>>> >>> THE
>>>>> >>> +# POSSIBILITY OF SUCH DAMAGE.
>>>>> >>> +from rtemstoolkit import error
>>>>> >>> +from rtemstoolkit import path
>>>>> >>> +from rtemstoolkit import log
>>>>> >>> +from rtemstoolkit import execute
>>>>> >>> +from rtemstoolkit import macros
>>>>> >>> +from datetime import datetime
>>>>> >>> +from . import options
>>>>> >>> +import shutil
>>>>> >>> +import os
>>>>> >>> +try:
>>>>> >>> +    import configparser
>>>>> >>> +except:
>>>>> >>> +    import ConfigParser as configparser
>>>>> >>> +class summary:
>>>>> >>> +    def __init__(self, p_summary_dir):
>>>>> >>> +        self.summary_file_path = path.join(p_summary_dir,
>>>>> >>> 'summary.txt')
>>>>> >>> +        self.index_file_path = path.join(p_summary_dir,
>>>>> >>> 'index.html')
>>>>> >>> +        self.bytes_analyzed = 0
>>>>> >>> +        self.bytes_not_executed = 0
>>>>> >>> +        self.percentage_executed = 0.0
>>>>> >>> +        self.percentage_not_executed = 100.0
>>>>> >>> +        self.ranges_uncovered = 0
>>>>> >>> +        self.branches_uncovered = 0
>>>>> >>> +        self.branches_total = 0
>>>>> >>> +        self.branches_always_taken = 0
>>>>> >>> +        self.branches_never_taken = 0
>>>>> >>> +        self.percentage_branches_covered = 0.0
>>>>> >>> +        self.is_failure = False
>>>>> >>> +    def parse(self):
>>>>> >>> +        if(not path.exists(self.summary_file_path)):
>>>>> >>> +            log.notice('summary file %s does not exist!' %
>>>>> >>> +            self.is_failure = True
>>>>> >>> +            return
>>>>> >>> +        with open(self.summary_file_path,'r') as summary_file:
>>>>> >>> self._get_next_with_colon(summary_file)
>>>>> >>> self._get_next_without_colon(summary_file)
>>>>> >>> +        if len(self.branches_uncovered) > 0 and
>>>>> >>> len(self.branches_total)
>>>>> >>> > 0:
>>>>> >>> +            self.percentage_branches_covered = \
>>>>> >>> +            1 - (float(self.branches_uncovered) /
>>>>> >>> float(self.branches_total))
>>>>> >>> +        else:
>>>>> >>> +        return
>>>>> >>> +    def _get_next_with_colon(self, summary_file):
>>>>> >>> +        line = summary_file.readline()
>>>>> >>> +        if ':' in line:
>>>>> >>> +            return line.split(':')[1].strip()
>>>>> >>> +        else:
>>>>> >>> +            return ''
>>>>> >>> +    def _get_next_without_colon(self, summary_file):
>>>>> >>> +        return line.strip().split(' ')[0]
>>>>> >>> +class report_gen_html:
>>>>> >>> +    def __init__(self, p_symbol_sets_list, build_dir, rtdir):
>>>>> >>> +        self.symbol_sets_list = ['score']
>>>>> >>> +        self.build_dir = build_dir
>>>>> >>> +        self.partial_reports_files = list(["index.html",
>>>>> >>> "summary.txt"])
>>>>> >>> +        self.number_of_columns = 1
>>>>> >>> +        self.covoar_src_path = path.join(rtdir, 'covoar')
>>>>> >>> +    def _find_partial_reports(self):
>>>>> >>> +        partial_reports = {}
>>>>> >>> +        for symbol_set in self.symbol_sets_list:
>>>>> >>> +            set_summary = summary(path.join(self.build_dir,
>>>>> >>> "coverage",
>>>>> >>> +                                  symbol_set))
>>>>> >>> +            set_summary.parse()
>>>>> >>> +            partial_reports[symbol_set] = set_summary
>>>>> >>> +        return partial_reports
>>>>> >>> +    def _prepare_head_section(self):
>>>>> >>> +        head_section = '''
>>>>> >>> +        <head>
>>>>> >>> +        <title>RTEMS coverage report</title>
>>>>> >>> +        <style type="text/css">
>>>>> >>> +            progress[value] {
>>>>> >>> +              -webkit-appearance: none;
>>>>> >>> +               appearance: none;
>>>>> >>> +              width: 150px;
>>>>> >>> +              height: 15px;
>>>>> >>> +        </style>
>>>>> >>> +        </head>'''
