[PATCH v2] tester: Add script to generate html coverage report from covoar output
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Thu May 31 21:57:50 UTC 2018
On 1 June 2018 at 02:50, Joel Sherrill <joel at rtems.org> wrote:
> On Thu, May 31, 2018 at 4:15 PM, Cillian O'Donnell <cpodonnell8 at gmail.com>
> wrote:
>> On Thu, 31 May 2018, 22:03 Vijay Kumar Banerjee, <
>> vijaykumar9597 at gmail.com> wrote:
>>> On 1 June 2018 at 02:14, Cillian O'Donnell <cpodonnell8 at gmail.com>
>>> wrote:
>>>> There is now a seperate bsp config for coverage, leon3-qemu-cov. That
>>>> is enough to trigger coverage now and --coverage could be reserved for
>>>> picking sets, probably renamed to --coverage-sets=... Or require sets to be
>>>> chosen --coverage-sets=all or specific sets --coverage-sets=score,sapi,cor
>>>> e
>>>> Actually the idea of having separate bsp configs for cov
>>> in each of the bsps will create a lot of files. The intention is
>>> to make it simple for the user. just adding --coverage
>>> should run coverage analysis. There's a plan to include
>>> the 'coverage' section into the bsp ini file, and hence the user wouldn't
>>> have to keep switching the bsp config files.
>> Actually that's exactly the way I had it working before Chris' recent
>> changes, he had a look at the way it's working and chose to create seperate
>> bsp config files. That may be the way he'd prefer. This was before the
>> --coverage option had another use other than triggering coverage, so his
>> thoughts may have changed on it.
> Chris should comment on the separate ini files. I think that might have
> been
> driven by couverture vs regular qemu before couverture was available from
> the RSB.
> Okay, we wait for Chris to comment on it then.
> I think it would be nice to have --coverage and if the BSP ini file
> doesn't support
> coverage, give an error.
Is the set option in the Python and processed by covoar in a way that still
> lets covoar be used on something besides RTEMS?
yes, it is totally handled by the script to 'feed' covoar with the options,
without changing the way it works.
I have a question/doubt.
By adding separate bsp config for cov. Are we not assuming that
the provided bsp ini supports coverage ?
>>> The idea of modifying it to --coverage-sets=all ;
>>> --coverage-sets=set1,set2,set3..... can surely be implemented
>>> in place of --coverage ; --coverage=set1,set2....
>>>> On Thu, 31 May 2018, 21:29 Vijay Kumar Banerjee, <
>>>>> On 1 June 2018 at 01:57, Cillian O'Donnell <cpodonnell8 at gmail.com>
>>>>> wrote:
>>>>>> So is it checking whether it's --coverage or --coverage=set1,set2?
>>>>>> Are those the 2 possibilities your checking?
>>>>>> Yes, right. :)
>>>>>> On Thu, 31 May 2018, 20:52 Vijay Kumar Banerjee, <
>>>>>>> On 1 June 2018 at 01:19, Gedare Bloom <gedare at rtems.org> wrote:
>>>>>>>> On Thu, May 31, 2018 at 3:47 PM, Vijay Kumar Banerjee
>>>>>>>> <vijaykumar9597 at gmail.com> wrote:
>>>>>>>> > On 1 June 2018 at 01:07, Cillian O'Donnell <cpodonnell8 at gmail.com>
>>>>>>>> wrote:
>>>>>>>> >> On 31 May 2018 at 19:07, Vijay Kumar Banerjee <
>>>>>>>> >> wrote:
>>>>>>>> >>> Add support in tester to run covoar and generate an html report
>>>>>>>> to
>>>>>>>> >>> display
>>>>>>>> >>> the summary of the coverage reports generated from covoar.
>>>>>>>> >>> Co-authored-by : Cillian O'Donnell <cpodonnell8 at gmail.com>
>>>>>>>> >>> tester/rt/coverage.py | 379
>>>>>>>> >>> tester/rt/test.py | 36 ++-
>>>>>>>> >>> tester/rtems/testing/bsps/leon3-qemu-cov.ini | 3 +-
>>>>>>>> >>> tester/rtems/testing/coverage/symbol-sets.ini | 36 +++
>>>>>>>> >>> tester/rtems/testing/qemu.cfg | 4 +-
>>>>>>>> >>> 5 files changed, 446 insertions(+), 12 deletions(-)
>>>>>>>> >>> create mode 100644 tester/rt/coverage.py
>>>>>>>> >>> create mode 100644 tester/rtems/testing/coverage/
>>>>>>>> symbol-sets.ini
>>>>>>>> >>> diff --git a/tester/rt/coverage.py b/tester/rt/coverage.py
>>>>>>>> >>> new file mode 100644
>>>>>>>> >>> index 0000000..25fbb9d
>>>>>>>> >>> --- /dev/null
>>>>>>>> >>> +++ b/tester/rt/coverage.py
>>>>>>>> >>> @@ -0,0 +1,379 @@
>>>>>>>> >>> +# RTEMS Tools Project (http://www.rtems.org/)
>>>>>>>> >>> +# Copyright 2014 Krzysztof Miesowicz (
>>>>>>>> krzysztof.miesowicz at gmail.com)
>>>>>>>> >>> +# All rights reserved.
