[PATCH v2] tester: Add script to generate html coverage report from covoar output
Cillian O'Donnell
cpodonnell8 at gmail.com
Thu May 31 21:15:38 UTC 2018
On Thu, 31 May 2018, 22:03 Vijay Kumar Banerjee, <vijaykumar9597 at gmail.com>
wrote:
> On 1 June 2018 at 02:14, Cillian O'Donnell <cpodonnell8 at gmail.com> wrote:
>> There is now a seperate bsp config for coverage, leon3-qemu-cov. That is
>> enough to trigger coverage now and --coverage could be reserved for picking
>> sets, probably renamed to --coverage-sets=... Or require sets to be chosen
>> --coverage-sets=all or specific sets --coverage-sets=score,sapi,core
>> Actually the idea of having separate bsp configs for cov
> in each of the bsps will create a lot of files. The intention is
> to make it simple for the user. just adding --coverage
> should run coverage analysis. There's a plan to include
> the 'coverage' section into the bsp ini file, and hence the user wouldn't
> have to keep switching the bsp config files.
Actually that's exactly the way I had it working before Chris' recent
changes, he had a look at the way it's working and chose to create seperate
bsp config files. That may be the way he'd prefer. This was before the
--coverage option had another use other than triggering coverage, so his
thoughts may have changed on it.
> The idea of modifying it to --coverage-sets=all ;
> --coverage-sets=set1,set2,set3..... can surely be implemented
> in place of --coverage ; --coverage=set1,set2....
>> On Thu, 31 May 2018, 21:29 Vijay Kumar Banerjee, <
>> vijaykumar9597 at gmail.com> wrote:
>>> On 1 June 2018 at 01:57, Cillian O'Donnell <cpodonnell8 at gmail.com>
>>> wrote:
>>>> So is it checking whether it's --coverage or --coverage=set1,set2? Are
>>>> those the 2 possibilities your checking?
>>>> Yes, right. :)
>>>> On Thu, 31 May 2018, 20:52 Vijay Kumar Banerjee, <
>>>>> On 1 June 2018 at 01:19, Gedare Bloom <gedare at rtems.org> wrote:
>>>>>> On Thu, May 31, 2018 at 3:47 PM, Vijay Kumar Banerjee
>>>>>> <vijaykumar9597 at gmail.com> wrote:
>>>>>> > On 1 June 2018 at 01:07, Cillian O'Donnell <cpodonnell8 at gmail.com>
>>>>>> wrote:
>>>>>> >> On 31 May 2018 at 19:07, Vijay Kumar Banerjee <
>>>>>> >> wrote:
>>>>>> >>> Add support in tester to run covoar and generate an html report to
>>>>>> >>> display
>>>>>> >>> the summary of the coverage reports generated from covoar.
>>>>>> >>> Co-authored-by : Cillian O'Donnell <cpodonnell8 at gmail.com>
>>>>>> >>> tester/rt/coverage.py | 379
>>>>>> >>> tester/rt/test.py | 36 ++-
>>>>>> >>> tester/rtems/testing/bsps/leon3-qemu-cov.ini | 3 +-
>>>>>> >>> tester/rtems/testing/coverage/symbol-sets.ini | 36 +++
>>>>>> >>> tester/rtems/testing/qemu.cfg | 4 +-
>>>>>> >>> 5 files changed, 446 insertions(+), 12 deletions(-)
>>>>>> >>> create mode 100644 tester/rt/coverage.py
>>>>>> >>> create mode 100644 tester/rtems/testing/coverage/symbol-sets.ini
>>>>>> >>> diff --git a/tester/rt/coverage.py b/tester/rt/coverage.py
>>>>>> >>> new file mode 100644
>>>>>> >>> index 0000000..25fbb9d
>>>>>> >>> --- /dev/null
>>>>>> >>> +++ b/tester/rt/coverage.py
>>>>>> >>> @@ -0,0 +1,379 @@
>>>>>> >>> +# RTEMS Tools Project (http://www.rtems.org/)
>>>>>> >>> +# Copyright 2014 Krzysztof Miesowicz (
>>>>>> krzysztof.miesowicz at gmail.com)
>>>>>> >>> +# All rights reserved.
>>>>>> >>> +# This file is part of the RTEMS Tools package in 'rtems-tools'.
>>>>>> >>> +# Redistribution and use in source and binary forms, with or
>>>>>> without
>>>>>> >>> +# modification, are permitted provided that the following
>>>>>> conditions are
>>>>>> >>> met:
>>>>>> >>> +# 1. Redistributions of source code must retain the above
>>>>>> copyright
>>>>>> >>> notice,
>>>>>> >>> +# this list of conditions and the following disclaimer.
