Fwd: [PATCH 2/4] covoar: Use DWARF to map addresses to source files and lines.
Mon May 7 17:56:46 UTC 2018
Hi
I have attached a workaround. It seems that libgen.h has this:
/* Return final component of PATH.
   This is the weird XPG version of this function.  It sometimes will
   modify its argument.  Therefore we normally use the GNU version (in
   <string.h>) and only if this header is included make the XPG
   version available under the real name.  */
extern char *__xpg_basename (char *__path) __THROW;
#define basename        __xpg_basename
Chris has used basename as a method name and even though that should
be perfectly acceptable, the macro above gets expanded, the name
gets changed (in some places) to rld::path::__xpg_basename()
      r.lowSourceLine = rld::path::basename (location);
IMO the fix is to add dirname to rld-files, use rld basename and dirname
exclusively, and avoid libgen.h at all costs.
I didn't do that much work. I got lucky in a couple of files by removing the
include of libgen.h since it wasn't needed but I had to leave it in one
place.
$ grep dirname *.cc
GcovData.cc:    dirname( path );
Hopefully this lets you all proceed with Chris' patches and my slight hack
in place.
Ultimate solution is probably simple. We just need to hear from Chris.
--joel
On Mon, May 7, 2018 at 12:42 PM, Joel Sherrill <joel at rtems.org> wrote:
> On Mon, May 7, 2018 at 12:36 PM, Vijay Kumar Banerjee <
> vijaykumar9597 at gmail.com> wrote:
>> On Mon, 7 May 2018, 22:57 Cillian O'Donnell, <cpodonnell8 at gmail.com>
>> wrote:
>>> Yeah I'm seeing the same as Joel, at least were further then we were :).
>>> I've been mostly working on the rtems-tester support, so just to give an
>>> update. I spent all day Saturday and today on it. It's taking longer than
>>> expected, re-orienting myself and deciding what is needed and not needed
>>> now with the changes in covoar. The problems are not difficult, it's just
>>> taking some time re-organizing everything. My time is limited during the
>>> week, so it'll probably be next weekend before I can finish it off. Vijay
>>> if you have time during the week I could push what I have and you could
>>> take a stab at some of them and then I could it finish off next weekend if
>>> you haven't already.
>> please send them, I can look into them for sure.
> Keep plugging away.
> I think there is something wrong in rld related to basename. My first
> thought was that the undefined symbol was because we didn't include the
> library. Now I think it is because something got misconfigured on
> Centos/Fedora/etc. Looking into this.
>>> On 7 May 2018 at 15:40, Joel Sherrill <joel at rtems.org> wrote:
>>>> On Mon, May 7, 2018 at 6:01 AM, Vijay Kumar Banerjee <
>>>>> I have added the path to libdwarf here
>>>> That worked for me to build but not to link.
>>>> I'm not sure why this rld symbol turned up missing on Centos 7.