>>>>>>>> >>> +# This file is part of the RTEMS Tools package in
>>>>>>>> 'rtems-tools'.
>>>>>>>> >>> +# Redistribution and use in source and binary forms, with or
>>>>>>>> without
>>>>>>>> >>> +# modification, are permitted provided that the following
>>>>>>>> conditions are
>>>>>>>> >>> met:
>>>>>>>> >>> +# 1. Redistributions of source code must retain the above
>>>>>>>> copyright
>>>>>>>> >>> notice,
>>>>>>>> >>> +# this list of conditions and the following disclaimer.
>>>>>>>> >>> +# 2. Redistributions in binary form must reproduce the above
>>>>>>>> copyright
>>>>>>>> >>> notice,
>>>>>>>> >>> +# this list of conditions and the following disclaimer in the
>>>>>>>> >>> documentation
>>>>>>>> >>> +# and/or other materials provided with the distribution.
>>>>>>>> >>> +# THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND
>>>>>>>> CONTRIBUTORS
>>>>>>>> >>> 'AS IS'
>>>>>>>> >>> +# AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
>>>>>>>> LIMITED TO,
>>>>>>>> >>> THE
>>>>>>>> >>> +# IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A
>>>>>>>> PARTICULAR
>>>>>>>> >>> PURPOSE
>>>>>>>> >>> +# ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR
>>>>>>>> CONTRIBUTORS
>>>>>>>> >>> BE
>>>>>>>> >>> +# LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
>>>>>>>> EXEMPLARY, OR
>>>>>>>> >>> +# CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
>>>>>>>> PROCUREMENT OF
>>>>>>>> >>> +# SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
>>>>>>>> OR
>>>>>>>> >>> BUSINESS
>>>>>>>> >>> +# INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
>>>>>>>> WHETHER
>>>>>>>> >>> IN
>>>>>>>> >>> +# CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
>>>>>>>> >>> OTHERWISE)
>>>>>>>> >>> +# ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF
>>>>>>>> ADVISED OF
>>>>>>>> >>> THE
>>>>>>>> >>> +# POSSIBILITY OF SUCH DAMAGE.
>>>>>>>> >>> +from rtemstoolkit import error
>>>>>>>> >>> +from rtemstoolkit import path
>>>>>>>> >>> +from rtemstoolkit import log
>>>>>>>> >>> +from rtemstoolkit import execute
>>>>>>>> >>> +from rtemstoolkit import macros
>>>>>>>> >>> +from datetime import datetime
>>>>>>>> >>> +from . import options
>>>>>>>> >>> +import shutil
>>>>>>>> >>> +import os
>>>>>>>> >>> +try:
>>>>>>>> >>> + import configparser
>>>>>>>> >>> +except:
>>>>>>>> >>> + import ConfigParser as configparser
>>>>>>>> >>> +class summary:
>>>>>>>> >>> + def __init__(self, p_summary_dir):
>>>>>>>> >>> + self.summary_file_path = path.join(p_summary_dir,
>>>>>>>> 'summary.txt')
>>>>>>>> >>> + self.index_file_path = path.join(p_summary_dir,
>>>>>>>> 'index.html')
>>>>>>>> >>> + self.bytes_analyzed = 0
>>>>>>>> >>> + self.bytes_not_executed = 0
>>>>>>>> >>> + self.percentage_executed = 0.0
>>>>>>>> >>> + self.percentage_not_executed = 100.0
>>>>>>>> >>> + self.ranges_uncovered = 0
>>>>>>>> >>> + self.branches_uncovered = 0
>>>>>>>> >>> + self.branches_total = 0
>>>>>>>> >>> + self.branches_always_taken = 0
>>>>>>>> >>> + self.branches_never_taken = 0
>>>>>>>> >>> + self.percentage_branches_covered = 0.0
>>>>>>>> >>> + self.is_failure = False
>>>>>>>> >>> + def parse(self):
>>>>>>>> >>> + if(not path.exists(self.summary_file_path)):
>>>>>>>> >>> + log.notice('summary file %s does not exist!' %
>>>>>>>> >>> + self.is_failure = True
>>>>>>>> >>> + return
>>>>>>>> >>> + with open(self.summary_file_path,'r') as summary_file:
>>>>>>>> >>> + self.bytes_analyzed = self._get_next_with_colon(summ
>>>>>>>> ary_file)
>>>>>>>> >>> self._get_next_with_colon(summary_file)
>>>>>>>> >>> + self.branches_total = self._get_next_with_colon(summ
>>>>>>>> ary_file)
>>>>>>>> >>> self._get_next_without_colon(summary_file)
>>>>>>>> >>> + if len(self.branches_uncovered) > 0 and
>>>>>>>> len(self.branches_total)
>>>>>>>> >>> > 0:
>>>>>>>> >>> + self.percentage_branches_covered = \
>>>>>>>> >>> + 1 - (float(self.branches_uncovered) /
>>>>>>>> >>> float(self.branches_total))