>>>>>> >>> +# 2. Redistributions in binary form must reproduce the above
>>>>>> copyright
>>>>>> >>> notice,
>>>>>> >>> +# this list of conditions and the following disclaimer in the
>>>>>> >>> documentation
>>>>>> >>> +# and/or other materials provided with the distribution.
>>>>>> >>> +# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND
>>>>>> CONTRIBUTORS
>>>>>> >>> 'AS IS'
>>>>>> >>> +# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
>>>>>> LIMITED TO,
>>>>>> >>> THE
>>>>>> >>> +# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A
>>>>>> PARTICULAR
>>>>>> >>> PURPOSE
>>>>>> >>> +# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR
>>>>>> CONTRIBUTORS
>>>>>> >>> BE
>>>>>> >>> +# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
>>>>>> EXEMPLARY, OR
>>>>>> >>> +# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
>>>>>> PROCUREMENT OF
>>>>>> >>> +# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
>>>>>> >>> BUSINESS
>>>>>> >>> +# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
>>>>>> WHETHER
>>>>>> >>> IN
>>>>>> >>> +# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
>>>>>> >>> OTHERWISE)
>>>>>> >>> +# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF
>>>>>> ADVISED OF
>>>>>> >>> THE
>>>>>> >>> +# POSSIBILITY OF SUCH DAMAGE.
>>>>>> >>> +from rtemstoolkit import error
>>>>>> >>> +from rtemstoolkit import path
>>>>>> >>> +from rtemstoolkit import log
>>>>>> >>> +from rtemstoolkit import execute
>>>>>> >>> +from rtemstoolkit import macros
>>>>>> >>> +from datetime import datetime
>>>>>> >>> +from . import options
>>>>>> >>> +import shutil
>>>>>> >>> +import os
>>>>>> >>> +try:
>>>>>> >>> + import configparser
>>>>>> >>> +except:
>>>>>> >>> + import ConfigParser as configparser
>>>>>> >>> +class summary:
>>>>>> >>> + def __init__(self, p_summary_dir):
>>>>>> >>> + self.summary_file_path = path.join(p_summary_dir,
>>>>>> 'summary.txt')
>>>>>> >>> + self.index_file_path = path.join(p_summary_dir,
>>>>>> 'index.html')
>>>>>> >>> + self.bytes_analyzed = 0
>>>>>> >>> + self.bytes_not_executed = 0
>>>>>> >>> + self.percentage_executed = 0.0
>>>>>> >>> + self.percentage_not_executed = 100.0
>>>>>> >>> + self.ranges_uncovered = 0
>>>>>> >>> + self.branches_uncovered = 0
>>>>>> >>> + self.branches_total = 0
>>>>>> >>> + self.branches_always_taken = 0
>>>>>> >>> + self.branches_never_taken = 0
>>>>>> >>> + self.percentage_branches_covered = 0.0
>>>>>> >>> + self.is_failure = False
>>>>>> >>> + def parse(self):
>>>>>> >>> + if(not path.exists(self.summary_file_path)):
>>>>>> >>> + log.notice('summary file %s does not exist!' %
>>>>>> >>> + self.is_failure = True
>>>>>> >>> + return
>>>>>> >>> + with open(self.summary_file_path,'r') as summary_file:
>>>>>> self._get_next_with_colon(summary_file)
>>>>>> >>> self._get_next_without_colon(summary_file)
>>>>>> >>> + if len(self.branches_uncovered) > 0 and
>>>>>> len(self.branches_total)
>>>>>> >>> > 0:
>>>>>> >>> + self.percentage_branches_covered = \
>>>>>> >>> + 1 - (float(self.branches_uncovered) /
>>>>>> >>> float(self.branches_total))
>>>>>> >>> + else:
>>>>>> >>> + return
>>>>>> >>> + def _get_next_with_colon(self, summary_file):
>>>>>> >>> + line = summary_file.readline()
>>>>>> >>> + if ':' in line:
>>>>>> >>> + return line.split(':')[1].strip()
>>>>>> >>> + else:
>>>>>> >>> + return ''
>>>>>> >>> + def _get_next_without_colon(self, summary_file):
>>>>>> >>> + return line.strip().split(' ')[0]
>>>>>> >>> +class report_gen_html:
>>>>>> >>> + def __init__(self, p_symbol_sets_list, build_dir, rtdir):
>>>>>> >>> + self.symbol_sets_list = ['score']