>>>>> >>> +        return head_section
>>>>> >>> +    def _prepare_index_content(self, partial_reports):
>>>>> >>> +        header = "<h1> RTEMS coverage analysis report </h1>"
>>>>> >>> +        header += "<h3>Coverage reports by symbols sets:</h3>"
>>>>> >>> +        table = "<table>"
>>>>> >>> +        table += self._header_row()
>>>>> >>> +        for symbol_set in partial_reports:
>>>>> >>> +            table += self._row(symbol_set,
>>>>> >>> partial_reports[symbol_set])
>>>>> >>> +        table += "</table> </br>"
>>>>> >>> +        timestamp = "Analysis performed on " +
>>>>> >>> datetime.now().ctime()
>>>>> >>> +        return "<body>\n" + header + table + timestamp +
>>>>> >>> "\n</body>"
>>>>> >>> +    def _row(self, symbol_set, summary):
>>>>> >>> +        row = "<tr>"
>>>>> >>> +        row += "<td>" + symbol_set + "</td>"
>>>>> >>> +        if summary.is_failure:
>>>>> >>> +            row += ' <td colspan="' +
>>>>> >>> str(self.number_of_columns-1) \
>>>>> >>> +            + '" style="background-color:red">FAILURE</td>'
>>>>> >>> +        else:
>>>>> >>> +            row += " <td>" +
>>>>> >>> self._link(summary.index_file_path,"Index")
>>>>> >>> +            + "</td>"
>>>>> >>> +            row += " <td>" +
>>>>> >>> self._link(summary.summary_file_path,"Summary") \
>>>>> >>> +            + "</td>"
>>>>> >>> +            row += " <td>" + summary.bytes_analyzed + "</td>"
>>>>> >>> +            row += " <td>" + summary.bytes_not_executed + "</td>"
>>>>> >>> +            row += " <td>" + summary.ranges_uncovered + "</td>"
>>>>> >>> +            row += " <td>" + summary.percentage_executed +
>>>>> >>> "%</td>"
>>>>> >>> +            row += " <td>" + summary.percentage_not_executed +
>>>>> >>> "%</td>"
>>>>> >>> +            row += ' <td><progress value="' +
>>>>> >>> summary.percentage_executed \
>>>>> >>> +            + '" max="100"></progress></td>'
>>>>> >>> +            row += " <td>" + summary.branches_uncovered + "</td>"
>>>>> >>> +            row += " <td>" + summary.branches_total + "</td>"
>>>>> >>> +            row += " <td> {:.3%}
>>>>> >>> </td>".format(summary.percentage_branches_covered)
>>>>> >>> +            row += ' <td><progress value="{:.3}"
>>>>> >>> max="100"></progress></td>'.format(100*summary.percentage_branches_covered)
>>>>> >>> +            row += "</tr>\n"
>>>>> >>> +        return row
>>>>> >>> +    def _header_row(self):
>>>>> >>> +        row = "<tr>"
>>>>> >>> +        row += "<th> Symbols set name </th>"
>>>>> >>> +        row += "<th> Index file </th>"
>>>>> >>> +        row += "<th> Summary file </th>"
>>>>> >>> +        row += "<th> Bytes analyzed </th>"
>>>>> >>> +        row += "<th> Bytes not executed </th>"
>>>>> >>> +        row += "<th> Uncovered ranges </th>"
>>>>> >>> +        row += "<th> Percentage covered </th>"
>>>>> >>> +        row += "<th> Percentage uncovered </th>"
>>>>> >>> +        row += "<th> Instruction coverage </th>"
>>>>> >>> +        row += "<th> Branches uncovered </th>"
>>>>> >>> +        row += "<th> Branches total </th>"
>>>>> >>> +        row += "<th> Branches covered percentage </th>"
>>>>> >>> +        row += "<th> Branches coverage </th>"
>>>>> >>> +        row += "</tr>\n"
>>>>> >>> +        self.number_of_columns = row.count('<th>')
>>>>> >>> +        return row
>>>>> >>> +    def _link(self, address, text):
>>>>> >>> +        return '<a href="' + address + '">' + text + '</a>'
>>>>> >>> +    def _create_index_file(self, head_section, content):
>>>>> >>> +        with open(path.join(self.build_dir,"report.html"),'w') as
>>>>> >>> f:
>>>>> >>> +            f.write(head_section)
>>>>> >>> +            f.write(content)
>>>>> >>> +    def generate(self):
>>>>> >>> +        partial_reports = self._find_partial_reports()