>>>>>>>> >>> + else:
>>>>>>>> >>> + return
>>>>>>>> >>> + def _get_next_with_colon(self, summary_file):
>>>>>>>> >>> + line = summary_file.readline()
>>>>>>>> >>> + if ':' in line:
>>>>>>>> >>> + return line.split(':')[1].strip()
>>>>>>>> >>> + else:
>>>>>>>> >>> + return ''
>>>>>>>> >>> + def _get_next_without_colon(self, summary_file):
>>>>>>>> >>> + return line.strip().split(' ')[0]
>>>>>>>> >>> +class report_gen_html:
>>>>>>>> >>> + def __init__(self, p_symbol_sets_list, build_dir, rtdir):
>>>>>>>> >>> + self.symbol_sets_list = ['score']
>>>>>>>> >>> + self.build_dir = build_dir
>>>>>>>> >>> + self.partial_reports_files = list(["index.html",
>>>>>>>> "summary.txt"])
>>>>>>>> >>> + self.number_of_columns = 1
>>>>>>>> >>> + self.covoar_src_path = path.join(rtdir, 'covoar')
>>>>>>>> >>> + def _find_partial_reports(self):
>>>>>>>> >>> + partial_reports = {}
>>>>>>>> >>> + for symbol_set in self.symbol_sets_list:
>>>>>>>> >>> + set_summary = summary(path.join(self.build_dir,
>>>>>>>> "coverage",
>>>>>>>> >>> + symbol_set))
>>>>>>>> >>> + set_summary.parse()
>>>>>>>> >>> + partial_reports[symbol_set] = set_summary
>>>>>>>> >>> + return partial_reports
>>>>>>>> >>> + def _prepare_head_section(self):
>>>>>>>> >>> + head_section = '''
>>>>>>>> >>> + <head>
>>>>>>>> >>> + <title>RTEMS coverage report</title>
>>>>>>>> >>> + <style type="text/css">
>>>>>>>> >>> + progress[value] {
>>>>>>>> >>> + -webkit-appearance: none;
>>>>>>>> >>> + appearance: none;
>>>>>>>> >>> + width: 150px;
>>>>>>>> >>> + height: 15px;
>>>>>>>> >>> + </style>
>>>>>>>> >>> + </head>'''
>>>>>>>> >>> + return head_section
>>>>>>>> >>> + def _prepare_index_content(self, partial_reports):
>>>>>>>> >>> + header = "<h1> RTEMS coverage analysis report </h1>"
>>>>>>>> >>> + header += "<h3>Coverage reports by symbols sets:</h3>"
>>>>>>>> >>> + table = "<table>"
>>>>>>>> >>> + table += self._header_row()
>>>>>>>> >>> + for symbol_set in partial_reports:
>>>>>>>> >>> + table += self._row(symbol_set,
>>>>>>>> partial_reports[symbol_set])
>>>>>>>> >>> + table += "</table> </br>"
>>>>>>>> >>> + timestamp = "Analysis performed on " +
>>>>>>>> datetime.now().ctime()
>>>>>>>> >>> + return "<body>\n" + header + table + timestamp +
>>>>>>>> "\n</body>"
>>>>>>>> >>> + def _row(self, symbol_set, summary):
>>>>>>>> >>> + row = "<tr>"
>>>>>>>> >>> + row += "<td>" + symbol_set + "</td>"
>>>>>>>> >>> + if summary.is_failure:
>>>>>>>> >>> + row += ' <td colspan="' +
>>>>>>>> str(self.number_of_columns-1) \
>>>>>>>> >>> + + '" style="background-color:red">FAILURE</td>'
>>>>>>>> >>> + else:
>>>>>>>> >>> + row += " <td>" + self._link(summary.index_file_
>>>>>>>> path,"Index")
>>>>>>>> >>> + + "</td>"
>>>>>>>> >>> + row += " <td>" +
>>>>>>>> >>> self._link(summary.summary_file_path,"Summary") \
>>>>>>>> >>> + + "</td>"
>>>>>>>> >>> + row += " <td>" + summary.bytes_analyzed + "</td>"
>>>>>>>> >>> + row += " <td>" + summary.bytes_not_executed +
>>>>>>>> "</td>"
>>>>>>>> >>> + row += " <td>" + summary.ranges_uncovered + "</td>"
>>>>>>>> >>> + row += " <td>" + summary.percentage_executed +
>>>>>>>> "%</td>"
>>>>>>>> >>> + row += " <td>" + summary.percentage_not_executed
>>>>>>>> + "%</td>"
>>>>>>>> >>> + row += ' <td><progress value="' +
>>>>>>>> >>> summary.percentage_executed \
>>>>>>>> >>> + + '" max="100"></progress></td>'
>>>>>>>> >>> + row += " <td>" + summary.branches_uncovered +
>>>>>>>> "</td>"
>>>>>>>> >>> + row += " <td>" + summary.branches_total + "</td>"
>>>>>>>> >>> + row += " <td> {:.3%}
>>>>>>>> >>> </td>".format(summary.percentage_branches_covered)
>>>>>>>> >>> + row += ' <td><progress value="{:.3}"
>>>>>>>> >>> max="100"></progress></td>'.format(100*summary.percentage_br
>>>>>>>> anches_covered)
>>>>>>>> >>> + row += "</tr>\n"
>>>>>>>> >>> + return row
>>>>>>>> >>> + def _header_row(self):
>>>>>>>> >>> + row = "<tr>"
>>>>>>>> >>> + row += "<th> Symbols set name </th>"
>>>>>>>> >>> + row += "<th> Index file </th>"