>>>>>> >>> + self.build_dir = build_dir
>>>>>> >>> + self.partial_reports_files = list(["index.html",
>>>>>> "summary.txt"])
>>>>>> >>> + self.number_of_columns = 1
>>>>>> >>> + self.covoar_src_path = path.join(rtdir, 'covoar')
>>>>>> >>> + def _find_partial_reports(self):
>>>>>> >>> + partial_reports = {}
>>>>>> >>> + for symbol_set in self.symbol_sets_list:
>>>>>> >>> + set_summary = summary(path.join(self.build_dir,
>>>>>> "coverage",
>>>>>> >>> + symbol_set))
>>>>>> >>> + set_summary.parse()
>>>>>> >>> + partial_reports[symbol_set] = set_summary
>>>>>> >>> + return partial_reports
>>>>>> >>> + def _prepare_head_section(self):
>>>>>> >>> + head_section = '''
>>>>>> >>> + <head>
>>>>>> >>> + <title>RTEMS coverage report</title>
>>>>>> >>> + <style type="text/css">
>>>>>> >>> + progress[value] {
>>>>>> >>> + -webkit-appearance: none;
>>>>>> >>> + appearance: none;
>>>>>> >>> + width: 150px;
>>>>>> >>> + height: 15px;
>>>>>> >>> + </style>
>>>>>> >>> + </head>'''
>>>>>> >>> + return head_section
>>>>>> >>> + def _prepare_index_content(self, partial_reports):
>>>>>> >>> + header = "<h1> RTEMS coverage analysis report </h1>"
>>>>>> >>> + header += "<h3>Coverage reports by symbols sets:</h3>"
>>>>>> >>> + table = "<table>"
>>>>>> >>> + table += self._header_row()
>>>>>> >>> + for symbol_set in partial_reports:
>>>>>> >>> + table += self._row(symbol_set,
>>>>>> partial_reports[symbol_set])
>>>>>> >>> + table += "</table> </br>"
>>>>>> >>> + timestamp = "Analysis performed on " +
>>>>>> datetime.now().ctime()
>>>>>> >>> + return "<body>\n" + header + table + timestamp +
>>>>>> "\n</body>"
>>>>>> >>> + def _row(self, symbol_set, summary):
>>>>>> >>> + row = "<tr>"
>>>>>> >>> + row += "<td>" + symbol_set + "</td>"
>>>>>> >>> + if summary.is_failure:
>>>>>> >>> + row += ' <td colspan="' +
>>>>>> str(self.number_of_columns-1) \
>>>>>> >>> + + '" style="background-color:red">FAILURE</td>'
>>>>>> >>> + else:
>>>>>> >>> + row += " <td>" +
>>>>>> self._link(summary.index_file_path,"Index")
>>>>>> >>> + + "</td>"
>>>>>> >>> + row += " <td>" +
>>>>>> >>> self._link(summary.summary_file_path,"Summary") \
>>>>>> >>> + + "</td>"
>>>>>> >>> + row += " <td>" + summary.bytes_analyzed + "</td>"
>>>>>> >>> + row += " <td>" + summary.bytes_not_executed + "</td>"
>>>>>> >>> + row += " <td>" + summary.ranges_uncovered + "</td>"
>>>>>> >>> + row += " <td>" + summary.percentage_executed +
>>>>>> "%</td>"
>>>>>> >>> + row += " <td>" + summary.percentage_not_executed +
>>>>>> "%</td>"
>>>>>> >>> + row += ' <td><progress value="' +
>>>>>> >>> summary.percentage_executed \
>>>>>> >>> + + '" max="100"></progress></td>'
>>>>>> >>> + row += " <td>" + summary.branches_uncovered + "</td>"
>>>>>> >>> + row += " <td>" + summary.branches_total + "</td>"
>>>>>> >>> + row += " <td> {:.3%}
>>>>>> >>> </td>".format(summary.percentage_branches_covered)
>>>>>> >>> + row += ' <td><progress value="{:.3}"
>>>>>> max="100"></progress></td>'.format(100*summary.percentage_branches_covered)
>>>>>> >>> + row += "</tr>\n"
>>>>>> >>> + return row
>>>>>> >>> + def _header_row(self):
>>>>>> >>> + row = "<tr>"
>>>>>> >>> + row += "<th> Symbols set name </th>"
>>>>>> >>> + row += "<th> Index file </th>"
>>>>>> >>> + row += "<th> Summary file </th>"
>>>>>> >>> + row += "<th> Bytes analyzed </th>"
>>>>>> >>> + row += "<th> Bytes not executed </th>"
>>>>>> >>> + row += "<th> Uncovered ranges </th>"
>>>>>> >>> + row += "<th> Percentage covered </th>"
>>>>>> >>> + row += "<th> Percentage uncovered </th>"
>>>>>> >>> + row += "<th> Instruction coverage </th>"
