rtems-tools: coverage covoar GSoC merge
Cillian O'Donnell cpodonnell8 at gmail.com
Fri May 4 06:26:53 UTC 2018
On Fri, 4 May 2018, 01:15 Chris Johns, <chrisj at rtems.org> wrote:
> On 04/05/2018 09:04, Joel Sherrill wrote:
> > On Thu, May 3, 2018 at 1:45 PM, Vijay Kumar Banerjee <
> vijaykumar9597 at gmail.com
> > <mailto:vijaykumar9597 at gmail.com>> wrote:
> >     On 3 May 2018 at 22:58, Cillian O'Donnell <cpodonnell8 at gmail.com
> >     <mailto:cpodonnell8 at gmail.com>> wrote:
> >         On Thu, 3 May 2018, 16:23 Vijay Kumar Banerjee,
> >         <vijaykumar9597 at gmail.com <mailto:vijaykumar9597 at gmail.com>>
> wrote:
> >             Hello,
> >             I want to ask some things about the project to get a clear
> >             understanding of the objectives/milestones and current
> status of the
> >             project. I also seek advice on my Tasks/obectives.
> >             1. The covoar has been updated to read symbols from the
> library and
> >             the next milestone is to remove covoar's dependancy on the
> external
> >             tools, which Chris is working on . ( Is that correct? )
> >         Looks like it won't be necessary for gsoc, so we won't have to
> wait for
> >         their removal. Chris might still have some other changes to make
> though
> >         and then we can pull master and branch off from there.
> >     Understood.
> > If it is working as is, you are OK to work on GSoC objectives. Emphasis
> on the
> > "working" part.
> > If something is broken right now, we want to fix it. :)
> Agreed.
No covoar is working fine now.
> > We also want to make sure all of the previous work is merged into the
> master.
> > There may be
> > clean up left for this. Cillian is the best person to answer this one.
> Has patches for this been posted? If they have I may have dropped the ball
> by
> not handling them.
Everything covoar related has been posted. Suppose the next thing is fix up
the rtems tester stuff and post those patches for comments. I'll try and do
that over the weekend.
> > Chris has identified things to improve covoar which are not all required
> to be
> > done now.
> Yes. I am working on removing addr2line as the first step.
> >             2. after it is done , the next step,I think, would be to
> update the
> >             coverage.py and test.py with the changes in covoar.
> >         Yeah getting all the rtems tester code up to a standard that
> Chris will
> >         be happy to merge it will be the next step.
> >     So basically we wait for Chris to make the changes to covoar, needed
> for us
> >     to start working on coverage code to make it running and up to the
> standards.
> > Chris can answer this. But if it works and produces coverage reports, it
> is ready.
> > If it is broken, report it.
> This is correct. The tools currently is host specific and my work is to
> make it
> native and contained so it is portable.
> > All clean up and removal of external tools should not impact your
> project if the
> > code is working now. :)
> I agree.
> Chris
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180504/6c57d15e/attachment-0002.html>