>>>>>>>> >>> + row += "<th> Summary file </th>"
>>>>>>>> >>> + row += "<th> Bytes analyzed </th>"
>>>>>>>> >>> + row += "<th> Bytes not executed </th>"
>>>>>>>> >>> + row += "<th> Uncovered ranges </th>"
>>>>>>>> >>> + row += "<th> Percentage covered </th>"
>>>>>>>> >>> + row += "<th> Percentage uncovered </th>"
>>>>>>>> >>> + row += "<th> Instruction coverage </th>"
>>>>>>>> >>> + row += "<th> Branches uncovered </th>"
>>>>>>>> >>> + row += "<th> Branches total </th>"
>>>>>>>> >>> + row += "<th> Branches covered percentage </th>"
>>>>>>>> >>> + row += "<th> Branches coverage </th>"
>>>>>>>> >>> + row += "</tr>\n"
>>>>>>>> >>> + self.number_of_columns = row.count('<th>')
>>>>>>>> >>> + return row
>>>>>>>> >>> + def _link(self, address, text):
>>>>>>>> >>> + return '<a href="' + address + '">' + text + '</a>'
>>>>>>>> >>> + def _create_index_file(self, head_section, content):
>>>>>>>> >>> + with open(path.join(self.build_dir,"report.html"),'w')
>>>>>>>> as f:
>>>>>>>> >>> + f.write(head_section)
>>>>>>>> >>> + f.write(content)
>>>>>>>> >>> + def generate(self):
>>>>>>>> >>> + partial_reports = self._find_partial_reports()
>>>>>>>> >>> + head_section = self._prepare_head_section()
>>>>>>>> >>> + index_content = self._prepare_index_content(pa
>>>>>>>> rtial_reports)
>>>>>>>> >>> + self._create_index_file(head_section,index_content)
>>>>>>>> >>> + def add_covoar_src_path(self):
>>>>>>>> >>> + table_js_path = path.join(self.covoar_src_path,
>>>>>>>> 'table.js')
>>>>>>>> >>> + covoar_css_path = path.join(self.covoar_src_path,
>>>>>>>> 'covoar.css')
>>>>>>>> >>> + symbol_set_dir = path.join(self.build_dir,
>>>>>>>> "coverage",
>>>>>>>> >>> symbol_set)
>>>>>>>> >>> + html_files = os.listdir(symbol_set_dir)
>>>>>>>> >>> + for html_file in html_files:
>>>>>>>> >>> + html_file = path.join(symbol_set_dir,
>>>>>>>> html_file)
>>>>>>>> >>> + if path.exists(html_file) and 'html' in
>>>>>>>> html_file:
>>>>>>>> >>> + with open(html_file, 'r') as f:
>>>>>>>> >>> + file_data = f.read()
>>>>>>>> >>> + file_data = file_data.replace('table.js',
>>>>>>>> >>> table_js_path)
>>>>>>>> >>> + file_data = file_data.replace('covoar.css'
>>>>>>>> covoar_css_path)
>>>>>>>> >>> + with open(html_file, 'w') as f:
>>>>>>>> >>> + f.write(file_data)
>>>>>>>> >>> +class build_path_generator(object):
>>>>>>>> >>> + Generates the build path from the path to executables
>>>>>>>> >>> + def __init__(self, executables, target):
>>>>>>>> >>> + self.executables = executables
>>>>>>>> >>> + self.target = target
>>>>>>>> >>> + def run(self):
>>>>>>>> >>> + build_path = '/'
>>>>>>>> >>> + Path = self.executables[0].split('/')
>>>>>>>> >>> + for P in Path:
>>>>>>>> >>> + if P == self.target:
>>>>>>>> >>> + break;
>>>>>>>> >>> + else:
>>>>>>>> >>> + build_path = path.join(build_path, P)
>>>>>>>> >>> + return build_path
>>>>>>>> >>> +class symbol_parser(object):
>>>>>>>> >>> + Parse the symbol sets ini and create custom ini file for
>>>>>>>> covoar
>>>>>>>> >>> + def __init__(self, symbol_config_path,
>>>>>>>> >>> + symbol_select_path, coverage_arg, build_dir):
>>>>>>>> >>> + self.symbol_select_file = symbol_select_path
>>>>>>>> >>> + self.symbol_file = symbol_config_path
>>>>>>>> >>> + self.symbol_sets = {}
>>>>>>>> >>> + self.cov_arg = coverage_arg
>>>>>>>> >>> + self.ssets = []
>>>>>>>> >>> + def parse(self):
>>>>>>>> >>> + config = configparser.ConfigParser()
>>>>>>>> >>> + try:
>>>>>>>> >>> + config.read(self.symbol_file)
>>>>>>>> >>> + if self.cov_arg:
>>>>>>>> >>> + self.ssets = self.cov_arg.split(',')
>>>>>>>> >>> + else:
>>>>>>>> >>> + self.ssets = config.get('symbol-sets',
>>>>>>>> >>> 'sets').split(',')
>>>>>>>> >>> + self.ssets = [ sset.encode('utf-8') for sset in
>>>>>>>> >>> self.ssets]
>>>>>>>> >>> + for sset in self.ssets:
>>>>>>>> >>> + lib = path.join(self.build_dir,
>>>>>>>> >>> + config.get('libraries', sset))
>>>>>>>> >>> + self.symbol_sets[sset] = lib.encode('utf-8')