>>>>>> >>> + row += "<th> Branches uncovered </th>"
>>>>>> >>> + row += "<th> Branches total </th>"
>>>>>> >>> + row += "<th> Branches covered percentage </th>"
>>>>>> >>> + row += "<th> Branches coverage </th>"
>>>>>> >>> + row += "</tr>\n"
>>>>>> >>> + self.number_of_columns = row.count('<th>')
>>>>>> >>> + return row
>>>>>> >>> + def _link(self, address, text):
>>>>>> >>> + return '<a href="' + address + '">' + text + '</a>'
>>>>>> >>> + def _create_index_file(self, head_section, content):
>>>>>> >>> + with open(path.join(self.build_dir,"report.html"),'w')
>>>>>> as f:
>>>>>> >>> + f.write(head_section)
>>>>>> >>> + f.write(content)
>>>>>> >>> + def generate(self):
>>>>>> >>> + partial_reports = self._find_partial_reports()
>>>>>> >>> + head_section = self._prepare_head_section()
>>>>>> >>> + index_content =
>>>>>> self._prepare_index_content(partial_reports)
>>>>>> >>> + self._create_index_file(head_section,index_content)
>>>>>> >>> + def add_covoar_src_path(self):
>>>>>> >>> + table_js_path = path.join(self.covoar_src_path,
>>>>>> 'table.js')
>>>>>> >>> + covoar_css_path = path.join(self.covoar_src_path,
>>>>>> 'covoar.css')
>>>>>> >>> + symbol_set_dir = path.join(self.build_dir,
>>>>>> "coverage",
>>>>>> >>> symbol_set)
>>>>>> >>> + html_files = os.listdir(symbol_set_dir)
>>>>>> >>> + for html_file in html_files:
>>>>>> >>> + html_file = path.join(symbol_set_dir, html_file)
>>>>>> >>> + if path.exists(html_file) and 'html' in
>>>>>> html_file:
>>>>>> >>> + with open(html_file, 'r') as f:
>>>>>> >>> + file_data = f.read()
>>>>>> >>> + file_data = file_data.replace('table.js',
>>>>>> >>> table_js_path)
>>>>>> >>> + file_data = file_data.replace('covoar.css',
>>>>>> covoar_css_path)
>>>>>> >>> + with open(html_file, 'w') as f:
>>>>>> >>> + f.write(file_data)
>>>>>> >>> +class build_path_generator(object):
>>>>>> >>> + Generates the build path from the path to executables
>>>>>> >>> + def __init__(self, executables, target):
>>>>>> >>> + self.executables = executables
>>>>>> >>> + self.target = target
>>>>>> >>> + def run(self):
>>>>>> >>> + build_path = '/'
>>>>>> >>> + Path = self.executables[0].split('/')
>>>>>> >>> + for P in Path:
>>>>>> >>> + if P == self.target:
>>>>>> >>> + break;
>>>>>> >>> + else:
>>>>>> >>> + build_path = path.join(build_path, P)
>>>>>> >>> + return build_path
>>>>>> >>> +class symbol_parser(object):
>>>>>> >>> + Parse the symbol sets ini and create custom ini file for
>>>>>> covoar
>>>>>> >>> + def __init__(self, symbol_config_path,
>>>>>> >>> + symbol_select_path, coverage_arg, build_dir):
>>>>>> >>> + self.symbol_select_file = symbol_select_path
>>>>>> >>> + self.symbol_file = symbol_config_path
>>>>>> >>> + self.symbol_sets = {}
>>>>>> >>> + self.cov_arg = coverage_arg
>>>>>> >>> + self.ssets = []
>>>>>> >>> + def parse(self):
>>>>>> >>> + config = configparser.ConfigParser()
>>>>>> >>> + try:
>>>>>> >>> + config.read(self.symbol_file)
>>>>>> >>> + if self.cov_arg:
>>>>>> >>> + self.ssets = self.cov_arg.split(',')
>>>>>> >>> + else:
>>>>>> >>> + self.ssets = config.get('symbol-sets',
>>>>>> >>> 'sets').split(',')
>>>>>> >>> + self.ssets = [ sset.encode('utf-8') for sset in
>>>>>> >>> self.ssets]
>>>>>> >>> + for sset in self.ssets:
>>>>>> >>> + lib = path.join(self.build_dir,
>>>>>> >>> + config.get('libraries', sset))
>>>>>> >>> + self.symbol_sets[sset] = lib.encode('utf-8')
>>>>>> >>> + except:
>>>>>> >>> + raise error.general('Symbol set parsing failed')
>>>>>> >>> + def _write_ini(self):
>>>>>> >>> + try:
>>>>>> >>> + sets = ', '.join(self.symbol_sets.keys())