>>>>> >>> +        head_section = self._prepare_head_section()
>>>>> >>> +        index_content =
>>>>> >>> self._prepare_index_content(partial_reports)
>>>>> >>> +        self._create_index_file(head_section,index_content)
>>>>> >>> +    def add_covoar_src_path(self):
>>>>> >>> +        table_js_path = path.join(self.covoar_src_path,
>>>>> >>> 'table.js')
>>>>> >>> +        covoar_css_path = path.join(self.covoar_src_path,
>>>>> >>> 'covoar.css')
>>>>> >>> +            symbol_set_dir = path.join(self.build_dir, "coverage",
>>>>> >>> symbol_set)
>>>>> >>> +            html_files = os.listdir(symbol_set_dir)
>>>>> >>> +            for html_file in html_files:
>>>>> >>> +                html_file = path.join(symbol_set_dir, html_file)
>>>>> >>> +                if path.exists(html_file) and 'html' in html_file:
>>>>> >>> +                    with open(html_file, 'r') as f:
>>>>> >>> +                        file_data = f.read()
>>>>> >>> +                    file_data = file_data.replace('table.js',
>>>>> >>> table_js_path)
>>>>> >>> +                    file_data = file_data.replace('covoar.css',
>>>>> >>> +                                                  covoar_css_path)
>>>>> >>> +                    with open(html_file, 'w') as f:
>>>>> >>> +                        f.write(file_data)
>>>>> >>> +class build_path_generator(object):
>>>>> >>> +    Generates the build path from the path to executables
>>>>> >>> +    def __init__(self, executables, target):
>>>>> >>> +        self.executables = executables
>>>>> >>> +        self.target = target
>>>>> >>> +    def run(self):
>>>>> >>> +        build_path = '/'
>>>>> >>> +        Path = self.executables[0].split('/')
>>>>> >>> +        for P in Path:
>>>>> >>> +            if P == self.target:
>>>>> >>> +                break;
>>>>> >>> +            else:
>>>>> >>> +                build_path = path.join(build_path, P)
>>>>> >>> +        return build_path
>>>>> >>> +class symbol_parser(object):
>>>>> >>> +    Parse the symbol sets ini and create custom ini file for
>>>>> >>> covoar
>>>>> >>> +    def __init__(self, symbol_config_path,
>>>>> >>> +                 symbol_select_path, coverage_arg, build_dir):
>>>>> >>> +        self.symbol_select_file = symbol_select_path
>>>>> >>> +        self.symbol_file = symbol_config_path
>>>>> >>> +        self.symbol_sets = {}
>>>>> >>> +        self.cov_arg = coverage_arg
>>>>> >>> +        self.ssets = []
>>>>> >>> +    def parse(self):
>>>>> >>> +        config = configparser.ConfigParser()
>>>>> >>> +        try:
>>>>> >>> +            config.read(self.symbol_file)
>>>>> >>> +            if self.cov_arg:
>>>>> >>> +                self.ssets = self.cov_arg.split(',')
>>>>> >>> +            else:
>>>>> >>> +                self.ssets = config.get('symbol-sets',
>>>>> >>> 'sets').split(',')
>>>>> >>> +                self.ssets = [ sset.encode('utf-8') for sset in
>>>>> >>> self.ssets]
>>>>> >>> +            for sset in self.ssets:
>>>>> >>> +                lib = path.join(self.build_dir,
>>>>> >>> +                                config.get('libraries', sset))
>>>>> >>> +                self.symbol_sets[sset] = lib.encode('utf-8')
>>>>> >>> +        except:
>>>>> >>> +            raise error.general('Symbol set parsing failed')
>>>>> >>> +    def _write_ini(self):
>>>>> >>> +        try:
>>>>> >>> +            sets = ', '.join(self.symbol_sets.keys())
>>>>> >>> +            config.add_section('symbol-sets')
>>>>> >>> +            config.set('symbol-sets', 'sets', sets)
>>>>> >>> +            for key in self.symbol_sets.keys():
>>>>> >>> +                config.add_section(key)
>>>>> >>> +                config.set(key, 'libraries',
>>>>> >>> self.symbol_sets[key])