>>>> $ ./waf -v
>>>> Waf: Entering directory `/home/joel/rtems-work/rtems-tools/build'
>>>> [228/229] Linking build/tester/covoar/trace-converter
>>>> 09:38:25 runner ['/usr/bin/g++', 'tester/covoar/TraceConverter.cc.2.o',
>>>> 'tester/covoar/TraceList.cc.2.o', 'tester/covoar/TraceReaderBase.cc.2.o',
>>>> 'tester/covoar/TraceReaderLogQEMU.cc.2.o',
>>>> 'tester/covoar/TraceWriterBase.cc.2.o', 'tester/covoar/TraceWriterQEMU.cc.2.o',
>>>> '-o/home/joel/rtems-work/rtems-tools/build/tester/covoar/trace-converter',
>>>> '-Wl,-Bstatic', '-Ltester/covoar', '-Lrtemstoolkit', '-lccovoar', '-lrld',
>>>> '-ldwarf', '-lelf', '-liberty', '-Wl,-Bdynamic']
>>>> [229/229] Linking build/tester/covoar/covoar
>>>> 09:38:25 runner ['/usr/bin/g++', 'tester/covoar/covoar.cc.3.o',
>>>> '-o/home/joel/rtems-work/rtems-tools/build/tester/covoar/covoar',
>>>> tester/covoar/libccovoar.a(DesiredSymbols.cc.1.o): In function
>>>> `Coverage::DesiredSymbols::determineSourceLines(Coverage::CoverageRanges*,
>>>> Coverage::ExecutableInfo*)':
>>>> /home/joel/rtems-work/rtems-tools/build/../tester/covoar/DesiredSymbols.cc:413:
>>>> undefined reference to `rld::path::__xpg_basename(std::string const&)'
>>>> /home/joel/rtems-work/rtems-tools/build/../tester/covoar/DesiredSymbols.cc:415:
>>>> collect2: error: ld returned 1 exit status
>>>> Waf: Leaving directory `/home/joel/rtems-work/rtems-tools/build'
>>>> Build failed
>>>>  -> task in 'trace-converter' failed with exit status 1:
>>>>         {task 34721616: cxxprogram TraceConverter.cc.2.o,TraceLis
>>>> t.cc.2.o,TraceReaderBase.cc.2.o,TraceReaderLogQEMU.cc.2.o,Tr
>>>> aceWriterBase.cc.2.o,TraceWriterQEMU.cc.2.o -> trace-converter}
>>>>  -> task in 'covoar' failed with exit status 1:
>>>>         {task 34820256: cxxprogram covoar.cc.3.o -> covoar}
>>>>> diff --git a/tester/covoar/wscript b/tester/covoar/wscript
>>>>> index 55d5ec9..dd4ad83 100644
>>>>> --- a/tester/covoar/wscript
>>>>> +++ b/tester/covoar/wscript
>>>>> @@ -63,6 +63,7 @@ def build(bld):
>>>>>      rtl_includes = [rtemstoolkit,
>>>>>  		    rtemstoolkit + '/elftoolchain/libelf',
>>>>>  		    rtemstoolkit + '/elftoolchain/common',
>>>>> +		    rtemstoolkit + '/elftoolchain/libdwarf',
>>>>>  		    rtemstoolkit + '/libiberty']
>>>>>      if bld.env.DEST_OS == 'win32':
>>>>>          rtl_includes += [rtemstoolkit + '/win32']
>>>>> -- vijay
>>>>> On 7 May 2018 at 13:30, Vijay Kumar Banerjee <vijaykumar9597 at gmail.com
>>>>> > wrote:
>>>>>> On 6 May 2018 at 13:29, Chris Johns <chrisj at rtems.org> wrote:
>>>>>>> On 6/5/18 5:28 pm, Vijay Kumar Banerjee wrote:
>>>>>>>> On 6 May 2018 at 08:54, Chris Johns <chrisj at rtems.org <mailto:
>>>>>>>> chrisj at rtems.org>> wrote:
>>>>>>>>         Would you please try `waf clean build` to see if rebuilding
>>>>>>>>         everything fixes this?
>>>>>>>> still getting the same error .
>>>>>>>> I'm using g++ 7.3.1 on fedora 27.
>>>>>>> OK
>>>>>>> If you have changed something in the code, can you please send a
>>>>>>>> patch for the same ?
>>>>>>> I have not changed anything. I do not have a Linux box to try.
>>>>>>> I tried to do it afresh as well, it's still failing to build.
>>>>>> Can someone please try to build it in a linux system ?
>>>>>>> Chris
>>>>> _______________________________________________
>>>>> devel mailing list
>>>>> devel at rtems.org
>>>>> http://lists.rtems.org/mailman/listinfo/devel
>>>> devel mailing list
>>>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180507/fdb06689/attachment-0002.html>
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180507/fdb06689/attachment-0002.obj>