>>>>>> >>> + config.add_section('symbol-sets')
>>>>>> >>> + config.set('symbol-sets', 'sets', sets)
>>>>>> >>> + for key in self.symbol_sets.keys():
>>>>>> >>> + config.add_section(key)
>>>>>> >>> + config.set(key, 'libraries',
>>>>>> self.symbol_sets[key])
>>>>>> >>> + with open(self.symbol_select_file, 'w') as conf:
>>>>>> >>> + config.write(conf)
>>>>>> >>> + except:
>>>>>> >>> + raise error.general('write failed')
>>>>>> >>> + def run(self):
>>>>>> >>> + self.parse()
>>>>>> >>> + self._write_ini()
>>>>>> >>> +class covoar(object):
>>>>>> >>> + Covoar runner
>>>>>> >>> + def __init__(self, base_result_dir, config_dir, executables,
>>>>>> >>> explanations_txt):
>>>>>> >>> + self.base_result_dir = base_result_dir
>>>>>> >>> + self.config_dir = config_dir
>>>>>> >>> + self.executables = ' '.join(executables)
>>>>>> >>> + self.explanations_txt = explanations_txt
>>>>>> >>> + self.project_name = 'RTEMS-5'
>>>>>> >>> + def run(self, set_name, symbol_file):
>>>>>> >>> + covoar_result_dir = path.join(self.base_result_dir,
>>>>>> set_name)
>>>>>> >>> + if (not path.exists(covoar_result_dir)):
>>>>>> >>> + path.mkdir(covoar_result_dir)
>>>>>> >>> + if (not path.exists(symbol_file)):
>>>>>> >>> + raise error.general('symbol set file: coverage %s
>>>>>> was not
>>>>>> >>> created for covoar, skipping %s'% (symbol_file, set_name))
>>>>>> >>> + command = ('covoar -S ' + symbol_file
>>>>>> >>> + + ' -O ' + covoar_result_dir
>>>>>> >>> + + ' -E ' + self.explanations_txt
>>>>>> >>> + + ' -p ' + self.project_name + ' ' +
>>>>>> self.executables)
>>>>>> >>> + log.notice('Running covoar for %s' % (set_name))
>>>>>> >>> + print( 'covoar results directory:\n' + covoar_result_dir
>>>>>> >>> + executor = execute.execute(verbose = True, output =
>>>>>> >>> self.output_handler)
>>>>>> >>> + exit_code = executor.shell(command, cwd=os.getcwd())
>>>>>> >>> + if (exit_code[0] != 0):
>>>>>> >>> + raise error.general('covoar failure exit code: %d' %
>>>>>> >>> (exit_code[0]))
>>>>>> >>> + log.notice('Coverage run for %s finished successfully.' %
>>>>>> >>> (set_name))
>>>>>> log.notice('-----------------------------------------------')
>>>>>> >>> + def output_handler(self, text):
>>>>>> >>> + log.notice('%s' % (text))
>>>>>> >>> +class coverage_run(object):
>>>>>> >>> + Coverage analysis support for rtems-test
>>>>>> >>> + def __init__(self, p_macros, coverage_arg, target):
>>>>>> >>> + Constructor
>>>>>> >>> + self.macros = p_macros
>>>>>> >>> + self.build_dir = self.macros['_cwd']
>>>>>> >>> self.macros.expand(self.macros['cov_explanations'])
>>>>>> >>> + self.test_dir = path.join(self.build_dir, 'coverage')
>>>>>> >>> + if (not path.exists(self.test_dir)):
>>>>>> >>> + path.mkdir(self.test_dir)
>>>>>> >>> + self.rtdir = path.abspath(self.macros['_rtdir'])
>>>>>> >>> + self.rtscripts =
>>>>>> self.macros.expand(self.macros['_rtscripts'])
>>>>>> >>> + self.coverage_config_path = path.join(self.rtscripts,
>>>>>> >>> 'coverage')
>>>>>> >>> + self.symbol_config_path =
>>>>>> path.join(self.coverage_config_path,
>>>>>> >>> + 'symbol-sets.ini')
>>>>>> >>> + self.symbol_select_path =
>>>>>> >>> + 'symbol-select.ini')
>>>>>> >>> + self.executables = None
>>>>>> >>> + self.symbol_sets = []
>>>>>> >>> + self.no_clean = int(self.macros['_no_clean'])
>>>>>> >>> + self.report_format = self.macros['cov_report_format']
>>>>>> >>> + self.coverage_arg = coverage_arg
>>>>>> >>> + def run(self):
>>>>>> >>> + try:
>>>>>> >>> + if self.executables is None:
>>>>>> >>> + raise error.general('no test executables
>>>>>> provided.')