>>>>> >>> +            with open(self.symbol_select_file, 'w') as conf:
>>>>> >>> +                config.write(conf)
>>>>> >>> +        except:
>>>>> >>> +            raise error.general('write failed')
>>>>> >>> +    def run(self):
>>>>> >>> +        self.parse()
>>>>> >>> +        self._write_ini()
>>>>> >>> +class covoar(object):
>>>>> >>> +    Covoar runner
>>>>> >>> +    def __init__(self, base_result_dir, config_dir, executables,
>>>>> >>> explanations_txt):
>>>>> >>> +        self.base_result_dir = base_result_dir
>>>>> >>> +        self.config_dir = config_dir
>>>>> >>> +        self.executables = ' '.join(executables)
>>>>> >>> +        self.explanations_txt = explanations_txt
>>>>> >>> +        self.project_name = 'RTEMS-5'
>>>>> >>> +    def run(self, set_name, symbol_file):
>>>>> >>> +        covoar_result_dir = path.join(self.base_result_dir,
>>>>> >>> set_name)
>>>>> >>> +        if (not path.exists(covoar_result_dir)):
>>>>> >>> +            path.mkdir(covoar_result_dir)
>>>>> >>> +        if (not path.exists(symbol_file)):
>>>>> >>> +            raise error.general('symbol set file: coverage %s was
>>>>> >>> not
>>>>> >>> created for covoar, skipping %s'% (symbol_file, set_name))
>>>>> >>> +        command = ('covoar -S ' + symbol_file
>>>>> >>> +                  + ' -O ' + covoar_result_dir
>>>>> >>> +                  + ' -E ' + self.explanations_txt
>>>>> >>> +                  + ' -p ' + self.project_name + ' ' +
>>>>> >>> self.executables)
>>>>> >>> +        log.notice('Running covoar for %s' % (set_name))
>>>>> >>> +        print( 'covoar results directory:\n' + covoar_result_dir )
>>>>> >>> +        executor = execute.execute(verbose = True, output =
>>>>> >>> self.output_handler)
>>>>> >>> +        exit_code = executor.shell(command, cwd=os.getcwd())
>>>>> >>> +        if (exit_code[0] != 0):
>>>>> >>> +            raise error.general('covoar failure exit code: %d' %
>>>>> >>> (exit_code[0]))
>>>>> >>> +        log.notice('Coverage run for %s finished successfully.' %
>>>>> >>> (set_name))
>>>>> >>> log.notice('-----------------------------------------------')
>>>>> >>> +    def output_handler(self, text):
>>>>> >>> +        log.notice('%s' % (text))
>>>>> >>> +class coverage_run(object):
>>>>> >>> +    Coverage analysis support for rtems-test
>>>>> >>> +    def __init__(self, p_macros, coverage_arg, target):
>>>>> >>> +        Constructor
>>>>> >>> +        self.macros = p_macros
>>>>> >>> +        self.build_dir = self.macros['_cwd']
>>>>> >>> self.macros.expand(self.macros['cov_explanations'])
>>>>> >>> +        self.test_dir = path.join(self.build_dir, 'coverage')
>>>>> >>> +        if (not path.exists(self.test_dir)):
>>>>> >>> +            path.mkdir(self.test_dir)
>>>>> >>> +        self.rtdir = path.abspath(self.macros['_rtdir'])
>>>>> >>> +        self.rtscripts =
>>>>> >>> self.macros.expand(self.macros['_rtscripts'])
>>>>> >>> +        self.coverage_config_path = path.join(self.rtscripts,
>>>>> >>> 'coverage')
>>>>> >>> +        self.symbol_config_path =
>>>>> >>> path.join(self.coverage_config_path,
>>>>> >>> +                                            'symbol-sets.ini')
>>>>> >>> +        self.symbol_select_path =
>>>>> >>> +                                            'symbol-select.ini')
>>>>> >>> +        self.executables = None
>>>>> >>> +        self.symbol_sets = []
>>>>> >>> +        self.no_clean = int(self.macros['_no_clean'])
>>>>> >>> +        self.report_format = self.macros['cov_report_format']
>>>>> >>> +        self.coverage_arg = coverage_arg
>>>>> >>> +    def run(self):
>>>>> >>> +        try:
>>>>> >>> +            if self.executables is None:
>>>>> >>> +                raise error.general('no test executables
>>>>> >>> provided.')