>>>>>>>> >>> + except:
>>>>>>>> >>> + raise error.general('Symbol set parsing failed')
>>>>>>>> >>> + def _write_ini(self):
>>>>>>>> >>> + try:
>>>>>>>> >>> + sets = ', '.join(self.symbol_sets.keys())
>>>>>>>> >>> + config.add_section('symbol-sets')
>>>>>>>> >>> + config.set('symbol-sets', 'sets', sets)
>>>>>>>> >>> + for key in self.symbol_sets.keys():
>>>>>>>> >>> + config.add_section(key)
>>>>>>>> >>> + config.set(key, 'libraries',
>>>>>>>> self.symbol_sets[key])
>>>>>>>> >>> + with open(self.symbol_select_file, 'w') as conf:
>>>>>>>> >>> + config.write(conf)
>>>>>>>> >>> + except:
>>>>>>>> >>> + raise error.general('write failed')
>>>>>>>> >>> + def run(self):
>>>>>>>> >>> + self.parse()
>>>>>>>> >>> + self._write_ini()
>>>>>>>> >>> +class covoar(object):
>>>>>>>> >>> + Covoar runner
>>>>>>>> >>> + def __init__(self, base_result_dir, config_dir,
>>>>>>>> executables,
>>>>>>>> >>> explanations_txt):
>>>>>>>> >>> + self.base_result_dir = base_result_dir
>>>>>>>> >>> + self.config_dir = config_dir
>>>>>>>> >>> + self.executables = ' '.join(executables)
>>>>>>>> >>> + self.explanations_txt = explanations_txt
>>>>>>>> >>> + self.project_name = 'RTEMS-5'
>>>>>>>> >>> + def run(self, set_name, symbol_file):
>>>>>>>> >>> + covoar_result_dir = path.join(self.base_result_dir,
>>>>>>>> set_name)
>>>>>>>> >>> + if (not path.exists(covoar_result_dir)):
>>>>>>>> >>> + path.mkdir(covoar_result_dir)
>>>>>>>> >>> + if (not path.exists(symbol_file)):
>>>>>>>> >>> + raise error.general('symbol set file: coverage %s
>>>>>>>> was not
>>>>>>>> >>> created for covoar, skipping %s'% (symbol_file, set_name))
>>>>>>>> >>> + command = ('covoar -S ' + symbol_file
>>>>>>>> >>> + + ' -O ' + covoar_result_dir
>>>>>>>> >>> + + ' -E ' + self.explanations_txt
>>>>>>>> >>> + + ' -p ' + self.project_name + ' ' +
>>>>>>>> self.executables)
>>>>>>>> >>> + log.notice('Running covoar for %s' % (set_name))
>>>>>>>> >>> + print( 'covoar results directory:\n' +
>>>>>>>> covoar_result_dir )
>>>>>>>> >>> + executor = execute.execute(verbose = True, output =
>>>>>>>> >>> self.output_handler)
>>>>>>>> >>> + exit_code = executor.shell(command, cwd=os.getcwd())
>>>>>>>> >>> + if (exit_code[0] != 0):
>>>>>>>> >>> + raise error.general('covoar failure exit code: %d'
>>>>>>>> >>> (exit_code[0]))
>>>>>>>> >>> + log.notice('Coverage run for %s finished
>>>>>>>> successfully.' %
>>>>>>>> >>> (set_name))
>>>>>>>> >>> + log.notice('------------------
>>>>>>>> >>> + def output_handler(self, text):
>>>>>>>> >>> + log.notice('%s' % (text))
>>>>>>>> >>> +class coverage_run(object):
>>>>>>>> >>> + Coverage analysis support for rtems-test
>>>>>>>> >>> + def __init__(self, p_macros, coverage_arg, target):
>>>>>>>> >>> + Constructor
>>>>>>>> >>> + self.macros = p_macros
>>>>>>>> >>> + self.build_dir = self.macros['_cwd']
>>>>>>>> >>> self.macros.expand(self.macros['cov_explanations'])
>>>>>>>> >>> + self.test_dir = path.join(self.build_dir, 'coverage')
>>>>>>>> >>> + if (not path.exists(self.test_dir)):
>>>>>>>> >>> + path.mkdir(self.test_dir)
>>>>>>>> >>> + self.rtdir = path.abspath(self.macros['_rtdir'])
>>>>>>>> >>> + self.rtscripts = self.macros.expand(self.macros
>>>>>>>> ['_rtscripts'])
>>>>>>>> >>> + self.coverage_config_path = path.join(self.rtscripts,
>>>>>>>> >>> 'coverage')
>>>>>>>> >>> + self.symbol_config_path =
>>>>>>>> path.join(self.coverage_config_path,
>>>>>>>> >>> + 'symbol-sets.ini')
>>>>>>>> >>> + self.symbol_select_path =
>>>>>>>> 'symbol-select.ini')
>>>>>>>> >>> + self.executables = None
>>>>>>>> >>> + self.symbol_sets = []
>>>>>>>> >>> + self.no_clean = int(self.macros['_no_clean'])
>>>>>>>> >>> + self.report_format = self.macros['cov_report_format']
>>>>>>>> >>> + self.coverage_arg = coverage_arg
>>>>>>>> >>> + def run(self):
>>>>>>>> >>> + try:
>>>>>>>> >>> + if self.executables is None:
>>>>>>>> >>> + raise error.general('no test executables
>>>>>>>> provided.')