>>>>>> >>> + build_dir = build_path_generator(self.executables,
>>>>>> >>> self.target).run()
>>>>>> >>> + parser = symbol_parser(self.symbol_config_path,
>>>>>> >>> + self.symbol_select_path,
>>>>>> >>> + self.coverage_arg,
>>>>>> >>> + build_dir)
>>>>>> >>> + parser.run()
>>>>>> >>> + covoar_runner = covoar(self.test_dir,
>>>>>> >>> + self.executables,
>>>>>> >>> self.explanations_txt)
>>>>>> >>> + covoar_runner.run('score', self.symbol_select_path)
>>>>>> >>> + self._generate_reports();
>>>>>> >>> + self._summarize();
>>>>>> >>> + finally:
>>>>>> >>> + self._cleanup();
>>>>>> >>> + def _generate_reports(self):
>>>>>> >>> + log.notice('Generating reports')
>>>>>> >>> + if self.report_format == 'html':
>>>>>> >>> + report = report_gen_html(self.symbol_sets,
>>>>>> >>> + self.build_dir,
>>>>>> >>> + self.rtdir)
>>>>>> >>> + report.generate()
>>>>>> >>> + report.add_covoar_src_path()
>>>>>> >>> + def _cleanup(self):
>>>>>> >>> + if not self.no_clean:
>>>>>> >>> + log.notice('***Cleaning tempfiles***')
>>>>>> >>> + for exe in self.executables:
>>>>>> >>> + trace_file = exe + '.cov'
>>>>>> >>> + if path.exists(trace_file):
>>>>>> >>> + os.remove(trace_file)
>>>>>> >>> + def _summarize(self):
>>>>>> >>> + log.notice('Coverage analysis finished. You can find
>>>>>> results in
>>>>>> >>> %s' % (self.build_dir))
>>>>>> >>> diff --git a/tester/rt/test.py b/tester/rt/test.py
>>>>>> >>> index f4d9b5c..84dff01 100644
>>>>>> >>> --- a/tester/rt/test.py
>>>>>> >>> +++ b/tester/rt/test.py
>>>>>> >>> @@ -48,12 +48,14 @@ from rtemstoolkit import mailer
>>>>>> >>> from rtemstoolkit import reraise
>>>>>> >>> from rtemstoolkit import stacktraces
>>>>>> >>> from rtemstoolkit import version
>>>>>> >>> +from rtemstoolkit import check
>>>>>> >>> from . import bsps
>>>>>> >>> from . import config
>>>>>> >>> from . import console
>>>>>> >>> from . import report
>>>>>> >>> +from . import coverage
>>>>>> >>> class log_capture(object):
>>>>>> >>> def __init__(self):
>>>>>> >>> @@ -147,7 +149,7 @@ class test_run(object):
>>>>>> >>> def run(self):
>>>>>> >>> self.thread = threading.Thread(target = self.runner,
>>>>>> >>> - name = 'test[%s]' %
>>>>>> >>> path.basename(self.executable))
>>>>>> >>> + name = 'test[%s]' %
>>>>>> >>> self.thread.start()
>>>>>> >>> def is_alive(self):
>>>>>> >>> @@ -214,6 +216,10 @@ def killall(tests):
>>>>>> >>> for test in tests:
>>>>>> >>> test.kill()
>>>>>> >>> +def coverage_run(opts, coverage, executables):
>>>>>> >>> + coverage.executables = executables
>>>>>> >>> + coverage.run()
>>>>>> >>> def run(command_path = None):
>>>>>> >>> import sys
>>>>>> >>> tests = []
>>>>>> >>> @@ -221,15 +227,16 @@ def run(command_path = None):
>>>>>> >>> opts = None