>>>>> >>> +            build_dir = build_path_generator(self.executables,
>>>>> >>> self.target).run()
>>>>> >>> +            parser = symbol_parser(self.symbol_config_path,
>>>>> >>> +                                   self.symbol_select_path,
>>>>> >>> +                                   self.coverage_arg,
>>>>> >>> +                                   build_dir)
>>>>> >>> +            parser.run()
>>>>> >>> +            covoar_runner = covoar(self.test_dir,
>>>>> >>> +                                   self.executables,
>>>>> >>> self.explanations_txt)
>>>>> >>> +            covoar_runner.run('score', self.symbol_select_path)
>>>>> >>> +            self._generate_reports();
>>>>> >>> +            self._summarize();
>>>>> >>> +        finally:
>>>>> >>> +            self._cleanup();
>>>>> >>> +    def _generate_reports(self):
>>>>> >>> +        log.notice('Generating reports')
>>>>> >>> +        if self.report_format == 'html':
>>>>> >>> +            report = report_gen_html(self.symbol_sets,
>>>>> >>> +                                     self.build_dir,
>>>>> >>> +                                     self.rtdir)
>>>>> >>> +            report.generate()
>>>>> >>> +            report.add_covoar_src_path()
>>>>> >>> +    def _cleanup(self):
>>>>> >>> +        if not self.no_clean:
>>>>> >>> +            log.notice('***Cleaning tempfiles***')
>>>>> >>> +            for exe in self.executables:
>>>>> >>> +                trace_file = exe + '.cov'
>>>>> >>> +                if path.exists(trace_file):
>>>>> >>> +                    os.remove(trace_file)
>>>>> >>> +    def _summarize(self):
>>>>> >>> +        log.notice('Coverage analysis finished. You can find
>>>>> >>> results in
>>>>> >>> %s' % (self.build_dir))
>>>>> >>> diff --git a/tester/rt/test.py b/tester/rt/test.py
>>>>> >>> index f4d9b5c..84dff01 100644
>>>>> >>> --- a/tester/rt/test.py
>>>>> >>> +++ b/tester/rt/test.py
>>>>> >>> @@ -48,12 +48,14 @@ from rtemstoolkit import mailer
>>>>> >>>  from rtemstoolkit import reraise
>>>>> >>>  from rtemstoolkit import stacktraces
>>>>> >>>  from rtemstoolkit import version
>>>>> >>> +from rtemstoolkit import check
>>>>> >>>  from . import bsps
>>>>> >>>  from . import config
>>>>> >>>  from . import console
>>>>> >>>  from . import report
>>>>> >>> +from . import coverage
>>>>> >>>  class log_capture(object):
>>>>> >>>      def __init__(self):
>>>>> >>> @@ -147,7 +149,7 @@ class test_run(object):
>>>>> >>>      def run(self):
>>>>> >>>          self.thread = threading.Thread(target = self.runner,
>>>>> >>> -                                       name = 'test[%s]' %
>>>>> >>> path.basename(self.executable))
>>>>> >>> +                            name = 'test[%s]' %
>>>>> >>>          self.thread.start()
>>>>> >>>      def is_alive(self):
>>>>> >>> @@ -214,6 +216,10 @@ def killall(tests):
>>>>> >>>      for test in tests:
>>>>> >>>          test.kill()
>>>>> >>> +def coverage_run(opts, coverage, executables):
>>>>> >>> +    coverage.executables = executables
>>>>> >>> +    coverage.run()
>>>>> >>>  def run(command_path = None):
>>>>> >>>      import sys
>>>>> >>>      tests = []
>>>>> >>> @@ -221,15 +227,16 @@ def run(command_path = None):
