Fwd: [PATCH 2/4] covoar: Use DWARF to map addresses to source files and lines.
Vijay Kumar Banerjee
vijaykumar9597 at gmail.com
Mon May 7 08:00:50 UTC 2018
On 6 May 2018 at 13:29, Chris Johns <chrisj at rtems.org> wrote:
> On 6/5/18 5:28 pm, Vijay Kumar Banerjee wrote:
>> On 6 May 2018 at 08:54, Chris Johns <chrisj at rtems.org <mailto:
>> chrisj at rtems.org>> wrote:
>> Would you please try `waf clean build` to see if rebuilding
>> everything fixes this?
>> still getting the same error .
>> I'm using g++ 7.3.1 on fedora 27.
> OK
> If you have changed something in the code, can you please send a patch for
>> the same ?
> I have not changed anything. I do not have a Linux box to try.
> I tried to do it afresh as well, it's still failing to build.
Can someone please try to build it in a linux system ?
> Chris
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180507/f09fd5e4/attachment-0002.html>
