[PATCH 1/3] source-builder/config: Add couverture-qemu general config & build instructions.
Cillian O'Donnell cpodonnell8 at gmail.com
Tue May 1 06:31:13 UTC 2018
On Tue, 1 May 2018, 00:52 Chris Johns, <chrisj at rtems.org> wrote:
> On 28/04/2018 20:18, Cillian O'Donnell wrote:
> >  source-builder/config/couverture-qemu-2-1.cfg | 104
> Why a new file? Could the existing qemu config be used?
We were thinking at the time that this would eventually replace the qemu
that's there so it was best if it was self contained. They are identical in
places so yes a lot of overlap.
> I would prefer to have as few of the global configs as possible and share
> them
> as much as possible.
> >  1 file changed, 104 insertions(+)
> >  create mode 100644 source-builder/config/couverture-qemu-2-1.cfg
> > diff --git a/source-builder/config/couverture-qemu-2-1.cfg
> b/source-builder/config/couverture-qemu-2-1.cfg
> > new file mode 100644
> > index 0000000..b0a31bb
> > --- /dev/null
> > +++ b/source-builder/config/couverture-qemu-2-1.cfg
> > @@ -0,0 +1,104 @@
> > +# This configuration file configure's, make's and install's
> Couverture-QEMU.
> > +%if %{release} == %{nil}
> > +  %define release 1
> > +%endif
> > +# The description.
> > +Name:      couverture-qemu-%{qemu_version}-%{_host}-%{release}
> > +Summary:   Couverture-Qemu is a processor simulator with extra trace
> ability.
> I do not mind we have just the QEMU name and summary.
> > +Version:   %{qemu_version}
> > +Release:   %{release}
> > +URL:            https://github.com/AdaCore/qemu
> > +BuildRoot: %{_tmppath}/%{name}-root-%(%{__id_u} -n)
> > +# List of architectures to be built
> > +%define qemu_archs arm-softmmu,i386-softmmu,lm32-softmmu,mips-softmmu
> > +%define qemu_archs %{qemu_archs},ppc-softmmu,sparc-softmmu
> Why limit the archs?
These are the ones I tested that produced same results with rtems tester to
the existing qemu. I think there is also ones that aren't relevant to rtems.
> > +# Prepare the source code.
> > +%prep
> > +  build_top=$(pwd)
> > +  source_dir_qemu="qemu-%{qemu_version}"
> > +  %source setup qemu -n qemu-%{qemu_version}
> Why remove the -q?
>From our discussion last year
>     3. What does the -q option do in the %prep section of the build, this
>     option shows up in examples in the docs but there is no description of
>     what it does?
>     %source setup qemu -q -n qemu-%{qemu_version}
It is a spec file compatible option that is not used. You can remove the -q.
> > +  %patch setup qemu -p1
> > +  cd ${build_top}
> > +%build
> > +  build_top=$(pwd)
> > +  %{build_directory}
> > +  mkdir -p ${build_dir}
> > +  cd ${build_dir}
> > +  %if %{pkgconfig check vdeplug}
> > +    VDE_CONFIG="--enable-vde"
> > +    VDE_CFLAGS="%{pkgconfig cflags vdeplug}"
> > +    VDE_LDFLAGS="%{pkgconfig ldflags vdeplug} %{pkgconfig libs vdeplug}"
> > +  %endif
> > +  %{host_build_flags}
> > +  if test "%{_build}" != "%{_host}" ; then
> > +    CROSS_PREFIX_OPTION="--cross-prefix=%{_host}-"
> > +  fi
> > +  SYSROOT=$SB_TMPPREFIX
> > +  # The --extra-cflags and --extra-ldflags do not work as expected.
> > +  # Hack warning: MSYS2 does not seem to convert the path to
> > +  #               a shell path from Windows so we keep them
> > +  #               separate and handle it in the pkgconfig tool.
> > +  PKG_CONFIG_DEFAULT_PATH=${PKG_CONFIG_PATH} \
> > +  PKG_CONFIG_PATH=$SYSROOT/lib/pkgconfig \
> > +  PKG_CONFIG_BUILD_TOP_DIR=$SB_TMPROOT \
> > +  %{_ld_library_path}=$SYSROOT/lib \
> > +  LDFLAGS="-Wl,-rpath -Wl,/$SB_PREFIX_CLEAN/lib ${VDE_LDFLAGS}" \
> > +  CFLAGS="${CFLAGS} ${VDE_CFLAGS}" \
> > +  ../${source_dir_qemu}/configure \
> > +    --prefix=%{_prefix} \
> > +    ${CROSS_PREFIX_OPTION} \
> > +    --make=%{__make} \
> > +    --target-list=%{?with_qemu_archs:%{with_qemu_archs}}\
> > +                  %{!?with_qemu_archs:%{qemu_archs}} \
> > +    ${VDE_CONFIG} \
> > +    --disable-smartcard-nss \
> > +    --disable-tools \
> > +    --disable-pie \
> > +    --disable-vnc \
> > +    --disable-sdl \
> > +    --disable-gtk \
> > +    --disable-opengl \
> > +    --disable-netmap \
> > +    --disable-werror \
> Some of these lines have white space at the end which seems wrong.
> > +    --disable-virtfs \
> > +    --disable-docs
> Does the standard qemu build with these added?
Not sure, didn't test that.
> Chris
> > +  %{__make} %{?_smp_mflags} all
> > +  cd ${build_top}
> > +%install
> > +  build_top=$(pwd)
> > +  %{__rmdir} $SB_BUILD_ROOT
> > +  cd ${build_dir}
> > +  %{__make} DESTDIR=$SB_BUILD_ROOT install
> > +  cd ${build_top}
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180501/9231a07c/attachment-0002.html>