>>>>> >>>      opts = None
>>>>> >>>      default_exefilter = '*.exe'
>>>>> >>>      try:
>>>>> >>> -        optargs = { '--rtems-tools': 'The path to the RTEMS
>>>>> >>> tools',
>>>>> >>> -                    '--rtems-bsp':   'The RTEMS BSP to run the
>>>>> >>> test on',
>>>>> >>> -                    '--user-config': 'Path to your local user
>>>>> >>> configuration INI file',
>>>>> >>> -                    '--report-mode': 'Reporting modes, failures
>>>>> >>> (default),all,none',
>>>>> >>> -                    '--list-bsps':   'List the supported BSPs',
>>>>> >>> -                    '--debug-trace': 'Debug trace based on
>>>>> >>> specific
>>>>> >>> flags',
>>>>> >>> -                    '--filter':      'Glob that executables must
>>>>> >>> match
>>>>> >>> to run (default: ' +
>>>>> >>> +        optargs = { '--rtems-tools':    'The path to the RTEMS
>>>>> >>> tools',
>>>>> >>> +                    '--rtems-bsp':      'The RTEMS BSP to run the
>>>>> >>> test
>>>>> >>> on',
>>>>> >>> +                    '--user-config':    'Path to your local user
>>>>> >>> +                    '--report-mode':    'Reporting modes, failures
>>>>> >>> +                    '--list-bsps':      'List the supported BSPs',
>>>>> >>> +                    '--debug-trace':    'Debug trace based on
>>>>> >>> specific
>>>>> >>> flags',
>>>>> >>> +                    '--filter':         'Glob that executables
>>>>> >>> must
>>>>> >>> match to run (default: ' +
>>>>> >>>                                default_exefilter + ')',
>>>>> >>> -                    '--stacktrace':  'Dump a stack trace on a user
>>>>> >>> termination (^C)' }
>>>>> >>> +                    '--stacktrace':     'Dump a stack trace on a
>>>>> >>> user
>>>>> >>> termination (^C)',
>>>>> >>> +                    '--coverage':       'Perform coverage analysis
>>>>> >>> of
>>>>> >>> test executables.'}
>>>>> >>>          mailer.append_options(optargs)
>>>>> >>>          opts = options.load(sys.argv,
>>>>> >>>                              optargs = optargs,
>>>>> >>> @@ -279,6 +286,15 @@ def run(command_path = None):
>>>>> >>>              raise error.general('RTEMS BSP not provided or an
>>>>> >>> invalid
>>>>> >>> option')
>>>>> >>>          bsp = config.load(bsp[1], opts)
>>>>> >>>          bsp_config = opts.defaults.expand(opts.defaults['tester'])
>>>>> >>> +        coverage_enabled = opts.find_arg('--coverage')
>>>>> >>> +        if coverage_enabled:
>>>>> >>> +            if len(coverage_enabled) == 2:
>>>>> >> Is this to check if sets have been provided to
>>>>> >> --coverage=score,sapi, that
>>>>> >> kind of thing? If so the variable name coverage_enabled doesn't make
>>>>> >> sense
>>>>> >> any more. Probably if symbol_sets and if len(symbol_sets) will make
>>>>> >> more
>>>>> >> sense for both cases.
>>>>> > That's a good point.
>>>>> > How about changing it to just 'coverage' instead ?
>>>>> > Because it's still checking whether the option is given or
>>>>> > not. symbol_sets might create confusion.
>>>>> > Will that be OK ?
>>>>> That name might collide with your class object (coverage)?
>>>> That's actually why I kept it as coverage_enabled.
>>>> I think we can go for coverage_option (?)
