[PATCH 4/4] covoar: Control the RLD verbose level from the -v option.
Sat May 5 14:22:03 UTC 2018
Seems obvious. Push it.
On Sat, May 5, 2018, 3:41 AM Chris Johns <chrisj at rtems.org> wrote:
>  tester/covoar/covoar.cc | 3 ++-
>  1 file changed, 2 insertions(+), 1 deletion(-)
> diff --git a/tester/covoar/covoar.cc b/tester/covoar/covoar.cc
> index 09c86c2..5bed98f 100644
> --- a/tester/covoar/covoar.cc
> +++ b/tester/covoar/covoar.cc
> @@ -227,7 +227,8 @@ int main(
>        case 'S': symbolSet           = optarg; break;
>        case 'T': target              = optarg; break;
>        case 'O': outputDirectory     = optarg; break;
> -      case 'v': Verbose             = true;   break;
> +      case 'v': Verbose             = true;
> +                rld::verbose_inc ();          break;
>        case 'p': projectName         = optarg; break;
>        case 'd': debug               = true;   break;
>        default: /* '?' */
> 2.15.1
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180505/4d14387b/attachment-0002.html>