>>>>>>>> >>> + build_dir = build_path_generator(self.executables,
>>>>>>>> >>> self.target).run()
>>>>>>>> >>> + parser = symbol_parser(self.symbol_config_path,
>>>>>>>> >>> + self.symbol_select_path,
>>>>>>>> >>> + self.coverage_arg,
>>>>>>>> >>> + build_dir)
>>>>>>>> >>> + parser.run()
>>>>>>>> >>> + covoar_runner = covoar(self.test_dir,
>>>>>>>> >>> + self.executables,
>>>>>>>> >>> self.explanations_txt)
>>>>>>>> >>> + covoar_runner.run('score', self.symbol_select_path)
>>>>>>>> >>> + self._generate_reports();
>>>>>>>> >>> + self._summarize();
>>>>>>>> >>> + finally:
>>>>>>>> >>> + self._cleanup();
>>>>>>>> >>> + def _generate_reports(self):
>>>>>>>> >>> + log.notice('Generating reports')
>>>>>>>> >>> + if self.report_format == 'html':
>>>>>>>> >>> + report = report_gen_html(self.symbol_sets,
>>>>>>>> >>> + self.build_dir,
>>>>>>>> >>> + self.rtdir)
>>>>>>>> >>> + report.generate()
>>>>>>>> >>> + report.add_covoar_src_path()
>>>>>>>> >>> + def _cleanup(self):
>>>>>>>> >>> + if not self.no_clean:
>>>>>>>> >>> + log.notice('***Cleaning tempfiles***')
>>>>>>>> >>> + for exe in self.executables:
>>>>>>>> >>> + trace_file = exe + '.cov'
>>>>>>>> >>> + if path.exists(trace_file):
>>>>>>>> >>> + os.remove(trace_file)
>>>>>>>> >>> + def _summarize(self):
>>>>>>>> >>> + log.notice('Coverage analysis finished. You can find
>>>>>>>> results in
>>>>>>>> >>> %s' % (self.build_dir))
>>>>>>>> >>> diff --git a/tester/rt/test.py b/tester/rt/test.py
>>>>>>>> >>> index f4d9b5c..84dff01 100644
>>>>>>>> >>> --- a/tester/rt/test.py
>>>>>>>> >>> +++ b/tester/rt/test.py
>>>>>>>> >>> @@ -48,12 +48,14 @@ from rtemstoolkit import mailer
>>>>>>>> >>> from rtemstoolkit import reraise
>>>>>>>> >>> from rtemstoolkit import stacktraces
>>>>>>>> >>> from rtemstoolkit import version
>>>>>>>> >>> +from rtemstoolkit import check
>>>>>>>> >>> from . import bsps
>>>>>>>> >>> from . import config
>>>>>>>> >>> from . import console
>>>>>>>> >>> from . import report
>>>>>>>> >>> +from . import coverage
>>>>>>>> >>> class log_capture(object):
>>>>>>>> >>> def __init__(self):
>>>>>>>> >>> @@ -147,7 +149,7 @@ class test_run(object):
>>>>>>>> >>> def run(self):
>>>>>>>> >>> self.thread = threading.Thread(target = self.runner,
>>>>>>>> >>> - name = 'test[%s]' %
>>>>>>>> >>> path.basename(self.executable))
>>>>>>>> >>> + name = 'test[%s]' %
>>>>>>>> >>> self.thread.start()
>>>>>>>> >>> def is_alive(self):
>>>>>>>> >>> @@ -214,6 +216,10 @@ def killall(tests):
>>>>>>>> >>> for test in tests:
>>>>>>>> >>> test.kill()
>>>>>>>> >>> +def coverage_run(opts, coverage, executables):
>>>>>>>> >>> + coverage.executables = executables
>>>>>>>> >>> + coverage.run()
>>>>>>>> >>> def run(command_path = None):
>>>>>>>> >>> import sys
>>>>>>>> >>> tests = []
>>>>>>>> >>> @@ -221,15 +227,16 @@ def run(command_path = None):
>>>>>>>> >>> opts = None