>>>>> >>> +                coverage_runner =
>>>>> >>> coverage.coverage_run(opts.defaults,
>>>>> >>> coverage_enabled[1],
>>>>> >>> opts.defaults['target'])
>>>>> >>> +            else:
>>>>> >>> +                coverage_runner =
>>>>> >>> 0,
>>>>> >>>          report_mode = opts.find_arg('--report-mode')
>>>>> >>>          if report_mode:
>>>>> >>>              if report_mode[1] != 'failures' and \
>>>>> >>> @@ -365,6 +381,8 @@ def run(command_path = None):
>>>>> >>>                      reports.failures(),
>>>>> >>>                      'Log', '===', ''] + output.get()
>>>>> >>>              mail.send(to_addr, subject, os.linesep.join(body))
>>>>> >>> +            coverage_run(opts, coverage_runner, executables)
>>>>> >>>      except error.general as gerr:
>>>>> >>>          print(gerr)
>>>>> >>> diff --git a/tester/rtems/testing/bsps/leon3-qemu-cov.ini
>>>>> >>> b/tester/rtems/testing/bsps/leon3-qemu-cov.ini
>>>>> >>> index 6b5e7e6..2f89117 100644
>>>>> >>> --- a/tester/rtems/testing/bsps/leon3-qemu-cov.ini
>>>>> >>> +++ b/tester/rtems/testing/bsps/leon3-qemu-cov.ini
>>>>> >>> @@ -31,9 +31,10 @@
>>>>> >>>  # The Leon 3 QEMU BSP
>>>>> >>> -[leon3-qemu]
>>>>> >>> +[leon3-qemu-cov]
>>>>> >>>  bsp               = leon3-qemu
>>>>> >>>  arch              = sparc
>>>>> >>> +target            = sparc-rtems5
>>>>> >>>  tester            = %{_rtscripts}/qemu.cfg
>>>>> >>>  bsp_qemu_opts     = %{qemu_opts_base} -M leon3_generic
>>>>> >>>  bsp_qemu_cov_opts = -exec-trace %{test_executable}.cov
>>>>> >>> diff --git a/tester/rtems/testing/coverage/symbol-sets.ini
>>>>> >>> b/tester/rtems/testing/coverage/symbol-sets.ini
>>>>> >>> index 0000000..a2ec7bc
>>>>> >>> --- /dev/null
>>>>> >>> +++ b/tester/rtems/testing/coverage/symbol-sets.ini
>>>>> >>> @@ -0,0 +1,36 @@
>>>>> >>> +# Copyright 2018 Chris Johns (chrisj at rtems.org)
>>>>> >>> without
>>>>> >>> conditions are
>>>>> >>> met:
>>>>> >>> copyright
>>>>> >>> notice,
>>>>> >>> copyright
>>>>> >>> notice,
>>>>> >>> documentation
>>>>> >>> CONTRIBUTORS
>>>>> >>> "AS IS"
>>>>> >>> LIMITED TO,
>>>>> >>> THE
>>>>> >>> PARTICULAR
>>>>> >>> PURPOSE
>>>>> >>> CONTRIBUTORS
>>>>> >>> BE
>>>>> >>> OR
>>>>> >>> PROCUREMENT OF
>>>>> >>> BUSINESS
>>>>> >>> WHETHER
>>>>> >>> IN
>>>>> >>> OTHERWISE)
>>>>> >>> ADVISED OF
>>>>> >>> THE
>>>>> >>> +[symbol-sets]
>>>>> >>> +sets = score,rtems
>>>>> >>> +[libraries]
>>>>> >>> +score = @BUILD-TARGET@/c/@BSP@/cpukit/score/libscore.a
>>>>> >>> +rtems = @BUILD-TARGET@/c/@BSP@/cpukit/rtems/librtems.a
>>>>> >>> diff --git a/tester/rtems/testing/qemu.cfg
>>>>> >>> b/tester/rtems/testing/qemu.cfg
>>>>> >>> index bfcd2f5..52a3752 100644
>>>>> >>> --- a/tester/rtems/testing/qemu.cfg
>>>>> >>> +++ b/tester/rtems/testing/qemu.cfg
>>>>> >>> @@ -51,8 +51,8 @@
>>>>> >>>  # Qemu common option patterns.
>>>>> >>> -#%define qemu_opts_base   -no-reboot -monitor none -serial stdio
>>>>> >>> -nographic
>>>>> >>> -%define qemu_opts_base   -no-reboot -serial null -serial mon:stdio
>>>>> >>> -nographic
>>>>> >>> +%define qemu_opts_base   -no-reboot -monitor none -serial stdio
>>>>> >>> -nographic
>>>>> >>> +#%define qemu_opts_base   -no-reboot -serial null -serial
>>>>> >>> mon:stdio
>>>>> >>> -nographic
>>>>> >>>  %define qemu_opts_no_net -net none
>>>>> >>> 2.14.3
>>>>> >>> _______________________________________________
>>>>> >>> devel mailing list
>>>>> >>> devel at rtems.org
>>>>> >>> http://lists.rtems.org/mailman/listinfo/devel
>>>>> > devel mailing list
>>>>> > devel at rtems.org