>>>>>> >>> default_exefilter = '*.exe'
>>>>>> >>> try:
>>>>>> >>> - optargs = { '--rtems-tools': 'The path to the RTEMS
>>>>>> tools',
>>>>>> >>> - '--rtems-bsp': 'The RTEMS BSP to run the
>>>>>> test on',
>>>>>> >>> - '--user-config': 'Path to your local user
>>>>>> >>> configuration INI file',
>>>>>> >>> - '--report-mode': 'Reporting modes, failures
>>>>>> >>> (default),all,none',
>>>>>> >>> - '--list-bsps': 'List the supported BSPs',
>>>>>> >>> - '--debug-trace': 'Debug trace based on
>>>>>> specific
>>>>>> >>> flags',
>>>>>> >>> - '--filter': 'Glob that executables must
>>>>>> match
>>>>>> >>> to run (default: ' +
>>>>>> >>> + optargs = { '--rtems-tools': 'The path to the RTEMS
>>>>>> tools',
>>>>>> >>> + '--rtems-bsp': 'The RTEMS BSP to run
>>>>>> the test
>>>>>> >>> on',
>>>>>> >>> + '--user-config': 'Path to your local user
>>>>>> >>> + '--report-mode': 'Reporting modes,
>>>>>> failures
>>>>>> >>> + '--list-bsps': 'List the supported
>>>>>> BSPs',
>>>>>> >>> + '--debug-trace': 'Debug trace based on
>>>>>> specific
>>>>>> >>> flags',
>>>>>> >>> + '--filter': 'Glob that executables
>>>>>> must
>>>>>> >>> match to run (default: ' +
>>>>>> >>> default_exefilter + ')',
>>>>>> >>> - '--stacktrace': 'Dump a stack trace on a
>>>>>> user
>>>>>> >>> termination (^C)' }
>>>>>> >>> + '--stacktrace': 'Dump a stack trace on a
>>>>>> user
>>>>>> >>> termination (^C)',
>>>>>> >>> + '--coverage': 'Perform coverage
>>>>>> analysis of
>>>>>> >>> test executables.'}
>>>>>> >>> mailer.append_options(optargs)
>>>>>> >>> opts = options.load(sys.argv,
>>>>>> >>> optargs = optargs,
>>>>>> >>> @@ -279,6 +286,15 @@ def run(command_path = None):
>>>>>> >>> raise error.general('RTEMS BSP not provided or an
>>>>>> invalid
>>>>>> >>> option')
>>>>>> >>> bsp = config.load(bsp[1], opts)
>>>>>> >>> bsp_config =
>>>>>> opts.defaults.expand(opts.defaults['tester'])
>>>>>> >>> + coverage_enabled = opts.find_arg('--coverage')
>>>>>> >>> + if coverage_enabled:
>>>>>> >>> + if len(coverage_enabled) == 2:
>>>>>> >> Is this to check if sets have been provided to
>>>>>> --coverage=score,sapi, that
>>>>>> >> kind of thing? If so the variable name coverage_enabled doesn't
>>>>>> make sense
>>>>>> >> any more. Probably if symbol_sets and if len(symbol_sets) will
>>>>>> make more
>>>>>> >> sense for both cases.
>>>>>> > That's a good point.
>>>>>> > How about changing it to just 'coverage' instead ?
>>>>>> > Because it's still checking whether the option is given or
>>>>>> > not. symbol_sets might create confusion.
>>>>>> > Will that be OK ?
>>>>>> That name might collide with your class object (coverage)?
>>>>> That's actually why I kept it as coverage_enabled.
>>>>> I think we can go for coverage_option (?)