>>>>>>>> >>> default_exefilter = '*.exe'
>>>>>>>> >>> try:
>>>>>>>> >>> - optargs = { '--rtems-tools': 'The path to the RTEMS
>>>>>>>> tools',
>>>>>>>> >>> - '--rtems-bsp': 'The RTEMS BSP to run the
>>>>>>>> test on',
>>>>>>>> >>> - '--user-config': 'Path to your local user
>>>>>>>> >>> configuration INI file',
>>>>>>>> >>> - '--report-mode': 'Reporting modes, failures
>>>>>>>> >>> (default),all,none',
>>>>>>>> >>> - '--list-bsps': 'List the supported BSPs',
>>>>>>>> >>> - '--debug-trace': 'Debug trace based on
>>>>>>>> specific
>>>>>>>> >>> flags',
>>>>>>>> >>> - '--filter': 'Glob that executables
>>>>>>>> must match
>>>>>>>> >>> to run (default: ' +
>>>>>>>> >>> + optargs = { '--rtems-tools': 'The path to the RTEMS
>>>>>>>> tools',
>>>>>>>> >>> + '--rtems-bsp': 'The RTEMS BSP to run
>>>>>>>> the test
>>>>>>>> >>> on',
>>>>>>>> >>> + '--user-config': 'Path to your local
>>>>>>>> user
>>>>>>>> >>> + '--report-mode': 'Reporting modes,
>>>>>>>> failures
>>>>>>>> >>> + '--list-bsps': 'List the supported
>>>>>>>> BSPs',
>>>>>>>> >>> + '--debug-trace': 'Debug trace based on
>>>>>>>> specific
>>>>>>>> >>> flags',
>>>>>>>> >>> + '--filter': 'Glob that executables
>>>>>>>> must
>>>>>>>> >>> match to run (default: ' +
>>>>>>>> >>> default_exefilter + ')',
>>>>>>>> >>> - '--stacktrace': 'Dump a stack trace on a
>>>>>>>> user
>>>>>>>> >>> termination (^C)' }
>>>>>>>> >>> + '--stacktrace': 'Dump a stack trace on
>>>>>>>> a user
>>>>>>>> >>> termination (^C)',
>>>>>>>> >>> + '--coverage': 'Perform coverage
>>>>>>>> analysis of
>>>>>>>> >>> test executables.'}
>>>>>>>> >>> mailer.append_options(optargs)
>>>>>>>> >>> opts = options.load(sys.argv,
>>>>>>>> >>> optargs = optargs,
>>>>>>>> >>> @@ -279,6 +286,15 @@ def run(command_path = None):
>>>>>>>> >>> raise error.general('RTEMS BSP not provided or an
>>>>>>>> invalid
>>>>>>>> >>> option')
>>>>>>>> >>> bsp = config.load(bsp[1], opts)
>>>>>>>> >>> bsp_config = opts.defaults.expand(opts.defa
>>>>>>>> ults['tester'])
>>>>>>>> >>> + coverage_enabled = opts.find_arg('--coverage')
>>>>>>>> >>> + if coverage_enabled:
>>>>>>>> >>> + if len(coverage_enabled) == 2:
>>>>>>>> >> Is this to check if sets have been provided to
>>>>>>>> --coverage=score,sapi, that
>>>>>>>> >> kind of thing? If so the variable name coverage_enabled doesn't
>>>>>>>> make sense
>>>>>>>> >> any more. Probably if symbol_sets and if len(symbol_sets) will
>>>>>>>> make more
>>>>>>>> >> sense for both cases.
>>>>>>>> > That's a good point.
>>>>>>>> > How about changing it to just 'coverage' instead ?
>>>>>>>> > Because it's still checking whether the option is given or
>>>>>>>> > not. symbol_sets might create confusion.
>>>>>>>> > Will that be OK ?
>>>>>>>> That name might collide with your class object (coverage)?
>>>>>>> That's actually why I kept it as coverage_enabled.
>>>>>>> I think we can go for coverage_option (?)
