ftp server upload filer error.
jameszxj
jameszxj at gmail.com
Tue May 8 05:54:51 UTC 2018
sorry, this problem is nothing to do with libbsd. The rtems/cpukit/ftpd/ftpd.c add a new function yield(),
this function makes the problem.
static void
yield(void)
* If we build not for the legacy network stack, then we use the libbsd. In
* the libbsd there is no global network stack semaphore which provides round
* robin fairness for threads of equal priority.
#ifndef RTEMS_NETWORKING
yield();
#endif
recursive invocation yield() make the function do not return. I use rtems_task_wake_after(0) replace the yield,
ftp server works correctly.
------------------ Original ------------------
Date: Fri, May 4, 2018 12:00 PM
To: "devel"<devel at rtems.org>;
Subject: ftp server upload filer error.
hi,
I update libbsd to the github version, and when i upload a file, the upload process failed at the end, and the target shell stuck.
I disconnect from the ftp client, shell print the msg
debug: _bsd_sonewconn: pcb 0x15df2000: Listen queue overflow: 2 already in queue awaiting acceptance (1 occurrences)
The target still respond the ping command.
URL: <http://lists.rtems.org/pipermail/devel/attachments/20180508/f1e7c6dc/attachment-0002.html>