>>>>>> >>> + coverage_runner =
>>>>>> coverage.coverage_run(opts.defaults,
>>>>>> coverage_enabled[1],
>>>>>> opts.defaults['target'])
>>>>>> >>> + else:
>>>>>> >>> + coverage_runner =
>>>>>> >>> 0,
>>>>>> >>> report_mode = opts.find_arg('--report-mode')
>>>>>> >>> if report_mode:
>>>>>> >>> if report_mode[1] != 'failures' and \
>>>>>> >>> @@ -365,6 +381,8 @@ def run(command_path = None):
>>>>>> >>> reports.failures(),
>>>>>> >>> 'Log', '===', ''] + output.get()
>>>>>> >>> mail.send(to_addr, subject, os.linesep.join(body))
>>>>>> >>> + coverage_run(opts, coverage_runner, executables)
>>>>>> >>> except error.general as gerr:
>>>>>> >>> print(gerr)
>>>>>> >>> diff --git a/tester/rtems/testing/bsps/leon3-qemu-cov.ini
>>>>>> >>> b/tester/rtems/testing/bsps/leon3-qemu-cov.ini
>>>>>> >>> index 6b5e7e6..2f89117 100644
>>>>>> >>> --- a/tester/rtems/testing/bsps/leon3-qemu-cov.ini
>>>>>> >>> +++ b/tester/rtems/testing/bsps/leon3-qemu-cov.ini
>>>>>> >>> @@ -31,9 +31,10 @@
>>>>>> >>> # The Leon 3 QEMU BSP
>>>>>> >>> -[leon3-qemu]
>>>>>> >>> +[leon3-qemu-cov]
>>>>>> >>> bsp = leon3-qemu
>>>>>> >>> arch = sparc
>>>>>> >>> +target = sparc-rtems5
>>>>>> >>> tester = %{_rtscripts}/qemu.cfg
>>>>>> >>> bsp_qemu_opts = %{qemu_opts_base} -M leon3_generic
>>>>>> >>> bsp_qemu_cov_opts = -exec-trace %{test_executable}.cov
>>>>>> >>> diff --git a/tester/rtems/testing/coverage/symbol-sets.ini
>>>>>> >>> b/tester/rtems/testing/coverage/symbol-sets.ini
>>>>>> >>> index 0000000..a2ec7bc
>>>>>> >>> --- /dev/null
>>>>>> >>> +++ b/tester/rtems/testing/coverage/symbol-sets.ini
>>>>>> >>> @@ -0,0 +1,36 @@
>>>>>> >>> +# Copyright 2018 Chris Johns (chrisj at rtems.org)
>>>>>> without
>>>>>> conditions are
>>>>>> >>> met:
>>>>>> copyright
>>>>>> >>> notice,
>>>>>> copyright
>>>>>> >>> notice,
>>>>>> >>> documentation
>>>>>> CONTRIBUTORS
>>>>>> >>> "AS IS"
>>>>>> LIMITED TO,
>>>>>> >>> THE
>>>>>> PARTICULAR
>>>>>> >>> PURPOSE
>>>>>> CONTRIBUTORS
>>>>>> >>> BE
>>>>>> EXEMPLARY, OR
>>>>>> PROCUREMENT OF
>>>>>> >>> BUSINESS
>>>>>> WHETHER
>>>>>> >>> IN
>>>>>> >>> OTHERWISE)
>>>>>> ADVISED OF
>>>>>> >>> THE
>>>>>> >>> +[symbol-sets]
>>>>>> >>> +sets = score,rtems
>>>>>> >>> +[libraries]
>>>>>> >>> +score = @BUILD-TARGET@/c/@BSP@/cpukit/score/libscore.a
>>>>>> >>> +rtems = @BUILD-TARGET@/c/@BSP@/cpukit/rtems/librtems.a
>>>>>> >>> diff --git a/tester/rtems/testing/qemu.cfg
>>>>>> >>> b/tester/rtems/testing/qemu.cfg
>>>>>> >>> index bfcd2f5..52a3752 100644
>>>>>> >>> --- a/tester/rtems/testing/qemu.cfg
>>>>>> >>> +++ b/tester/rtems/testing/qemu.cfg
>>>>>> >>> @@ -51,8 +51,8 @@
>>>>>> >>> # Qemu common option patterns.
>>>>>> >>> -#%define qemu_opts_base -no-reboot -monitor none -serial stdio
>>>>>> >>> -nographic
>>>>>> >>> -%define qemu_opts_base -no-reboot -serial null -serial
>>>>>> mon:stdio
>>>>>> >>> -nographic
>>>>>> >>> +%define qemu_opts_base -no-reboot -monitor none -serial stdio
>>>>>> >>> -nographic
>>>>>> >>> +#%define qemu_opts_base -no-reboot -serial null -serial
>>>>>> mon:stdio
>>>>>> >>> -nographic
>>>>>> >>> %define qemu_opts_no_net -net none
>>>>>> >>> 2.14.3
>>>>>> >>> _______________________________________________
>>>>>> >>> devel mailing list
>>>>>> >>> devel at rtems.org
>>>>>> >>> http://lists.rtems.org/mailman/listinfo/devel
>>>>>> > devel mailing list
>>>>>> > devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180531/604a19d8/attachment-0001.html>