>>>>>>>> >>> + coverage_runner =
>>>>>>>> coverage.coverage_run(opts.defaults,
>>>>>>>> coverage_enabled[1],
>>>>>>>> opts.defaults['target'])
>>>>>>>> >>> + else:
>>>>>>>> >>> + coverage_runner =
>>>>>>>> >>> 0,
>>>>>>>> >>> report_mode = opts.find_arg('--report-mode')
>>>>>>>> >>> if report_mode:
>>>>>>>> >>> if report_mode[1] != 'failures' and \
>>>>>>>> >>> @@ -365,6 +381,8 @@ def run(command_path = None):
>>>>>>>> >>> reports.failures(),
>>>>>>>> >>> 'Log', '===', ''] + output.get()
>>>>>>>> >>> mail.send(to_addr, subject, os.linesep.join(body))
>>>>>>>> >>> + coverage_run(opts, coverage_runner, executables)
>>>>>>>> >>> except error.general as gerr:
>>>>>>>> >>> print(gerr)
>>>>>>>> >>> diff --git a/tester/rtems/testing/bsps/leon3-qemu-cov.ini
>>>>>>>> >>> b/tester/rtems/testing/bsps/leon3-qemu-cov.ini
>>>>>>>> >>> index 6b5e7e6..2f89117 100644
>>>>>>>> >>> --- a/tester/rtems/testing/bsps/leon3-qemu-cov.ini
>>>>>>>> >>> +++ b/tester/rtems/testing/bsps/leon3-qemu-cov.ini
>>>>>>>> >>> @@ -31,9 +31,10 @@
>>>>>>>> >>> # The Leon 3 QEMU BSP
>>>>>>>> >>> -[leon3-qemu]
>>>>>>>> >>> +[leon3-qemu-cov]
>>>>>>>> >>> bsp = leon3-qemu
>>>>>>>> >>> arch = sparc
>>>>>>>> >>> +target = sparc-rtems5
>>>>>>>> >>> tester = %{_rtscripts}/qemu.cfg
>>>>>>>> >>> bsp_qemu_opts = %{qemu_opts_base} -M leon3_generic
>>>>>>>> >>> bsp_qemu_cov_opts = -exec-trace %{test_executable}.cov
>>>>>>>> >>> diff --git a/tester/rtems/testing/coverage/symbol-sets.ini
>>>>>>>> >>> b/tester/rtems/testing/coverage/symbol-sets.ini
>>>>>>>> >>> index 0000000..a2ec7bc
>>>>>>>> >>> --- /dev/null
>>>>>>>> >>> +++ b/tester/rtems/testing/coverage/symbol-sets.ini
>>>>>>>> >>> @@ -0,0 +1,36 @@
>>>>>>>> >>> +# Copyright 2018 Chris Johns (chrisj at rtems.org)
>>>>>>>> 'rtems-tools'.
>>>>>>>> without
>>>>>>>> conditions are
>>>>>>>> >>> met:
>>>>>>>> copyright
>>>>>>>> >>> notice,
>>>>>>>> copyright
>>>>>>>> >>> notice,
>>>>>>>> >>> documentation
>>>>>>>> CONTRIBUTORS
>>>>>>>> >>> "AS IS"
>>>>>>>> LIMITED TO,
>>>>>>>> >>> THE
>>>>>>>> PARTICULAR
>>>>>>>> >>> PURPOSE
>>>>>>>> CONTRIBUTORS
>>>>>>>> >>> BE
>>>>>>>> EXEMPLARY, OR
>>>>>>>> PROCUREMENT OF
>>>>>>>> OR
>>>>>>>> >>> BUSINESS
>>>>>>>> WHETHER
>>>>>>>> >>> IN
>>>>>>>> >>> OTHERWISE)
>>>>>>>> ADVISED OF
>>>>>>>> >>> THE
>>>>>>>> >>> +[symbol-sets]
>>>>>>>> >>> +sets = score,rtems
>>>>>>>> >>> +[libraries]
>>>>>>>> >>> +score = @BUILD-TARGET@/c/@BSP@/cpukit/score/libscore.a
>>>>>>>> >>> +rtems = @BUILD-TARGET@/c/@BSP@/cpukit/rtems/librtems.a
>>>>>>>> >>> diff --git a/tester/rtems/testing/qemu.cfg
>>>>>>>> >>> b/tester/rtems/testing/qemu.cfg
>>>>>>>> >>> index bfcd2f5..52a3752 100644
>>>>>>>> >>> --- a/tester/rtems/testing/qemu.cfg
>>>>>>>> >>> +++ b/tester/rtems/testing/qemu.cfg
>>>>>>>> >>> @@ -51,8 +51,8 @@
>>>>>>>> >>> # Qemu common option patterns.
>>>>>>>> >>> -#%define qemu_opts_base -no-reboot -monitor none -serial
>>>>>>>> stdio
>>>>>>>> >>> -nographic
>>>>>>>> >>> -%define qemu_opts_base -no-reboot -serial null -serial
>>>>>>>> mon:stdio
>>>>>>>> >>> -nographic
>>>>>>>> >>> +%define qemu_opts_base -no-reboot -monitor none -serial stdio
>>>>>>>> >>> -nographic
>>>>>>>> >>> +#%define qemu_opts_base -no-reboot -serial null -serial
>>>>>>>> mon:stdio
>>>>>>>> >>> -nographic
>>>>>>>> >>> %define qemu_opts_no_net -net none
>>>>>>>> >>> 2.14.3
>>>>>>>> >>> _______________________________________________
>>>>>>>> >>> devel mailing list
>>>>>>>> >>> devel at rtems.org
>>>>>>>> >>> http://lists.rtems.org/mailman/listinfo/devel
>>>>>>>> > devel mailing list
>>>>>>>> > devel at rtems.org
>> devel mailing list
>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180601/0a769d9b/attachment-0001.html>
